Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 14, 2007, 06:32 PM   #31
Personal Sales Rating: (0)
bsander23's Avatar
Drives: 03 Evo 8 (silver)
so is it possible to reverse the rough idle after the cams are already installed? I was told you cannot since they are hydraulic........not sure why that would matter, but then again, I am a newb....
__________________
O,O,O,OH SNAP!!
2003 Evo 8, HKS 272 cams, HKS cb, cat delete, helix dp, AEM intake, walboro 255 fp, custom dynotune reflash, Megan manifold, more to come......
"I am a hot little potato right now!!"
Look out for the 10,000+ posters, they probably have no lives..
Offline
Old Sep 26, 2007, 03:41 PM   #32
hey
Sort of noob here, I have a weird head tick that i just cant find where its coming from! You can hear the tick once warmed up, there's a slight tick at idle. You hear the tick once you let offf the throttle(on decelleration) stops ticking once the rpms go under 2500 but then you can hear again at idle. Could this be a lifter? i do have hks 272 cams and adjustable cam gears. I DID PRIME THE LIFTER DURING INSTALL. The tick slowly came out of nowhere after some time, and aventually got a little louder.
Offline
Old Oct 11, 2007, 10:45 AM   #33
Drives: toyota
to get the lifters out u got to take the head out also or no???
Offline
Old Oct 11, 2007, 10:04 PM   #34
nightwalker's Avatar
Drives: 1986 Chevy Silverado, 1989 240sx, 2003 EVO VIII, 1992 Integra
they're under the cams. They just come off. Literally. You just lift them off, so be careful.
As for the ticking, I would rebleed the lifters. Dirty oil can also cause lifter tick.
__________________
Owning an Evo means ruining your life for all other cars.
Offline
Old Nov 8, 2007, 09:25 PM   #35
Drives: Evo 7
Lucky i read this coz im installing 272/272 hks cams real soon
Offline
Old Nov 13, 2007, 02:54 PM   #36
Personal Sales Rating: (8)
Drives: goggles and a speedo
For me the 50,000 mile lifter tick was solved by performing the diesel fuel wash procedure per FSM. Use three consecutive washes in clean solvent then keep them filled up when you stick them back in.
No ticking since then - been about 9000 miles
Offline
Old Nov 25, 2007, 01:54 PM   #37
Personal Sales Rating: (4)
Thoe99's Avatar
Drives: '03 Lancer Evolution 8
I installed a set of GSC S1 cams over a week ago, didn't bleed the lifters, and I'm not getting a tapping noise. I guess I'm lucky?
__________________
CarDomain pics
Mods: GSC S1 cams, QTP 3" electric cutout downpipe, Hallman Pro MBC @22psi, Walbro 255 fuel pump, Vibrant cone air filter, Nisei LICP, custom self-tune, RobiSpec KW Club Sports, 18x9½+40 Enkei NTO3-M, 285/30/18 Yokohama Neova AD08
Offline
Old Dec 13, 2007, 08:15 AM   #38
njvlllrs's Avatar
Drives: everyone f*ckin crazy ...
Send a message via AIM to njvlllrs
also I am curious if adjustable cam gears are needed when installing comp 272s.... about to do the install just want to know if I should get some... figured you would be the people to ask..
Offline
Old Dec 18, 2007, 11:56 AM   #39
Personal Sales Rating: (17)
steadly2004's Avatar
Drives: dodge Stratus turbo
Send a message via Yahoo to steadly2004
Quote:
Originally Posted by bounthai View Post
how do u bleed the lifters?
Did you read the thread posted first?
Quote:
Originally Posted by timzcat View Post
Remove the lifter from the head and insert a "pin" in the center bore. Most use a paper clip to do this. I used a cdrom drive ejector tool if you ever seen one. I think a small allen wrench would work well too since it stiffer. We are talking a 1/16th allen wrench or the larger size paper clip.
Put the pin down through the top of lifter and apply a small amount of pressure to unseat the check ball in the lifter. You'll know you have it cause you can immediately start to move the top of the lifter in. Pump the the piston in and out with the pin in place until you can do it without the pin. Basically when you unseat it and push on the piston you are going to be pushing oil out so be careful because if you do it fast you will shoot oil out of the lifter.
Easiest thing I found was to hold the lifter in one hand.
Put the pin in the lifter until it is all the way in. Use your thumb and forefinger to pinch the pin really close to the piston. Now push the pin in and at the same time your fingers will be meeting the piston so you can push it in and out while holding the pin in place. It's not very difficult to do, harder to explain. First one your kind of like wtf but then you figure it out and they are easy.
Offline
Old Dec 25, 2007, 06:58 PM   #40
Personal Sales Rating: (16)
Jack_of_Trades's Avatar
Drives: '03 evo VIII BBY(sold!), '95 Talon ESI-Turbo'd, '90 Mirage 4g63
Good thread to have around.
__________________
New VDR 5.71 Launched on 9/04/2009!! Now can be used for ANY vehicle, presets for all Evo 7,8,9,10 models!
CLICK HERE TO DOWNLOAD 'Virtual Dyno Room v5.71' !
'90 Mirage hatchback 4g63 and Evo8 ECU powered!
VDR 5.71 (EvoM Mode)=300whp/268wtq (thru stock 1.5" exhaust!)
'03 BBY Evo 8 (sold)
VDR 5.71 (EvoM Mode)=339whp/335wtq
Best 1/4 Mile: 12.2@113mph
'95 Eagle Talon non-turbo ATX......turbo'd
Best 1/4 Mile: 13.99@101mph
Offline
Old Dec 28, 2007, 03:19 AM   #41
Drives: EVO 8 RED
Hi Guys,
I dont know which combination to get. 262/272 cams or 272/272 (both HKS)? Whats the difference? Please help me out.
My car is an evo 8 stock turbo with HKS rs kit and HKS intercooler kit.
Thanks
Offline
Old Jan 15, 2008, 04:15 PM   #42
Personal Sales Rating: (1)
xtremeIX's Avatar
Drives: Toyota Pickup
I recently installed a set of GSC S1 Cams and followed this post for bleeding the lifters. When I started the car for the first time the lifters I still heard the ticking. After I took the car for a 15 minute drive the ticking went away and everything is working great.
__________________
FP Green, RC750cc, UICP, LICP, 02 Housing, GSC S1's, Ported Exhaust Manifold, 3" exhaust, 3"downpipe, 3" test pipe, Intake, NLTS, HFS-1, Tuned by Tuning Technologies (wouldn't recommend).
91 Map: 346whp | 315wtq
Water/Meth Map: 410whp | 371wtq
GO ROBISPEC///
Offline
Old Jan 15, 2008, 04:31 PM   #43
Quote:
I followed it and bled mine as well and had the tick. Having the tick is good to hear after the install IMO, that means the lifters aren't over extended and you won't damage anything during initial use (driving like that all the time isn't good though). Once the lifters fill up with the proper amount of oil to take up the slack they will adjusted perfectly for the new cams. Doing the 3000rpm trick stopped the noise after 5-8 times for me. This helps increase the oil pressure so it reaches the lifters a lot easier while forcing the lifters to open and close to their maximum length.
Quiet as a mouse.
__________________
Offline
Old Feb 21, 2008, 11:07 AM   #44
undeadmonk's Avatar
Drives: evo 9
some good infor, i install with a friend and don't do the bleed part but is all find
__________________
Steathy is Healthy 343 whp on stock 9 turbo.... next plan is Fp green.
Offline
Old Feb 24, 2008, 09:35 PM   #45
Rob#2's Avatar
Drives: Evo 9
How many if you drove around for a while without getting tuned?
Thanks Timzcat for posting this even if it was out of frustration
Offline
Tags
03, 1200, 2004, 4g63, cam, camshaft, civic, escalade, evo, hks, install, installation, noise, tapping, wrx
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
