Quickie Oil change question.
After draining is it safe to dry crank the motor on a turbocharged car to get the oil from the valvetrain out? I remember shade tree mechanic did that on their oil change and then again that's a push rod engine
Better ideal just wait and drain to get most out? For the evo owners, how many quarts do you fill?
4.5L?
thanks,
4.5L?
thanks,
I would never recommend dry cranking the engine.
You are risking destroying your bearings at the cost of trying to get a little more dirty oil out of your engine. Definately not worth it. Just make sure to use a good quality oil, preferably synthetic and a good oil filter and all will be fine. I always recommend synthetic oil on a turbocharged car because the oil is put under a lot more stress from the increased heat.
Tagge
22
Dec 3, 2010 07:03 PM
