car losing power at 3000 rpm and above??? HELP!
this has been happening for about a week or 2 now. i figured it was just the spark plugs(have 12,500 miles and i figured that's a lot for a turbo cars spark plugs) so i replaced the spark plugs with denzo (not sure of part number). but today i was driving to work in a 65 i was going 70 which put me around about 3000 rpms i think. anyway, it started again. even after the plugs. also my SAFC says that the mass air flow sensor isn't pulling as much air when this starts to happen. oh! and when it starts to happen i can just take my foot off the gas and re-apply about 3 seconds later and it's fine for about 15 seconds. anyway, my next guess is maybe it's the coil pack/packs... but if you have any advice i'd really appreciate it.
Ben
Ben
Originally Posted by JoeWalker4G63
Check your IC piping. Wouldn't the misfire send a CEL? Do you have a CEL? To me the symptoms match that of a leaky IC pipe.
i took my friend for a ride in it last night who is much more knowledgeable about cars and motors than i am and he said that it may be the fuel pump or filter that is making it run lean since it only happens at higher RPMs. He said something about if the fuel pump can't keep up (because it went bad as walboro pumps do sometimes) it could make the motor run lean which would make the ecu pull timing which would be the reason (i forgot to tell you guys about this) i'm getting really high EGT readings. but i'll try the IC pipes first. that'll be a lot easier than putting my stock fuel pump back in.
list of mods:
hks intake
hks exhaust and downpipe
perrin cat delete (could be the reason for the CEL) (i do have resistor in tho)
apexi SAFC
dynoflash mail in
SSAUTOCHROME exhaust mani and turbo outlet
hallman MBC
PWR radiator
i think thats it....
sorry for the long post... but thanks again for everyones help
Ben
You say the CEL was on before...
Do you have the code pulled yet? Your local PEP BOYS, Auto zone or similar will pull these for free and you don't have to see the dreaded dealership!
Once you have that let us or anyone here know. It will seriously narrow down your search. Also, you said you have the PERRIN™ Off-Road Pipe. What happened to the CEL fix that was included? You mention a resistor and that may not be adequate to fight the P0420 code.
Let us know how we may be able to help!
PERRIN Performance
tech@perrinperformance.com
PERRIN Performance
PERRIN Performance
PERRIN Performance
Ben
kikiboi
12
Jul 6, 2007 12:49 PM
