Jet-Hot - Not Recommended
Old Dec 5, 2006, 01:31 PM
Killboy's Avatar
Thumbs down Jet-Hot 1300 Degree Coating - Not Recommended
Just a heads-up so you guys/gals don't waste your time and money: I had my Megan SS headers ceramic coated by Jet Hot (1300 degree silver coating) and they started cracking and peeling after 2 weeks. Yeah they have a lifetime warranty, and I'm going to take them up on it, but it's a pain to swap them out, and what good is getting the same coating again if it's just going to crack in 2 weeks.
BTW, I'm running rich. (cold)
*EDIT* For the purposes of saving someone else the hassle, this applies to the 1300 degree coating. There are people on here who say the 1300 degree coating worked for them, it did not for me. Jet Hot's website says nothing (at the time of this writing) about turbo-specific applications, and they were aware that the part was going on a turbo-charged engine.
Old Dec 5, 2006, 01:43 PM
SlowCar's Avatar
when i did my senior year project for undergrad on quasicrystals in the late 90s, amazing thermal barrier. Back then, we had Ames lab @ Iowa state u plasma spray the stuff on for us. Wonder if anyone does it commercially now
Old Dec 5, 2006, 01:47 PM
bluebanana23's Avatar
I was told 1300F won't cut it due to the immense heat from being turbocharged. 2000F is def. the way to go.
Old Dec 5, 2006, 01:52 PM
SlowCar's Avatar
most of these "coatings" are painted on, sprayed on or dipped. Over time, interface delamination occurs and the film spalls off
Old Dec 5, 2006, 01:54 PM
Killboy's Avatar
I can understand that line of thought for parts AFTER the turbo, or the turbo itself, but I don't see how the header would get any hotter on a turbo-charged application than the header does on a non-turbo application.
Either way, they were aware that the part was going on a turbo-charged engine and did not say anything about the coating being insufficient.
Old Dec 5, 2006, 01:55 PM
Killboy's Avatar
In this case, the time being 2 weeks.
Old Dec 5, 2006, 02:00 PM
SlowCar's Avatar
its a science by itself to get a film to "stick" to a part under punishing conditions of rapid heating/cooling - stresses generated, rain........
good surface prep is of utmost importance, sand blasting to roughen to create "anchoring points"...grease free to lessen formations of brittle carbide phases.......not easy
Old Dec 5, 2006, 02:04 PM
articfury's Avatar
900C or 1650F are not uncommon EGTs (as read in the manifold) for turbo cars at WOT.
Just make sure they put the higher temp coating on and you should be fine. People have been using Jet Hot on parts very successfully for many, many years. Sometimes mistakes happen. As long as they take care of you, I wouldn't say that Jet Hot coating aren't recommended.
D
Old Dec 5, 2006, 02:12 PM
althemean's Avatar
agree 100%
Old Dec 5, 2006, 02:22 PM
BiFfMaN's Avatar
The DOE (department of energy) has been writing some papers on this subject:
Quote from paper: New quasicrystalline materials
capable of being sprayed using a high-velocity
oxygen-fuel (HVOF) process that produces denser
coatings with higher bond strengths.
I have also heard that they have done testing of this stuff on jet engine components. so might be awhile for the automotive world....
+1 on the 2000F+ coating and prep.
Old Dec 5, 2006, 02:43 PM
Cirrusly Evolvd's Avatar
You chose the wrong coating my friend so blame yourself. The manifold sees over 900 degrees during WOT. Jet-Hot probly Will Not warranty it due to it being a turbocharged header. They specifically recommend the Jet-Hot 2000 for all turbocharged exhaust parts.
I've had Jet-Hot on two different downpipes and currently have it on my AMS setup and it's the shizzle. No cracking, chipping or fading. And it's Jet-Hot 2000.
Old Dec 5, 2006, 03:16 PM
SlowCar's Avatar
kinetic energy does wonders, promotes implantation/compound formation/film densification thats essential for interface adhesion
Old Dec 5, 2006, 03:54 PM
Killboy's Avatar
Sorry to break it to ya, my friend, but there is NO mention of turbo application specifics on their "Coating Selector" page, or any of their pages that I can see.
Like I said, they were aware of the turbo application, and they recommended the coating I got. I even sand-blasted the part.
I'm glad their other coatings worked for you. It's too bad my experience offends you to the point you have to whip out the attitude. You could have just stated your experience without the back-handed remarks.
Old Dec 5, 2006, 04:00 PM
Sorry you got butt-hurt from my comments...good luck with your warranty.
Old Dec 5, 2006, 04:06 PM
Rutt's Avatar
Has anybody used the company QC Coatings?
Quick Reply: Jet-Hot - Not Recommended
