Wastegate vacuum line question
Old Jun 21, 2006, 07:37 PM
AutoEuphoria's Avatar
Hey guys,
I am having a little bit of a problem. After looking around at the vacuum lines to see how I should install my MBC (which will now go on the 7th of July right after I get my gauges installed) I noticed that the way my wastegate was connected was a little different than how the vacuum diagram on the underside of the hood shows.
First off, I am the 3rd owner of this car, and I did not personally do this...
That being said, I noticed that there was a vacuum line coming from the air intake hose that was connected directly to the wastegate. There was a "T" before the wastegate, but the other line coming off from the T had a bolt in it, blocking it off. I know that the CORRECT way was to have the line from the air intake hose to a boost control solenoid (which I cannot find...it's not on this car anymore), then to the wastegate and to a line on the turbo (which is also not connected anymore, and I CAN NOT find the nipple or whatever that is supposed to be there...I can not see it anywhere on the intake side of the turbo, and I've felt all the way around it, too).
So, in preparation for the new MBC I capped off the nipple on the air intake hose, then cut the line going to the blow-off valve, inserted a "T" and ran that directly to the wastegate.
Now, I just want to make sure that this will be OK until the 7th. I do not beat on my car, and usually only drive to work and back (5 miles). I did test it out once after I connected everything up again, and noticed I am getting noticeably less power than before. I remember reading somewhere that the stock wastegate has an 11psi spring, so I'm assuming that's all that I'm seeing...is this correct, or am I way off here?
Thanks for the insight
Tyler
Old Jun 21, 2006, 08:31 PM
evo150's Avatar
yes you are only seeing around 11psi if the lines are not installed correctly or your not using the stock vacum lines. here is a link i quickly found, within it has some drawings of the proper routing of stock lines as well as when you hook up the mbc.
https://www.evolutionm.net/forums/sh...ht=mbc+install
Old Jun 21, 2006, 09:00 PM
ok, that's what I thought...oh well, better than too much psi
Old Jun 21, 2006, 09:22 PM
evo150's Avatar
youll be loving your car all over again when you get the mbc installed and are back to 19.5 psi
Old Jun 21, 2006, 09:24 PM
I sure hope so...I'm getting a suspected exhaust leak fixed that day, too (in the turbo/manifold area) so hopefully it'll be even quicker.
fostytou
338
Nov 10, 2023 11:55 AM
Seth_Horton92
Feb 9, 2017 07:13 AM
Aux.
40
Aug 23, 2008 07:22 AM
meat_EVO
May 26, 2008 03:52 PM
projekt_shocker
Nov 6, 2006 09:01 PM
Quick Reply: Wastegate vacuum line question
