Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 21, 2005, 12:57 PM   #1
Personal Sales Rating: (23)
Drives: 450ZX, Slow Tundra, LS430
Send a message via AIM to SuperHatch
Evolution Drivetrain for Dummies
See attached and learn!!!!
- Steve
P.S. - You're Welcome in advance
__________________
I DO NOT ACCEPT PMs
"My life is a cup of sugar I borrowed before time began and forgot to return."
"For the message of the cross is foolishness to those who are perishing, but to us who are being saved it is the power of God."
I DO NOT ACCEPT PMs
Offline
Old Jul 21, 2005, 01:17 PM   #2
Personal Sales Rating: (0)
Drives: '97 Eclipse GSX
Quote:
- Steve
What is your definition of torque tube? Because I've always thought that a torque tube was something akin to a torque converter. In other words, fluid filled.
I think that the red shaft is purely an axle, isn't it? Especially since the driver's side axle has to slide through the space in the center of that red shaft.
__________________
Josh
'97 Eclipse GSX - Evo III Big 16G
Best 1/4mi 11.825 @ 117.55mph 1.676 60-ft
Best mph: 118.78 - 30psi of spiking fun!
Think your ECU reflash is optimized for your car? Learn how to tune your own car and really optimize it.
Offline
Old Jul 21, 2005, 01:18 PM   #3
I called it a torque tube because it's a tube that transmits torque. You could also call it a hollow axle.
- Steve
__________________
I DO NOT ACCEPT PMs
I DO NOT ACCEPT PMs
Offline
Old Jul 21, 2005, 01:40 PM   #4
PVD04's Avatar
Drives: 2003 BBY Evo8, 2009 Outback
Send a message via AIM to PVD04
Looks good. That should help almost anyone understand the layout of the transmission and transfer case. Good work.
-Paul
Offline
Old Jul 21, 2005, 01:50 PM   #5
Thanks
__________________
I DO NOT ACCEPT PMs
I DO NOT ACCEPT PMs
Offline
Old Jul 21, 2005, 01:59 PM   #6
Personal Sales Rating: (13)
KLancer1997's Avatar
Drives: 08 IS250AWD
Send a message via AIM to KLancer1997
Offline
Old Jul 21, 2005, 02:09 PM   #7
Personal Sales Rating: (11)
marksae's Avatar
Drives: 03 TB, 99 EK
Send a message via AIM to marksae
Nicely done. Now all you need to do is animate it.
Offline
Old Jul 21, 2005, 02:12 PM   #8
Former Vendor
Personal Sales Rating: (107)
Curt@MrLed's Avatar
Drives: www.
not bad, but im sure someone will have no0 clue what it is..
Offline
Old Jul 21, 2005, 02:15 PM   #9
Personal Sales Rating: (10)
Fourdoor's Avatar
Drives: 2010 Ralliart Sportback.
You just got stuck!
Great post
Keith
__________________
2010 Lancer Ralliart Sportback... From stock to modified as follows in less than a week!
Buschur Racing FMIC, upper IC pipe, and lower IC pipe with EVO X BOV. AMS cat back exhaust, mini battery kit, and MAF housing from EVO X,Buschur Air filter mounted to EVO X MAF housing. Forge WG actuator, Ultimate Racing high flow cat.
Triple gauge pod with Wide band A/F ratio and boost.
Offline
Old Jul 21, 2005, 04:16 PM   #10
WOOHOO, thanks!
__________________
I DO NOT ACCEPT PMs
I DO NOT ACCEPT PMs
Offline
Old Jul 28, 2005, 12:27 AM   #11
Personal Sales Rating: (1)
PunoEvo1337's Avatar
Drives: with a WOT
great stuff... this will come in handy
__________________
i <3 modding
Offline
Old Aug 23, 2005, 12:39 AM   #12
Personal Sales Rating: (2)
AznraceR's Avatar
Awsome! good info
__________________
im a perfectionist.... the edit button is my friend....
Tein Flex w/ EDFC, Cusco F&R strut brace, Cusco Twin Plate Carbon Kevlar Clutch and flywheel, SS Clutch line, Blitz TT/Boost Guage, Greddy BC, Greddy Catch Can, HKS dp, HKS hi power exaust, HKS Intake,HKS Circle Earth Ground Kit,UR test pipe,MR BOV, JESTERTuning Reflash M1
03' Evo Sold =(
03 G35 - Current
Offline
Old Aug 23, 2005, 12:45 AM   #13
Personal Sales Rating: (5)
Drives: '03 tarmac black evo 8
Send a message via AIM to ez76 Send a message via Yahoo to ez76
+1 guru point
Offline
Old Aug 23, 2005, 10:04 AM   #14
Personal Sales Rating: (3)
Drives: 03 TB Evo 8
ok i kinda get what's going on.... but my question is... when someone blows their TC... what exactly is blowing up??
Offline
Old Aug 29, 2005, 06:26 PM   #15
It depends, chances are if they blew it from an agressive launch (and the car is an 03 or 04 GSR w/ an open front diff, then they broke the 4 spider gears in the front differential. Those gears are made of a relatively weak powdered metal and break easily.
If the TC has an LSD or blew from low/no fluid, then they tore up the ring and pinion gears and the TC would first growl and howl, and then seize, or strip the teeth off. Same result either way, car won't go anymore.
Actually, theoretically the car could go if the teeth stripped off the ring or pinion, the center diff would also have to lock and the car would be FWD from that point on, but the chances of that happening are slim.
__________________
I DO NOT ACCEPT PMs
I DO NOT ACCEPT PMs
Offline
Tags
converters, diagram, drive, drivetrain, drivetrainfordummies, drivetrainv2pdf, dummies, eviolutions, evo, evolution, pinions, ring, saved, torque, train
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
