TECH ARTICLE: 16g turbos and all its variants (20g)
#33
Wow this is a great resource, that you very much.
Just to check, you could buy a JDM 9 RS turbo and get it converted into a green correct?
This would give you the green compressor wheel with the TiAl turbine wheel?
That should help spool by a good amount.
#36
Dudi: The Green is really about reduced exhaust backpressure. The larger turbine wheel lets the engine breath better, thus improving exhaust scavenging. More better.
Although turbine mass is increased, and thus inertia, this doesn't hurt transient response significantly.
#39
also note that in japan the 9.8 was available in a single flapper but was a manufacturer's replacement item, it was never installed on any cars out of the factory.
trinydex
40
May 31, 2016 01:56 PM
trinydex
Mar 29, 2007 05:45 PM
trinydex
Mar 29, 2007 05:39 PM
