Nov 17, 2008, 09:16 PM
#121
Personal Sales Rating: ( 0)
Drives: evo9 and 01 acura CLS
Quote:
Originally Posted by 03whitegsr
Seems a little harsh considering Full-Race has since redesigned the manifold to have a port matched inlet?
first the OP says its not port matched but shows a pic of a gasket (which is much larger than the evo exhaust ports), then people tell him the manifold is good, he still argues, it does not take a genius to realize a port-matched manifold is better, easy fix, go to machine shop and have it port matched, i don't know why this was such a big deal to him... like the OP was all upset like as if full-race ripped him off or something...
Quote:
Originally Posted by Wicked E
You're late to the program...
-E
i don't understand what your trying to say, seriously. If your saying i posted late i was watching this thread since the beginning and was trying to stay out, i try to be polite but sometimes i just gotta say something... like it really seems a lot of people on here are fixing up a car for the first time and have ZERO knowledge...
__________________
oh shAt miVak juSt kiCkeD iN y0!!
Offline
Nov 18, 2008, 08:54 AM
#122
Personal Sales Rating: ( 4)
Drives: EVO 8, E46 BMW
The tread evolved from him thinking the port was supposed to match the gasket to him realizing the manifold flange was slightly smaller then the port where the gasket is oversized and he still wanted to port match it to the head port because he felt it would hurt performance.
Geoff, does the new flange match the gasket or the head port?
Offline
Nov 18, 2008, 03:32 PM
#123
Personal Sales Rating: ( 1)
Drives: EVO VIII
Quote:
The bad thing is not to ask but to be sure that you know everything
__________________
ECUFLASH, Cosworth Pistons, Pauter Rods, Ported Head, Turbo XS FMIC, Exedy Triple Plate, Blitz Sus Air Intake, Helix Cam Gears, Greedy Timing Belt, Ferrea Valve Springs and Retainers, Cosworth 272/272, ARP Headstuds, Custom O2 Housing (divided), Rhys Millen Turbo-Back, Greddy Profec B, Walbro 255, Tial BOV, EVO 9 Turbo,FullRace Prostock Manifold, Helix 720cc, B&M Short Shift, Pilot Shift Light, Nisei Itercooler Piping Kit, Nisei Small Battery, Leda Suspension, Stopteck Brake Lines
Offline
Nov 18, 2008, 06:19 PM
#124
Quote:
touche
__________________
Offline
Dec 9, 2008, 09:26 AM
#125
Drives: EVO 9 FQ320
Quote:
Originally Posted by Full-Race Geoff
the 500hp "ceiling" is only applicable to the very old manifolds that did not have our twinscroll-specific cnc ported head flange:
As of 2008, every evo twinscroll manifold from Full-Race has our CNC ported headflange and can support well over 500whp.
if you have an old head flange, you can simply port it (i even recommend further port matching on the cnc flanges...)
Just wondered i'm picking up a second hand full race manifold next week. As you recommend porting i might give it a go, will a dremel touch it? also is there enough meat on it as i haven't seen it or any F R manifolds before? as i plan on using a fp red.
also is it worth ceramic coating?
like this;
http://www.zircotec.com/page/exhaust_system_coatings/60
cheers
Offline
Dec 16, 2008, 07:29 PM
#126
Drives: 1G DSM, 07Si, E46M3
The flow is turbulent to begin with so it makes me laugh when you say this supposed step would cause turbulence, like it would really matter in the bigger picture. The Reynolds number of exhaust flow in an exhaust runner is WELL above the transition region. On the intial blow down you are talking mach 1 fluid velocities in 900+ C temperatures. It's a highly turbulent flow and you are reducing the flow area, supposedly. If it was a diverging cross sectional area change, sure, you could really hurt flow, in a theoretical sense. But even then, the pressure drop associated with this transition probably is only a few percent of the total pressure drop of the runner.
Just by looking at the pictures and being familar with the 4G63 I can tell you that port is probably very close to being "port matched" though.
Steady state ought to be a fair rough estimation... but exhaust is a pulsation, and you all need to be talking about wave propagation...
Hytech use to have a great little article about scavenging cylinders and reversion chambers... fun stuff..
__________________
4g63
Quote:
Originally Posted by 9sec9:
Our success was based solely on the support that we received from Buschur Racing
Quote:
Originally Posted by Indy Evo:
David Buschur gave me my first break when he was working on some aero stuff and the rest is history.
Offline
Dec 16, 2008, 07:44 PM
#127
Drives: 2006 Evo 9, 93 MR2 Turbo
should have bought it new, then you would have had somebody to complain to
Offline
Dec 20, 2008, 07:52 AM
#128
Drives: EVO 9 FQ320
Offline
Dec 20, 2008, 09:56 AM
#129
Personal Sales Rating: ( 3)
2005 Mitsubishi Lancer Evolution
Drives: 2005 EVO8, 2004 CTS-V
I have no experience with the Full Race header but....typically quality headers will have those cuts to allow for the flange to move so it does not warp from the heat cycles (heating and cooling when running-shutting down) I have had this happen on previous cars and it usually leads to an exhaust leak.
The real question is..is the flange still true or flat where it bolts to the head. Will the bolts line that back up. I doubt it....to a degree it may...and you may have to force it over the stud.
This is just my opinion from past experience.
__________________
In an effort to make this site easier to navigate for everyone, please refrain from posting off topic comments or posting threads in the wrong forums.
Forum rules:
http://forums.evolutionm.net/evom-newbie-faqs-forum/announcements.html
AMS 2.0L // Cosworth Head // JUN 264 // AEM EMS //
Stock Turbo // Built/Tuned by me
Best time 12.84 @ 105.3 60ft 1.737
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
