Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Dec 21, 2005, 08:57 AM   #31
Personal Sales Rating: (10)
Fourdoor's Avatar
Drives: 2010 Ralliart Sportback.
You have been Stuck!
PM me when you think the useful comments have run out, and I will do a one time "clean up" and close the thread while leaving it stuck for all to see.
Keith
__________________
2010 Lancer Ralliart Sportback... From stock to modified as follows in less than a week!
Buschur Racing FMIC, upper IC pipe, and lower IC pipe with EVO X BOV. AMS cat back exhaust, mini battery kit, and MAF housing from EVO X,Buschur Air filter mounted to EVO X MAF housing. Forge WG actuator, Ultimate Racing high flow cat.
Triple gauge pod with Wide band A/F ratio and boost.
Offline
Old Dec 21, 2005, 09:24 AM   #32
Personal Sales Rating: (29)
DaWorstPlaya's Avatar
Drives: Thats MR to U!
Quote:
Originally Posted by Terry S
Interesting… Can any vendors in here who carry Ralliart parts give em a call and figure out if the Evo 7 ACD ECU might be compatable with the USDM ACD Evo’s? Thanks for the tip
Terry S
Z1auto sells the Ralliart ACD ECU upgrade, but it specifically says its not for US spec models
http://www.z1auto.com/prodmore.asp?m...gmt&prodid=137
Also, in layman's terms ACD exists to keep the behavior of the car predictable under different road conditions. To me this is what it means and feel free to correct me if I am wrong, when the coefficient of friction (mu) of the surface conditions go down (aka when the roads get slipperly), switching to gravel or snow progressively induces more understeer on the car during corner entry and mid-cornering.
This is because no car is setup to be perfectly balanced in handling in all road surface conditions. Usually a car that is setup to have neutral balance at the limit during dry road conditions will tend to oversteer as the road gets wet (slippery). There is no such thing as a car with neutral balance under all road conditions. But ACD tries to compensate for that .
If you have tried pushing your car during wet/gravel conditions with ACD set to tarmac or if you have an 03/04 EVO and pushed it during hard cornering under wet/gravel conditions, you know exactly what I am talking about. The car will oversteer like crazy (dangerous if you don't know how to handle it).
ACD does a lot more than just inducing more understeer it also tries to optimize grip during accleration. Its pretty obvious on how it accomplishes that with the info given above.
Goodjob!!! Terry S.
__________________
GTWorx-www.GTWorx.com
Jestrtuning-www.jestrtuning.com
Better slow in fast out, than fast in dead out!
Forza 3 Discussion: Click here
Forza 3 Racing League:Click here
FS: Misc suspension bushings: Click here
Offline
Old Dec 21, 2005, 12:32 PM   #33
Personal Sales Rating: (2)
mdosu's Avatar
Drives: an Apex Silver one
Send a message via AIM to mdosu
so, the Ralliart ACD ECU must interfere with other equipment on USspec cars. I has nothing to do with AYC. hmmm.
__________________
WTB - Front LSD, OEM or aftermarket, new or used.
ARC box, Zeal 10/10, RRE sway bar, Cusco rear bar, JDM MR DV, Zero-Lift front dam
Quote:
Originally Posted by SilverNine
OMG!!!!! i am going to either kill myself or sum1 else for me being so f_cking stupid!!! Blonde im SORRY but i DONT have Boardwalk!!!!
Offline
Old Dec 21, 2005, 01:14 PM   #34
Personal Sales Rating: (1)
Drives: '05 Evo RS
Send a message via AIM to M5150
http://www.lancerregister.com/showth...threadid=65880
Theres some info on the ACD ECU installed in a USA Evo. I think its possible to trick the ECU into thinking AYC is there, therefore allowing it to work.
Regards,
Max
Offline
Old Dec 21, 2005, 06:48 PM   #35
Terry S's Avatar
Drives: Cakeaters to the nazi death camps
Keith
Awesome, thanks Keith. I'm going to look into the Ralliart ECU thing a bit then i'll shoot you a pm to close and clean.
Thanks again to everyone for the kind words and keep the good info coming!
Terry S
__________________
The OT's resident Coffee Geek and Emperor of Pie
Quote:
Originally Posted by HobieKopek View Post
Terry S is right
Quote:
Originally Posted by Kurt View Post
pie is ****ing awesome.
Quote:
Originally Posted by Rin Tin Tin View Post
It puts the creamer on it's skin or else it gets the coffee bean again.
I used to think Terry S was gay. Turned out he was jue pie-curious.
Offline
Old Dec 21, 2005, 07:10 PM   #36
Silencer's Avatar
Drives: 03' Evolution VIII Tarmac Black, 03' Montero Sport XLS Silver, 98' Eclipse GST
"The ACD allows the differential to operate in more of a free state when steering movements are made. When turning, the wheels in the front have to travel a further distance than the wheels in the rear. This is because the wheels in the front travel using a larger turning radius than the rear wheels as you can see from this picture. (turning radius.gif) So in order for smooth turning, the center differential needs to become open to allow for the front set to turn at a different speed. If you were to leave the center differential locked, the wheels would skip and skid badly. (1) (3)"
Question: Given the front and rear have lsd's and work independent from one another, if the center diff becomes locked, how would the wheels possibly skip around corners when both the front and rear diffs slip. You could actually set up, by virtue of plates, and control which end slips (over/under steer) if the center was always locked. Doesn't Ralliart offer a center lsd replacement that fits the US 8? How does this fit in to the mix if all diffs have the ability to mechanically slip under pressure (cornering)?
Dave
__________________
#76 STU
Offline
Old Dec 22, 2005, 12:57 AM   #37
Fourdoor's Avatar
Dave
The slip action in the front and rear diff allow the wheels on the different sides to move at different speeds than each other without binding up and skipping around... but when BOTH front wheels are traveling a longer or shorter path than BOTH of the rear wheels you have a difference between the front and rear wheel speeds that has to be compensated for with a sliping action in the center differential.
I used a welded center differential on my Galant VR-4 and parking that car was an absolute pain in the @ss if any tight steering angels were involved. Binding and skittering happen at high speed.... at low speed such as parking the car it was more like binding and poping as the gears in the rear differential ring and pinion tried to self destruct.
Keith
__________________
Offline
Old Dec 22, 2005, 09:02 AM   #38
Silencer's Avatar
Keith
Slight as it may be, I understand how slow speed cornering would complicate a fixed mechanical center. High speed should mostly be absorbed by the tires, but I see you have done this already.
Thanks for your input.
Dave
__________________
#76 STU
Offline
Old Dec 22, 2005, 10:35 AM   #39
Dave
I don't think the center diff becomes completely locked but instead think of it as the center diff providing more clamping force under gravel and snow modes while still allowing some slip (LSD). Compared to the tarmac mode which immidiately opens up the center diff under braking and cornering. In gravel and snow modes the center diff stays clamped progressively longer allowing some slip. What is means is the car is more stable under braking going into the corner, longer in each mode. This is because the center diff is forcing the front and rear tires to have closer speeds under slippery conditions which translates to a more stable and predictable driving experience. Controlled understeer vs sudden oversteer ...
__________________
Offline
Old Dec 22, 2005, 02:28 PM   #40
superman105's Avatar
Drives: 05' Evo WW
Hey Mike1023
I have the same problem as you, but it only happens when the car is cold
if you find out more let me know
tks
Quote:
Originally Posted by mike1023
i like it a lot. but i have one comment maybe someone can help.
on this secstion saying
D. ACD unit fault – 3 solid lights
When your ACD unit has all three lights on at the same time (other than at startup), this means your car is reporting back to Mitsubishi headquarters that your warranty should be voided… Just kidding. As stated in your owners manual, this denotes some kind of error in the unit and it needs to be serviced. To service the ACD you need a very special, and very expensive tool from Mitsubishi. This tool is used to engage the ACD pump to bleed the lines. You may run into this issue if you are changing out your transfercase. (6)
well yes i been geting that but i have a small batt. and wondering if it is becasue of that. well i turn on car some times all 3 come on and sometimes no. and then if they do come on after 3sec car on. i drive and i just kill car and turn on again and its fine. so i dont see what is up with it. lol . is it the ACD fauling. or is it just the small batt not getting enought power on start up and giving it a fauild code.
Offline
Old Dec 23, 2005, 02:22 AM   #41
Personal Sales Rating: (11)
mike1023's Avatar
Drives: 05 Evo Blacker than blue
Send a message via AIM to mike1023
ya i know only happens on cold start ups thats why im beliving it is that. but i dont thinnk i will find out becasue if bring to deal they will void warrney. i have nothing left of the car. so i dont know how they will take it lol. i will see if my mancnic has the tool for the test. if so great if not not cool lol. i can always but the stock batt in and see but i bet anything it is from cold start. and note this only happens when it is like 20F out side and the batt volta is at like say 10 or so. so its hard for car to start up
Offline
Old Dec 27, 2005, 09:33 PM   #42
Personal Sales Rating: (0)
How does the ACD react to differences in lateral grip front to rear?
For example, using the same size tire with a different compound? Or using the same diameter tire but with different widths?
In other words, does the ACD clamp harder/sooner/longer in response to yaw (assuming the the steering wheel being turned)?
Great info by the way... very well organized!
Offline
Old Dec 30, 2005, 05:35 PM   #43
Boy this is a hard question to answer ... by using different tires on the front and rear. You are affecting the level of grip provided in the front and in the rear which will either induce more under or oversteer, depending on where the there is more grip and what the difference in grip level is between the front and rear tires.
ACD will still do what it is preprogramed to do depending on the mode it is set at (Tarmac, Gravel or Snow) and what you steering, braking and throttle inputs are, but the results might not be predictable .... the senario will just be different depending on the tires.
Eg: in Tarmac mode with grippier tires in the front, the car most likely will oversteer ... again depending also on surface conditions ... likewise using grippier tires in the rear will induce more understeer in every ACD mode.
__________________
Offline
Old Jan 10, 2006, 10:25 PM   #44
spoolinspyder's Avatar
nice, well thoughtout review. I guess i'll be using tarmac much more....
Offline
Old Feb 19, 2006, 03:44 PM   #45
Drives: '05 Electric Blue Pearl Evo 8
wow, nice write-up on ACD. Very helpful!
__________________
RMR cold air intake
Offline
Tags
2003, 2005, acd, active, bleed, differential, evo, evolution, evos, installing, mr, psi, pump, sale, usdm
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
