Official torque specs thread
Old Dec 22, 2006, 04:05 PM
kreionic's Avatar
great find dan
Old Dec 22, 2006, 04:19 PM
Yme
Yme's Avatar
This will def come in handy. Thanks for compiling the list
Old Dec 22, 2006, 04:23 PM
EvoDan2004's Avatar
no problem guys. just pm me what you know if you dont see it and i can add that to the list for the future for others.
Old Feb 12, 2007, 08:21 PM
EVOINVASION's Avatar
Thanks!
Old Feb 28, 2007, 04:25 AM
joeMama's Avatar
Does anybody have the specs for the rear differential? caps, yoke....etc.
Old Mar 1, 2007, 04:57 AM
joeMama's Avatar
*MODS PLEASE UPDATE*
REAR DIFFERENTIAL
Pinion Gear- 45ft lbs
Bearing Caps- 150ft lbs
Old Mar 7, 2007, 11:21 AM
rodman's Avatar
How about specs for the drain and fill plugs for tranny/T-case and rear diff?
Old Mar 28, 2007, 09:36 AM
ElectricEvoIX's Avatar
valve cover 31 (+/-4) inch pounds
I'm new to this but does that mean that the valve cover torque bolts need to be torqued to 31 lbs each?
Old Apr 20, 2007, 08:27 AM
truDriver's Avatar
Originally Posted by BlackTrack
Good Idea!
How much for the lugs?
evodan2004 posted this at the top: Tire lug nuts 98 ± 10 Nm (73 ± 7 ft-lb)
This is also in the owners manual
Old Apr 20, 2007, 08:30 AM
truDriver's Avatar
these threads may help for more suspension torque specs and diagrams
https://www.evolutionm.net/forums/sh...n+torque+specs
Old May 25, 2007, 12:42 PM
Guz Man's Avatar
good stuff dude.. thanks
Old Jul 26, 2007, 04:04 PM
ayS
ayS's Avatar
good stuff!
Old Jul 26, 2007, 04:17 PM
boostedwrx's Avatar
Yes and no... 31 inch/lbs is what it calls for and not foot/lbs. If you overtighten those valve cover bolts you have the chance of cracking your valve cover because it expands a little as it gets hot. Get an inch-lb torque wrench.
I use something like this, with a flex dial guage - http://www.toolsource.com/beamtype-t...b-p-71321.html
Old Jul 27, 2007, 06:40 AM
^ awesome man thanx for the info
Old Jul 27, 2007, 07:09 AM
derangedazn's Avatar
subscribed
Quick Reply: Official torque specs thread
