tscomptuned - fp black - STOCK BLOCK - virtual dyno vs dynojet / take two - 600whp+
So I made a thread about this car a few weeks ago with virtual dyno showing 570 in 80f temps and then 600whp in cooler temps.. I also said i was going to get the owner on a dynojet for a comparison as well and we did just that.
Below are virtual dyno vs dynojet results.. in Standard, Uncorrected and SAE. The car is from FL so heat is definitely an issue yet it still managed to crack well into the 600whp territory.
Mods are the same as before:
Stock Block & Head
FP Black (JB)
Kelford 272s
Toxic Fab tubular exhaust mani
MAP 3" recirc dump
FP Intake Pipe
BR Filter intake
BR 65mm TB
BR Ported Intake mani
BR Double Pumper
BR Mini Battery kit (A Real One LOL)
BR 3" TBE w/ two Magnaflows (no cat)
Forge RS BOV
Forge MBC
Grimmspeed 3 port
Precision 1200cc Injectors
Spoolin Up COP
ETS 3.8" Garrett core FMIC
ETS 2.5" Upper & Lower Piping
ARP Headstuds
Kiggly HLA pressure reg
ACT Clutch
Boost pressure: 38psi drop to 36psi
Fuel: E85
Please Note: The virtual dyno pull was not done on the same day as the dyno runs, but looks to be very close to the uncorrected / SAE graph on the dynojet. The virtual dyno graph is being shared to show that it is still well within the ball park even though they are not true back to back.. there is a 7-10 day variance here.
smoothing 1 = 613
smoothing 3 = 603
smoothing 5 = 602
smoothing 8 = 599
smoothing 10 = 597
Dynojet results and video:
Uncorrected:
SAE:
Standard:
Unedited Video:
http://www.youtube.com/watch?v=Ls3BJGsiaaA
Stock Block & Head
FP Black (JB)
Kelford 272s
MAP 3" recirc dump
FP Intake Pipe
BR Filter intake
BR 65mm TB
BR Double Pumper
Forge RS BOV
Forge MBC
Grimmspeed 3 port
Spoolin Up COP
ARP Headstuds
ACT Clutch
Fuel: E85
smoothing 1 = 613
smoothing 3 = 603
smoothing 5 = 602
smoothing 8 = 599
smoothing 10 = 597
Uncorrected:
SAE:
Standard:
Unedited Video:
FIRST! soooooooooooooooo jealous!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!! cant wait to get mine back on the road and tuned. great job as always Tom
So out of curiosity what did you revamp to get it to match so close? I spent some time playing with it the other day and was off by 100/100 (on the low side actually) on GotWheelHop's car. I kept getting some weird errors as well so maybe its just I need to update. Not sure but would like to get it that close, especially since I think there are definitely some flat enough roads to get it pretty accurate.
thanks
aaron
thanks
aaron
thanks
aaron
thanks
aaron
