Apr 24, 2005, 12:41 PM
Personal Sales Rating: ( 4)
Drives: Graphite Grey MR
Tapping after CAM install
Just installed HKS 272/272 Cams with Fidanza cam gears set at -4 intake/ -1 exhaust, and I am getting a loud tapping. Sounds like the lifters. I thought it was the lifters not having enough pressure, but I waited for 10 minutes and it's still tapping. Can anyone shed light on the situation, please?
Offline
Apr 24, 2005, 01:04 PM
I think that the oil pressure dropped from the lifters. While installing the cams I left them sit overnight without completing the install. Seems like the lifters don't have any pressure. Will running the car build the pressure to the lifters, and get rid of the noise?
Offline
Apr 24, 2005, 01:27 PM
Personal Sales Rating: ( 27)
Drives: Ev-Oh
is your timing all correct 2 ?
Offline
Apr 24, 2005, 01:36 PM
Personal Sales Rating: ( 36)
Drives: 04 RS and 08 GSR
Did you just let it idle for 10 minutes, or are you revving it up a bit and varying the RPM? I get a little tapping after my cam install and it goes away once the car warms up, but it goes away a lot slower if the warm up is just the car sitting at idle.
__________________
RichJ
2004 RS - FP Black, BR 2.0/stg3 head/BF272s, stock ECU w/SD
2008 GSR - stock
Offline
Apr 24, 2005, 01:50 PM
Personal Sales Rating: ( 10)
Drives: gt35r evo @ 35psi daily!
make sure everything lines up and go drive it around for a little bit. it takes some oil pressure to fill them up, and idle oil pressure isn't enough. my 264/272 combo ticked pretty loud at first too.
Offline
Apr 24, 2005, 03:44 PM
Personal Sales Rating: ( 24)
Drives: 03 BBY
Are you sure that the cam sensor is not 180 degrees out? It can go 2 ways but only one is right!
__________________
Most sports use one ball. Racing requires two!
Offline
Apr 24, 2005, 03:51 PM
Personal Sales Rating: ( 2)
Drives: 1995 Honda Civic (ej1)
I get the same thing. It's a loud ticking while I idle. once I bring the rpms up over idle it pretty much goes away after about 1200-1500 rpms.
-chad-
__________________
Daily Driver 1995 Honda Civic ex coupe:
Mod: Aebs Sleeved 2.0 liter LS/Vtec-RLZ built b16 Head.
Inline Pro manifold, SC6152e.
Built and tuned By RLZenginering
22psi 548whp (on Sonoco 114)
6.9@109 (RLZ driving)
10.52@139 (RLZ driving)
My best
7.3@104 (crappy back woods 1/8th mile)
1/4mile times.. Soon to come..
SOLD 2003 Rally Red Evo V///
Current mods:Vishnu Stage 1+(equivalent) tuned by Dyno4mance
305.6whp (dynodynamics) 93oct
Offline
Apr 24, 2005, 03:58 PM
Quote:
Did you bleed the lifters before re-assembly?
This is a must or the lifters will be damaged by the higher lift cam and the lifters fully extending when the cams are removed.
Offline
Apr 24, 2005, 03:59 PM
Former Vendor
Personal Sales Rating: ( 107)
Drives: www.
why does it seem that the stock lifters cannot handle these higher lifts at lower rpm... i have built many v8 with 280 dur. 580. lift and still used stock lifters. and never had a prob... maybe its a dsm thing... or is it the interference with the valve seals causing the ticking.. i wonder if anyone still has the ticking when changing the springs say going to ferrera, or revolver.. malibu jack where you at.. he has the revolver springs...
Offline
Apr 24, 2005, 04:02 PM
Former Vendor
Drives: www.
even ohc audi motors never had this prob.. i never bled the lifters.. on v8's i only pumped them full of oil, just a couple squirts.. just me wondering why this is happening...
Offline
Apr 24, 2005, 04:09 PM
Drives: C63
ITS THE LIFTERS I HAVE THE SAME THING with my 264's
Offline
Apr 24, 2005, 04:16 PM
Okay to be clear, if you remove the stock cams and reinstall them you will get ticking.
The design of the lash adjusters does not allow them to collapse like older style lifters. All lash adjusters must be bled before being reinstalled or they will make noise and most likely 1 or 2 will end up blowing their internal seals and collapsing. They will quiet up with RPM because the oil pressure will pump them back up but at idle they will collapse again. This is happening over and over again on here because no one is bleeding the lifters. I wish evomoto.com would change their install guide to include this since everyone is following it.
Offline
Apr 24, 2005, 04:18 PM
Former Vendor
Drives: www.
thank you..
Offline
Apr 24, 2005, 04:23 PM
i bled all my lifters and still get the tick after idleing for a while.
Offline
Apr 24, 2005, 04:24 PM
Personal Sales Rating: ( 17)
Drives: 03 E8 BBY-BBK, 08 RAV4/Sport/V6
How do you explain the heat cycle ticking? Silent when cold , intake side tick when warming up and silent when at operating temp?
__________________
BBK-Full on E85|Perrin 3 port|HKS 264/272|FIC1050|AMS ic-lip|Works TBE|
www.reflexracing.net
Offline
Tags
264, 272, bleed, cam, cams, eclipse, evoution, gsc, hks, install, intake, lifter, procedure, tick, ticking  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
