Tscomp tuned Evo 8 W/ 9 turbo on 93 393whp/385wtq
Tom from Tscomp did it again. I will always recommend him to anyone in need of a tune. Took a few months but Tom made sure the car was running the way it should before tuning. The car has 155k miles on it so I wasn't expecting much over 350hp. The car peaks at 30psi and tapers to 24 by redline. Sorry no map sensor to show boost and for some reason the A/F didn't show up. Like the title says the car put out 393whp and 385tq on 93 octane.
Stock block
ARP headstuds
Evo 9 turbo W/ Forge WGA 25psi
9 BOV Crushed
Kelford 272s stock springs
ETS 3.5 IC
Injen IC piping/intake W/ Perrin microphone
Tanabe TBE
Halman MBC
Walbro 255
Stock injectors
Stock block
ARP headstuds
9 BOV Crushed
ETS 3.5 IC
Tanabe TBE
Halman MBC
Walbro 255
Stock injectors
Thanks guys.
It had 1050cc and one turned out to be bad, so he put stock injectors back in temp or at least that's what he thinks they are.
I will have him log IDC to see how high it is. That will tell more of the story. Maybe they are slightly larger then stock.
You can make this power on 93 /w no ethanol on stock injectors & a upgraded pump, but along with it comes high injector duty cycles.
