11.5lb Mini Battery for $60
#166
The Honda battery hit my AIT sensor....
I've been using a walmart 51 series honda battery for over a year now.
~450CCA 2yr warranty
-Stock battery tray cut to fit
-Drilled new holes to mount tie downs
-Reused tie downs, but cut the threads on one to make it shorter
-ebay honda battery tie down, $8 shipped
-works great with Muse UICP
#168
You can actually mount the battery on the stock tray. What I did with mine is I placed the battery on the tray on its side, drilled some holes in the tray on both sides of the battery and used a cheap adjustable battery tie-down from advance auto to hold it in place. Since it's an AGM battery it is safe to put it on its side. It has been that way for 5 years and still works fine right now, although in the winter I have some issues with cold starts so maybe time to replace it. Five years is a good run for a mini battery.
#170
What needs to be modified? if you dont mind sharing your secret, i have a buschur mini battery kit but need a new battery and was thinking of the EXT16; did you just have to use an air grinder or dremel to make adjustments or was it a pain? Thanks
honey on boost
Apr 26, 2013 08:32 AM
