Apr 9, 2007, 11:45 PM
Personal Sales Rating: ( 0)
Drives: 03' EVO8, 92' MR2 Turbo
Quote:
Originally Posted by JT-KGY
I listened more closely today.. really sounds from one of the pulleys or belt...
Thanks for verifying my evaluation.
__________________
03' EVOVIII - exhaust+meth+boost@25psi
92' MR2 TURBO - exhaust+boost@17psi
Offline
Apr 9, 2007, 11:47 PM
Personal Sales Rating: ( 3)
Quote:
Not 100% sure, of course..
How involved is it to replace/change the pulley/belts.. space is tight under the
hood..
__________________
FS: Amsoil Fluids for Evo engine, transaxle or diffs here
Offline
Apr 9, 2007, 11:51 PM
Drives: EVO9_gsr
I got that same noise, its just not as loud. started around 13k
http://www.youtube.com/watch?v=dAqYn8sOrOY
Anyone else got this noise?
Sounds like noise came from the belts
(or at least coming from that side of the engine).
Car/engine is stock... noise started around a week ago.
Only thing I think can of is that overfill the engine oil a little bit.
Offline
Apr 9, 2007, 11:58 PM
Drives: 2006 IX GG GSR
Okay, glad to know I'm not the only one with this going on...Seriously, mine started last week (cold weather may have something to do with it?)...After I'm moving, dissapears...I was concerned at my last auto-x, but didn't see any belt splits or loose pulleys...What can a guy do?...Are there any VIII guys out there experiencing this too?
Offline
Apr 10, 2007, 12:01 AM
Ya.. it's totally from the pulley/belt area...
or if from engine, the cam gears (?), but I doubt it...
__________________
Offline
Apr 10, 2007, 12:03 AM
hood..
The belts should be changed first. And yea, it is tight. But all side-mounted engines are.
If the noise doesn't go away - then try seeing if the crank pulley is causing the noise. It could also be the cam gear, or timing belt.
-M
__________________
Offline
Apr 10, 2007, 12:04 AM
Quote:
No noise here. 03' with 42k.
-M
__________________
Offline
Apr 10, 2007, 12:11 AM
Drives: 05 RS
damn I hear a lot of noises out of my rs but not like that at idle... until I check it tomorrow lmao g/l let us know if you get it figured out.
Offline
Apr 10, 2007, 12:19 AM
Personal Sales Rating: ( 10)
Drives: 2006 EVO IX MR, 06 gsxr 600
i got the same thing. i even made a thread about it. some random noise!! help
i have a vid on it too. check it out.
__________________
PSN ID: kdash106
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
Offline
Apr 22, 2007, 12:58 PM
Personal Sales Rating: ( 9)
Drives: Evolution IX - From home to work to school..
did you fnd out what is it?
i just hit 11K and my car does make a simmilar noise when the engine is warm and its been driven for a bit. I noticed that if i rev up a little at a light the sound get louder... also, I have some sort of vibration inside the car where the shifter is that is driving me crazy.. =(
Offline
Apr 22, 2007, 02:56 PM
Personal Sales Rating: ( 7)
Drives: 1996 Lexus SC300, 1996 Sebring Convertible
i've noticed this sound on a bunch of IXs including mine
it's been like that for awhile now so I am not too worried, will probably replace the belts around 30K miles anyway (my car's at 21K now)
__________________
2006 Evo IX (sold)
Offline
Apr 22, 2007, 06:04 PM
Drives: TB Evo IX
I have a similar noise, but more of a screeching sound from the same area. I can't notice anything looking at it. I keep meaning to take it to the dealer to check it out.
__________________
TB Evo IX
Cosworth IX Cams | HKS Cat-Back | DC Sports Downpipe w/Cat Delete | Megan O2 Housing | Forge UNOS MBC | Forge RS BOV | Nisei LICP, UICP, & Mini Battery Kit | ETS 3.5" Intercooler | Walbro 255lph | BR Intake | BR Ported Ex Manifold | BR Shifter Bushings | SS Clutch Line | ARP Headstuds | ACT HDSS Clutch | ACT Streetlite Flywheel | Swift Springs | Powerflex Front/Side Motor Mounts | Custom Tune by JustDSM
344whp 356wtq | 91 Oct | 23 psi
369whp 395wtq | 104 Oct | 27 psi
Offline
Apr 22, 2007, 06:12 PM
Personal Sales Rating: ( 1)
Drives: 05 Evo 8
05 evo 8, no sounds like that coming from my car besides the injectors ticking.
__________________
Megan 3" Catback
Megan Resonated testpipe
Works 3" Ceramic Coated DP
Walbro 255 FP
Hks Ssq Bov Recirc'd
Buschur Racing Filter Kit
@All work done by Hugh From BSM@
Road Tune Done By Sekula
Best time so far, 12.9 @ 108mph
Offline
Apr 22, 2007, 06:27 PM
Personal Sales Rating: ( 5)
Drives: all wheel drive is all well drive
mine does it too ive took it to warranty and they changed all the belt and looked every where but couldnt fined the problem i havnt lost any power or anything so mabe its just the mivec????
Offline
Apr 22, 2007, 06:28 PM
Quote:
only 9's
Offline
Tags
03, 600, belt, belts, bmw, engine, gsxr, idle, isnt, ix, m3, noise, sounds, squeal, tacoma  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
