Transmission failiure
stvbreal....your the guy...your description the other day was just the same as I was experiencing....on deceleration in 3rd gear at 3500rpm it sounds like a bearing noise or a loose heat shield
stvbreal -
I found my trans problem when I noticed a whine while decelerating through 3000 rpm. It only did it when the car was well warmed up - about 30 minutes of driving. It hasn't seen over 5k - never broken in - now i'm afraid it's fragile.
Originally posted by number13
stvbreal -
stvbreal -
limey -
nope - it's going to the dealer's on monday for bearings - just sitting in the driveway now
limey -
I'm still trying to figure out if the noise I am hearing is the same as what you guys are hearing. Mine just sounds more like a high RPM grinding noise, no whinning or whizzing, I think. Damnit ! ! I'm gonna get some audio after work and let you guys hear it if that's cool with ya'll.
Thats fine but the easiest way to tell is take it to the dealer to inspect the trans oil....he will put a magnet in the hole and presto....you will be able to visibly see you have a problem
It sounds the same, I don't mean to be negative here...thats three of us ...any more people experiencing the same trouble....somebody said a few days ago that thier evo trans sounds like an M3 trans....mine definately did not sound like an M3 trans....IMO
Originally posted by uranium9v
so is that 3 evo's with the same trans. problem?? This could be bad...How much metal was in with the fluid?
I have not seen yet....I heard through a phone call...will post later I am leaving for the dealer now
