hid ballast wiring
hid ballast wiring
Hey guys, i posted this in general but realised its probably better in this forum.
so I was sold a ballast but the seller didnt tell me the wire had been cut and now I need the d2s connector for the bulb , will any ebay d2s connector be able to replace it?
http://m.ebay.com.au/itm/321230071545?cmd=VISPEC
Something like this? I know the connecting end to the ballast is wrong but was thinking of chopping the head and using whats left of the existing wiring on the ballast I got.
Cheers
Cheers
As long as it connects to the bulb ok, it should work.
But be careful - the wiring between the bulb and ballast is high voltage, and not something you can just extend with some cheapo walmart wiring and a couple crimp connectors. The wiring doesn't need to carry a lot of current (thin gauge wire), but needs very good insulation...since yours is probably cut you'll probably see that yours is the wire inside a separate sleeve.
Solder and a bunch of heat shrink is probably your best option.
Sounds like you got hosed though. Bummer.
Ok, Ive got a sleeve feom my busted up headlights still intact and I will use that to cover them up , I been searching for weeks and finally got an answer ! Thanks heaps!
SSMCL9
Nov 5, 2015 08:26 AM
gjgfrombigd
65
Jan 10, 2010 04:58 PM
StevenStarke
14
Jan 19, 2009 09:35 PM
