Turbolab of America Stock frame 35R vs Stock turbo 93oct results
Old Jan 15, 2014, 08:37 PM
tscompusa's Avatar
I figured you guys would be interested in seeing data from this customers car I recently completed.
The vehicle is from Alabama, and is running Shell 93oct fuel.
Information about the car is as follows:
Car: Evo 8 GSR
Fuel: 93 octane Fuel (Shell)
Loc/Temp: Alabama / 40-50F average
Mods:
Stock block and head
Stock Intake manifold, Throttle body
FIC 950cc injectors
turbolab of america Ported Stock frame 35R (comparable to EF4) /w 18PSI Turbosmart WGA
Map H11 headstuds
Map tubular exhaust manifold
Map beehive valve springs
GSC S2 cams
Muse upper piping
Muse lower piping
Muse o2 dump
Buschur Deluxe FMIC
Walbro 255
Grimmspeed 3 port
4" SD intake
Tephra v7 SD /w ecuboost
Full specs on the turbo is as follows:
60x83mm Compressor Wheel with a clipped TD06H4 turbine wheel
First is final results of the turbo after the tune was completed:
Next is the turbo at three different boost levels:
Finally, Here is the turbo vs a Stock Evo 9 turbo:
Notes: Car was on a MAF, FP intake + perrin filter, mbc, and stock injectors on the Stock turbo setup. Do not take this as a back to back legit comparison. It is mearly just an example to show the different characteristics between the two turbos in 3rd gear.
Side note: There may have been a little more power left, but we both agreed to leave it. We stopped before we reached any kind of detonation / knock feedback, so in that sense this is a semi conservative tune.
Old Jan 15, 2014, 09:34 PM
4g63evoeight's Avatar
Looks good ! I think it would be pretty cool to see my stock turbo overlayed with this turbo just to see the comparison
Old Jan 15, 2014, 11:28 PM
TigOLDBiTTies's Avatar
is this ball bearing or journal bearing?
Old Jan 16, 2014, 05:11 AM
gsrjosh's Avatar
Its a upgraded journal bearing!
Old Jan 16, 2014, 06:15 AM
Silvermike's Avatar
Great results. I really like the comparison at the different boost levels. Shows the efficiency of the turbo between 25 to 30psi. Seems a bit lean uptop for 93?
Old Jan 16, 2014, 06:18 AM
gsrjosh's Avatar
I don't know where to begin, Tom is such a great guy.. I love working with him, he is defintly the best tuner hands down!!!! The car is a completely different animal, it pulls so hard.. I love the big turbo power band and the top end pull!! I SUGGEST EVERYONE TO GET A TSCOMPUSA TUNE!! Best tuner for sure!!!
Old Jan 16, 2014, 07:43 PM
tscompusa's Avatar
Thanks Josh.
AFR averages around 11.5-11.8. There's enough timing there, so the leaner afr is not of concern.
This car has leaking throttle body shaft seals, so once that's fixed if we see any changes in the tune ill update the thread for those interested.
That said, the results may not change even after the shaft seals are fixed. It all depends on how bad they are leaking.
Old Jan 16, 2014, 07:51 PM
tscompusa's Avatar
Hey Pete, Thanks. Both 93 and E85 on your car overlayed?
Old Jan 17, 2014, 12:13 PM
gsrjosh's Avatar
Here are some pics of the turbo!!
Old Jan 18, 2014, 01:58 PM
gsrjosh's Avatar
So I replaced the TB shaft seals, and the car felt better all around...hopefully tom will post up the new numbers soon!!!!
Old Jan 18, 2014, 02:43 PM
AWD96's Avatar
How is the quality of the turbo? And how long have you been running it? Keep us updated on it!
Old Jan 22, 2014, 05:08 PM
tscompusa's Avatar
AWD96, ill let Josh answer that. It should be the same reliability as a stock turbo though.
After he fixed the boost leak (throttle body shaft seals) here are the new results.
smoothing6:
Old Jan 22, 2014, 07:33 PM
gsrjosh's Avatar
The quality of this turbo is awesome, it comes with a 2 year 15,000 mile warranty, its got upgraded thrust bearing and oil ports..The sound of thisthing spooling between 2-6psi is wicked sounding.. I've had it on the car for 300miles..and more than 12 third gear pulls..I absolutely love the power band
Old Jan 22, 2014, 10:34 PM
8AVETTE's Avatar
Wow great numbers. Chart looks great
Old Jan 23, 2014, 08:48 AM
Evo8Master's Avatar
Awesome turbo and numbers Where can I buy some new TB Seals? How hard was it to replace the old ones? I think my seals are leaking
Quick Reply: Turbolab of America Stock frame 35R vs Stock turbo 93oct results
