Gear ratios and MPH
Gear ratios and MPH
Tried searching but i couldnt find anything... How many MPH does 1st gear go up to when it is redlined? the same with 2nd? and so on? thanks guys
yes i think it is redline. as in when the needle hit 7k. but i dont think its for rev limiter.
for example i think the manual says 4th gears top speed is 110mph, but if u take it o the limiter u might get a few extra mph. but this also changes once u start modding the car also. but the owners manual should give u a good idea about how fast u can go per gear. other than that, go to the track or somewhere very very safe and see the max per gear.
wel i could tell u this......
a 4.111 longer gear ratio would give you these top speeds....and this is with normal redline at 7500rpm or whatever
1st 48Mph
2nd 69Mph
3rd 96Mph
4th 130Mph
5th 177Mph
dont know what it is stock though. u can check the manual for this
1st 48Mph
2nd 69Mph
3rd 96Mph
4th 130Mph
5th 177Mph
1st 48Mph
2nd 69Mph
3rd 96Mph
4th 130Mph
5th 177Mph
1st 48Mph
2nd 69Mph
3rd 96Mph
4th 130Mph
5th 177Mph
Originally Posted by Fourdoor
Using 7000 RPM as the refererance point:
1st = 40 mph
2nd = 60 mph
3rd = 83 mph
4th = 114 mph
5th = 163 mph
Keith
1st = 40 mph
2nd = 60 mph
3rd = 83 mph
4th = 114 mph
5th = 163 mph
Keith
First Gear
RPM MPH
2500 14.286
2600 14.857
2700 15.429
2800 16.000
2900 16.572
3000 17.143
3100 17.715
3200 18.286
3300 18.857
3400 19.429
3500 20.000
3600 20.572
3700 21.143
3800 21.715
3900 22.286
4000 22.857
4100 23.429
4200 24.000
4300 24.572
4400 25.143
4500 25.715
4600 26.286
4700 26.858
4800 27.429
4900 28.000
5000 28.572
5100 29.143
5200 29.715
5300 30.286
5400 30.858
5500 31.429
5600 32.000
5700 32.572
5800 33.143
5900 33.715
6000 34.286
6100 34.858
6200 35.429
6300 36.001
6400 36.572
6500 37.143
6600 37.715
6700 38.286
6800 38.858
6900 39.429
7000 40.001
7100 40.572
7200 41.143
7300 41.715
7400 42.286
7500 42.858
7600 43.429
7700 44.001
7800 44.572
RPM MPH
2500 14.286
2600 14.857
2700 15.429
2800 16.000
2900 16.572
3000 17.143
3100 17.715
3200 18.286
3300 18.857
3400 19.429
3500 20.000
3600 20.572
3700 21.143
3800 21.715
3900 22.286
4000 22.857
4100 23.429
4200 24.000
4300 24.572
4400 25.143
4500 25.715
4600 26.286
4700 26.858
4800 27.429
4900 28.000
5000 28.572
5100 29.143
5200 29.715
5300 30.286
5400 30.858
5500 31.429
5600 32.000
5700 32.572
5800 33.143
5900 33.715
6000 34.286
6100 34.858
6200 35.429
6300 36.001
6400 36.572
6500 37.143
6600 37.715
6700 38.286
6800 38.858
6900 39.429
7000 40.001
7100 40.572
7200 41.143
7300 41.715
7400 42.286
7500 42.858
7600 43.429
7700 44.001
7800 44.572
sumopower87 (Feb 28, 2024)
2nd Gear
RPM MPH
2500 21.451
2600 22.309
2700 23.167
2800 24.025
2900 24.883
3000 25.741
3100 26.599
3200 27.457
3300 28.315
3400 29.173
3500 30.031
3600 30.889
3700 31.747
3800 32.605
3900 33.463
4000 34.321
4100 35.179
4200 36.037
4300 36.895
4400 37.753
4500 38.612
4600 39.470
4700 40.328
4800 41.186
4900 42.044
5000 42.902
5100 43.760
5200 44.618
5300 45.476
5400 46.334
5500 47.192
5600 48.050
5700 48.908
5800 49.766
5900 50.624
6000 51.482
6100 52.340
6200 53.198
6300 54.056
6400 54.914
6500 55.772
6600 56.630
6700 57.488
6800 58.346
6900 59.204
7000 60.062
7100 60.920
7200 61.778
7300 62.636
7400 63.495
7500 64.353
7600 65.211
7700 66.069
7800 66.927
RPM MPH
2500 21.451
2600 22.309
2700 23.167
2800 24.025
2900 24.883
3000 25.741
3100 26.599
3200 27.457
3300 28.315
3400 29.173
3500 30.031
3600 30.889
3700 31.747
3800 32.605
3900 33.463
4000 34.321
4100 35.179
4200 36.037
4300 36.895
4400 37.753
4500 38.612
4600 39.470
4700 40.328
4800 41.186
4900 42.044
5000 42.902
5100 43.760
5200 44.618
5300 45.476
5400 46.334
5500 47.192
5600 48.050
5700 48.908
5800 49.766
5900 50.624
6000 51.482
6100 52.340
6200 53.198
6300 54.056
6400 54.914
6500 55.772
6600 56.630
6700 57.488
6800 58.346
6900 59.204
7000 60.062
7100 60.920
7200 61.778
7300 62.636
7400 63.495
7500 64.353
7600 65.211
7700 66.069
7800 66.927
3rd Gear
RPM MPH
2500 29.729
2600 30.918
2700 32.108
2800 33.297
2900 34.486
3000 35.675
3100 36.864
3200 38.054
3300 39.243
3400 40.432
3500 41.621
3600 42.810
3700 43.999
3800 45.189
3900 46.378
4000 47.567
4100 48.756
4200 49.945
4300 51.134
4400 52.324
4500 53.513
4600 54.702
4700 55.891
4800 57.080
4900 58.269
5000 59.459
5100 60.648
5200 61.837
5300 63.026
5400 64.215
5500 65.405
5600 66.594
5700 67.783
5800 68.972
5900 70.161
6000 71.350
6100 72.540
6200 73.729
6300 74.918
6400 76.107
6500 77.296
6600 78.485
6700 79.675
6800 80.864
6900 82.053
7000 83.242
7100 84.431
7200 85.620
7300 86.810
7400 87.999
7500 89.188
7600 90.377
7700 91.566
7800 92.755
RPM MPH
2500 29.729
2600 30.918
2700 32.108
2800 33.297
2900 34.486
3000 35.675
3100 36.864
3200 38.054
3300 39.243
3400 40.432
3500 41.621
3600 42.810
3700 43.999
3800 45.189
3900 46.378
4000 47.567
4100 48.756
4200 49.945
4300 51.134
4400 52.324
4500 53.513
4600 54.702
4700 55.891
4800 57.080
4900 58.269
5000 59.459
5100 60.648
5200 61.837
5300 63.026
5400 64.215
5500 65.405
5600 66.594
5700 67.783
5800 68.972
5900 70.161
6000 71.350
6100 72.540
6200 73.729
6300 74.918
6400 76.107
6500 77.296
6600 78.485
6700 79.675
6800 80.864
6900 82.053
7000 83.242
7100 84.431
7200 85.620
7300 86.810
7400 87.999
7500 89.188
7600 90.377
7700 91.566
7800 92.755
4th Gear
RPM MPH
2500 40.571
2600 42.194
2700 43.817
2800 45.440
2900 47.063
3000 48.686
3100 50.309
3200 51.931
3300 53.554
3400 55.177
3500 56.800
3600 58.423
3700 60.046
3800 61.669
3900 63.291
4000 64.914
4100 66.537
4200 68.160
4300 69.783
4400 71.406
4500 73.029
4600 74.651
4700 76.274
4800 77.897
4900 79.520
5000 81.143
5100 82.766
5200 84.389
5300 86.011
5400 87.634
5500 89.257
5600 90.880
5700 92.503
5800 94.126
5900 95.749
6000 97.371
6100 98.994
6200 100.617
6300 102.240
6400 103.863
6500 105.486
6600 107.109
6700 108.731
6800 110.354
6900 111.977
7000 113.600
7100 115.223
7200 116.846
7300 118.469
7400 120.091
7500 121.714
7600 123.337
7700 124.960
7800 126.583
RPM MPH
2500 40.571
2600 42.194
2700 43.817
2800 45.440
2900 47.063
3000 48.686
3100 50.309
3200 51.931
3300 53.554
3400 55.177
3500 56.800
3600 58.423
3700 60.046
3800 61.669
3900 63.291
4000 64.914
4100 66.537
4200 68.160
4300 69.783
4400 71.406
4500 73.029
4600 74.651
4700 76.274
4800 77.897
4900 79.520
5000 81.143
5100 82.766
5200 84.389
5300 86.011
5400 87.634
5500 89.257
5600 90.880
5700 92.503
5800 94.126
5900 95.749
6000 97.371
6100 98.994
6200 100.617
6300 102.240
6400 103.863
6500 105.486
6600 107.109
6700 108.731
6800 110.354
6900 111.977
7000 113.600
7100 115.223
7200 116.846
7300 118.469
7400 120.091
7500 121.714
7600 123.337
7700 124.960
7800 126.583
