Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory
Search
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Dec 26, 2005, 07:39 AM   #1
Personal Sales Rating: (2)
Garage is empty, add now
el producto's Avatar
Drives: a big boosted 4 banger
Question Cast Iron VS Aluminum BLOCKS
Is there any difference besides weight when it comes to these engine blocks.
I think I heard that the X will be an aluminum block, will it still be able to hold all the power that we give it??
__________________
HKS272s.Walbro.UNOS.ACTHD6PKSPRNG.UICP.LICP.TBE.Parlez vous, francais, mi amor, merci, oui oui, bon bons
and all that good stuff
Offline
Old Dec 26, 2005, 07:47 AM   #2
Personal Sales Rating: (7)
Drives: 06 GG Evo IX SE, 09 Mercedes ML 350
Send a message via AIM to PA-silver03evo
I read that too. I really dont like it as the cast iron block on the 4g63 has proven itself for such a long time. Why fix it if it isnt broke. I think it will be fine for anyone who does light modding but if you are planning on doing a lot, might want to stick with the evo 9. Not to mention the automatic trans with paddle shifting. I personally would wait and let other people do the testing before buying one to mod.
Offline
Old Dec 26, 2005, 07:59 AM   #3
Personal Sales Rating: (4)
thetox's Avatar
Drives: The Grand Rustle Mobile
Send a message via AIM to thetox
heat dissipation/retention is also different from aluminum to iron, with aluminum cooling down quicker
Offline
Old Dec 26, 2005, 08:02 AM   #4
Personal Sales Rating: (0)
x838nwy's Avatar
Drives: VIII MR
Well, I think Mitsu know the advantages of the cast iron block over the aluminium one. But the Al does have attractive qualities such as its ability to conduct heat better and being slightly cheaper to manufacture.
I'm sure if they do go that route, it's not going to be for no reason, but I think we will loose the ability to run our evo's at insane boost levels due to the decreased stiffness of the Al. [unless they use some really exotic alloys]
Strangely enough, the new Mazda Miata went from a 1.8l cast iron block to a 2.0l Al block. It lost only 5.4kg.
Offline
Old Dec 26, 2005, 10:45 AM   #5
Personal Sales Rating: (5)
purplegodzilla's Avatar
Drives: evo 9 mr
since when does aluminum cost less than iron?
Offline
Old Dec 26, 2005, 01:11 PM   #6
Personal Sales Rating: (90)
inco9nito99's Avatar
Drives: '08 CBR 600RR "Graffiti"/'99 Maroon GSX/SOLD: RR IX RS
Send a message via AIM to inco9nito99
Umm...aluminum IS cheaper than iron -it is more readily available. Secondly, aluminum tends to react to heat much faster in expansion/shrinkage. This usually is the cause of hairline cracks in the block..you have to remember, there is coolant flowing around the walls of the piston chamber. High heat dissapating from the friction off the piston walls on the insides of the chamber and cool coolant flowing outside of the chamber. I don't think they'll resort to using aluminum blocks and if they do in my opinion the motor wont be able to withstand an FI application with high hp for too long esp. being a DD.
__________________
◄◄◄ KUNiiiZZZEEE ►►►
...it's my NICKNAME!
"OCD isn't a disease..it's a lifestyle" -revvin9k
"...faith in KARMA" -me.
FS: Engine/Driveline/Turbo/Electronics:
http://forums.evolutionm.net/sale-en...ml#post9533241
Offline
Old Dec 26, 2005, 02:19 PM   #7
Personal Sales Rating: (10)
Boost Addict's Avatar
Drives: 05 Evolution
I really dont know about Aluminum being cheaper than Iron but what do I know. I do know that all aluminum blocks use iron sleaves so block integrity at high hp levels shouldnt be an issue.
__________________
"Thank You Chuck Norris"
Offline
Old Dec 26, 2005, 02:30 PM   #8
Drives: 1997 Eclipse GSX, 2004 Acura TSX, 1999 Mitsubishi Eclipse Spyder GST, 2004 Evo, 2005 Honda Accord V6 (fiances), 2005 G35 Coupe (fiances)
Aluminum Alloy is not even close to being as inexpensive as Iron...whoever even remotly thinks that is a baffling idiot. It can be cheaper to manufacture because its easier to work with, but no car company has elected to use Aluminum as a cost reduction technique.
Offline
Old Dec 26, 2005, 03:55 PM   #9
E. Haskell's Avatar
Drives: VIII
Aluminum can be repaired if damaged. It's not always weaker either.....look at the 4.6 Cobras that are running well over 1200hp with aluminum blocks.
Offline
Old Dec 26, 2005, 05:12 PM   #10
x838nwy's Avatar
Drives: VIII MR
Quote:
When you look at things like engine blocks, the majority of the cost comes from the machining operations rather than the material costs. If you look at it in the cast form the material cost is probably only 15% of the costs, in this case.
All in all, both materials should cost roughly the same to cast but this depends very much on the method chosen. But once you mass produce the part, the casting cost should not be a major issue.
The largest chunk of the cost is in machining and Al is much cheaper to machine. Another plus is the thermal conductivity of al means that you can have the cooling channels not so close to the surfaces which allows for shallower hole depths and larger tolerances all round. So machining cost will be reduced.
Going back to materials, if you look at how much al alloy coast per kg and how much an hour cost on a 3/4/5-axis CNC machining centre with gun drills, you'll get the picture.
Now I'm not saying that the cost saving will be the only reason why mitsu would switch, but it is one of the plus points. The reduction in engine block costs is probably not significant when you look at the selling price of the evo.
I do not know if car companies use al blocks as a cost reduction technique, and frankly I don't think I ever will since I do not sit in on their engineering meetings but I doubt they'd say in the brochure "we use al for the engine block to make it cheaper for us". As I mentioned, it is a plus point (if you don't include the cost of re-tooling) but not a major one.
Offline
Old Dec 26, 2005, 05:25 PM   #11
Personal Sales Rating: (1)
Mercenary3's Avatar
Drives: 2005 Evolution VIII
Quote:
The 03/04 cobras use an iron block, chief. Only the n/a cobras were running aluminum blocks.
Ive heard from several sources that Ford wanted to use an aluminum block on the upcomming 5.4L supercharged Shelby, but testing at production boost levels resulted in "catastrophic failures".
Offline
Old Dec 26, 2005, 06:42 PM   #12
E. Haskell's Avatar
Drives: VIII
Umm, notice I didn't specify 03/04 Cobras . The '96-'98 Cobras used aluminum and they are STRONG. Mihovitz is making 1500+hp with his block.
Another example is y2khawk(Harlan) who post on LS1tech, he traps 171mph @ 3350lbs and uses a stock LS1 block
Offline
Old Dec 26, 2005, 07:48 PM   #13
Mookie's Avatar
Drives: 2007 Coblat SS s/c
don't the new corvettes have aluminum blocks?
Offline
Old Dec 26, 2005, 08:05 PM   #14
E. Haskell's Avatar
Drives: VIII
yes
Offline
Old Dec 26, 2005, 08:35 PM   #15
EVOclub4's Avatar
Drives: wherever
is it true though that once you overheat it, you're f****? it gets all warped and stuff? not to the extreme but minor warping?
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
aluminium, aluminum, block, blocks, case, cast, cobra, cylinder, drag, durable, engine, evo, iron, strength, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
