Jul 24, 2006, 08:04 PM
Personal Sales Rating: ( 0)
Drives: E92 335, E65 750
Try clicking that link in the first post and reading a little.
__________________
Born to lose and destined to fail
Offline
Aug 19, 2006, 01:08 PM
Drives: 05 RS
Thanks for the head's up.
__________________
05 RS
94 Supra TT 6 spd
91 MR2 Turbo hardtop
Offline
Aug 21, 2006, 05:44 PM
Drives: WRX STI RA, EVO 8 MR
Very useful info. Thanks. Just finished my 272in 264ex install. No probs at all. No noisey lifters. Found a small allen key was ideal for bleeding the lifters. As advised, the first one feels a bit weird while you work out what is going on, but from there its fine.
__________________
I wish my girlfriend was as hardcore as my EVO
Offline
Sep 17, 2006, 09:54 AM
Personal Sales Rating: ( 13)
Drives: WW Evo IX Buschur Race car. 97 GTi VR6T, self built and tuned. 98 Jetta VR6 DD.
I didn't want to start a new thread, so I will ask here.
To everyone doing your install at home... How important is the tentioner tool? and I also read that it is normal for the crank to not be in time with the cams  (a few degree's off BTDC)
I am only doing the exhaust cam... I am worried about the timing marks and this tentioner tool that I don't have.  Is there something else you guys are using in place of this?
Please help out a fellow Evo brotha
Offline
Oct 2, 2006, 03:12 PM
Personal Sales Rating: ( 6)
Drives: 03 tarmac black evo
thanks for posting that. hope everyone reads it first
Offline
Oct 2, 2006, 05:16 PM
Personal Sales Rating: ( 1)
Drives: 04 white EVO,93 awd TSi
u have to have the tool or take the belt completely off. One or the other. My DSM has the crank a lil lil bit off the exact mark. but if u try one tooth either way then its way off. So u should get the point. Look at it first and make sure its int he same spot afterward, mark it with touch up paint if u have to.
__________________
Buschur Built: JE/Crower,stg 3 head, BF272s, 1K PTEs double pumper, tubular 82mm HTA with a.63 housing, newly installed BR Race Core.
480whp unfiltered BR MD Dyno, 544 whp Dynojet STD correction, 3rd gear, 31 psi, Stock ECU and MAF. Straight Shell 93 pump.
Currently running 94170015 V5.10 with SD Patch(Omni 4BAR) 531 whp 406 tq 4th gear, 519 386 3rd, CBRDs MD 33 psi straight pump Shell 93 Self Tuned
Offline
Nov 9, 2006, 10:01 PM
Drives: Evolution IX
can somebody tell me what the size of the stock evo 9 cams are? I got a 264 ex from a friend and wondered if it was worth installing; or whether I should just buy a 272?
Offline
Nov 27, 2006, 12:35 AM
I did the DIY tool using threaded rod and 2 nuts locked together. I wouldn't recommend it. I was lucky and it worked ok... but the threaded rod was bent when it came out so I was lucky it didnt break.
Also a nice idea is to mark the belt and your cam gears with white paint to ensure you dont slip a tooth.
__________________
Offline
Jan 9, 2007, 07:24 AM
Drives: 2006 Black EVO IX
ahhhhhhhhhhh
Offline
Feb 28, 2007, 03:54 AM
Personal Sales Rating: ( 38)
Drives: a soon to be built FORCE-FED PERFORMANCE beast...
I have done a few of these now from my garage and a tensioner tool (real one, not a knock off home made) is damn near a necessity. I wouldn't recommend doing a cam install otherwise. marking the cam gears and belt work the best and interchanging to new ones one at a time. Evo Moto tech install tips are awesome, follow them to a "T". Good luck everyone.
Offline
Mar 13, 2007, 07:50 PM
Drives: Lancer Evolution X MR
anybody else installing cams please read this thread:
Diesel fuel inside the OEM lifters???
__________________
STOCK EVO X MR WW
Offline
Mar 13, 2007, 07:52 PM
Personal Sales Rating: ( 20)
Drives: Evo VIII
definately good data to know....thanks
__________________
Airborne
Offline
Mar 17, 2007, 06:04 AM
Personal Sales Rating: ( 24)
Drives: Wicked White GSR
yep.. read it all like 5 times.. lol.. doing cams soon.. tryijng to know as much as i can
Offline
Mar 31, 2007, 05:26 PM
Personal Sales Rating: ( 17)
Drives: 03 Lancer Evo-8, 01 Toyota Highlander, 08 Jetta 2.0T
For those needing a visual on how to bleed 4G63 lifters watch this......
http://www.youtube.com/watch?v=gKX2pYVO0Ak
Offline
May 17, 2007, 01:26 AM
Drives: 03 Evo 8 (silver)
dang it, wish the mechanic that did mine knew what he was doing. mines bounces all over from 500-1000 at idle. Guess I could think about taking it in the have it bled down....shouldn't cost much to do
__________________
O,O,O,OH SNAP!!
2003 Evo 8, HKS 272 cams, HKS cb, cat delete, helix dp, AEM intake, walboro 255 fp, custom dynotune reflash, Megan manifold, more to come......
"I am a hot little potato right now!!"
Look out for the 10,000+ posters, they probably have no lives..
Offline
Tags
03, 1200, 2004, 4g63, cam, camshaft, civic, escalade, evo, hks, install, installation, noise, tapping, wrx  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
