Manual Boost Controller vs. Electronic Boost Controller
I like the Hallman Evo kit - manual boost controller but you can adjust it in the cockpit - on ebay buy it now for like $135. In cab makes it easy to setup and looks sweet be sure to get it tuned and some gauges!!!
There is a full install how to on hallman's site.
here: http://www.hallmanboostcontroller.com/howto.html
i had a forge and didn't like it at all... its way to sensitive. every 3 degrees in change it needed adjustment to hold the same boost.
i now have the greddy profec b 2 and its great. not as sensitive, and even if i need to change it its super easy and fast.
do your own research and decied on your own. i listened to every1 else and followed what they said, wasted money and was unhappy for 3 months before i finally did something about it. very few people on here actually know there stuff
cheers!
cheers!
cheers!
i am using the forge boost controller and it works great just a little tapper in 3rd gear which seems normal/ I had the avcr and it sucked everyday was a different setting it always needed to be adjusted
