Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 22, 2007, 09:37 AM   #91
Personal Sales Rating: (0)
Drives: 03 EVO/ 99GSX
Quote:
Originally Posted by nos51 View Post
aem ems,we are running about 11.2-11.5 afr,timing i would have to look at the map but it is not very high.i believe at like 39 psi it is running like 4-5 degrees of timing.i am not sure on this though so dont qoute me on it.this is on torco 118
I run Torco 118NOS and have found that the cars generally like higher timing numbers with it to make the power. You should be able to run SOMEWHERE in the neighborhood of 15-19* up top.
If you are really only running 5* of timing then you may be shocked at what the hp difference would be. Do you have an EGT setup? I would be a little scared to know what the EGTs are at with so much boost and so little timing.
__________________
-Mike
DQ 1g: 9.39 at 157mph
DQ 2g: 10.46 at 143mph
DQ EVO 11.98 at 117mph
Offline
Old Aug 22, 2007, 09:40 AM   #92
Silver Sponsor
Personal Sales Rating: (6)
Drives: E39, R14, S14, EG coupe, F350
Send a message via AIM to Full-Race Geoff
another thing is we could not get the turbo to build boost past 40 psi no matter what.i tried a manuel boost controler and i even unplugged the vacum line to the wastegate to see how high it would go.it will not go past 40psi.so i think either i have a boost leak or maybe the turbo cant build past 40 psi which i doubt.
very interesting. from what you're saying i doubt its a boost leak.. post the dyno plot when you get home, ill go into more detail later tonite
Offline
Old Aug 22, 2007, 09:40 AM   #93
Silver Sponsor
Quote:
Originally Posted by mike 99gsx View Post
You should be able to run SOMEWHERE in the neighborhood of 15-19* up top. If you are really only running 5* of timing then you may be shocked at what the hp difference would be. Do you have an EGT setup? I would be a little scared to know what the EGTs are at with so much boost and so little timing.
^^^ what he said
Offline
Old Aug 22, 2007, 09:43 AM   #94
Personal Sales Rating: (27)
nos51's Avatar
Drives: 05 evo VIII,03 evo STREET WHORE
Send a message via AIM to nos51
yea that is true but again i am not sure of the timing values off the top of my head since i didnt tune the car.i would have to look at the map when i get home.
__________________
778hp,579tq,40psi billet 6265....built and tuned by me
Offline
Old Aug 22, 2007, 09:45 AM   #95
Personal Sales Rating: (5)
Drives: Evo VIII/SVO Mustang/BMW E30 M3
Whatever the .85 A/R TS hotside delivered, the 1.06 should do better, so that shouldn't be an issue.
The stock head is likely somewhat of a limiting factor, but I can't say to what extent. Logic implies that the greater the power potential, the more significant a limiting factor it would be.
I agree that the turbo isn't the problem. There is something else amiss. A pressure test is always a good first order of business.
What WG spring set are you using?
I agree that with only 5* of ignition advance, there is either power left on the table, or, if preignition was encountered near that point, there is something amiss that is aggravating the knock threshold. Again, make a pressure test to verify that you don't have a leak.
__________________
Ted B. Spec JAM LR 2.0L - Headway Perf CNC Head - DI Int Man - 75mm Hypertune TB - HTA3582 TS 1.06 A/R T4 - 12mm lift Billet Cams - MPFab TS T4 Manifold, TBE, UICP, LICP - MPFab FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1250cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Super Twin P-Trim Clutch
Offline
Old Aug 22, 2007, 09:57 AM   #96
nos51's Avatar
i am using a 19psi spring or springs rather.i am going to pressure test it but now that i think about it if i am correct on the timing which i think i am it would explain alot of things.i know my tuner was very conservitive.def power to gain there.i remeber on my old k20 turbo teg 2* of timing would give it like 30hp,but it was a 11.1 compression motor also.
you guys are a huge help,thats why i love evo m!!!
__________________
Offline
Old Sep 3, 2007, 10:44 AM   #97
electricevo's Avatar
Drives: '06 Evo IX SE, 04 STi (sold), electric evo (sold), lancer OZ (sold)
Saw this video testing a FP GT4094 produced 760whp 536tq. Its really hard to see the dyno graph, but it is posted.
Anyone know how much boost this evo was running?
http://videos.streetfire.net/video/d...90000a3c71.htm
__________________
400.5HP 384lb/ft @ 23psi 93 octane.
Offline
Old Sep 6, 2007, 12:25 AM   #98
riggs's Avatar
Drives: 98 RB26DET 240SX
Send a message via AIM to riggs
I just dynoed 629/490 on the GT4088R (.95 A/R) on E85 Pump Gas at 25 PSI last weekend.
It will do 700-725whp on C16, however I am not trying to max out this setup.
I have decided to go to a GT42 or GT45R, as I plan to drag race the car next year.
I paid $1800 for it back in June, and will take $1400 for it as it sits. It has approximately 500 miles on it, and is in perfect shape.
Offline
Tags
4202, 4294r, 750whp, dyno, ets, evo, evolutionm, gas, graphs, gt4088r, gt4094r, horsepower, power, pump, sale
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
