GT3076R owners, post your #'s.
#46
Originally Posted by Mercenary3
evoviiiyou runns a FP 3065, which I beleive is very similar. 30r turbine with larger compressor than the usual 3076R-12.
In any event, he has a Switzer custom setup, but its nasty. 3076-12 like spool putting out 540 whp with very mild cams.
#47
yeah i believe that gt3040(30r turbine, gt40 comp) is the same as the fp3065. this is what im looking for, but ive heard that its a mismatched turbo and that the 30r turbine cant flow the gt40comp well, but evoviiiyou has a nice set up!! so i dont know what to do. the other consideration is the 3076r with -13(not sure about the full specs and where it falls in the gt30r group). definitely looking for more help and info on these turbos. any recommendations?
#52
Someone had asked earlier about a 3076r with a stroker motor. I have this setup with a 2.4 4g64 and 3076, so it is quite comparable. I was limited to 20 psi due to my injectors, and we dynoed in 108 degree scorching weather; so the numbers aren't all that high; but it will give you guys a good idea how the turbo spools. Very broad powerband.
#53
I have the -13 GT30R and it is a sick pump gas turbo. On pump it will make over 400 whp DJ easily.
With racegas it will do 500 whp DJ without a problem.
However once you get to about 28-30 psi while the turbo will continue to make peak power but the power will fall off fast and has surge issues. For 500+whp I would pick a GT3040R.
#54
GT3076R on JUN 2.2L stroker, HKS 264 cams, 30 psi at 4400 RPM held. 98 RON (about 93 octane in the US). 100 deg F in the shade. Cylinder head is stock.
The new Nissan GTR does about 390 PS at wheels on this dyno.
#56
432 whp with a GT3076R, with HFS-5 at 28psi
but then my stock block decided to take a dump and put cylinder 1 out of commission.. so i will be doing a full block build, and put it again on the dyno and see where it gets me...
