Evo 8 stock turbo/cam Factory Freak
Evo 8 stock turbo/cam Factory Freak 410/401
Mod list :
Hallman MBC
PTE 1000cc
Walboro pump
Full Tbe
Greddy RS Bov
ETS LICP
T bolt clamps
NGK brp8 1 step
E85 30psi dropping off to 27psi
and the key ingredient : TSCOMPUSA aka Tom
E85
93OCT
Tom told me there was room for a bit more but I have some engine noise and rattling to fix that was causing some false knock (Radiator Support bracket)
and the best part? I didnt have a serial cable to log my wideband so Tom had to go off what I told him.. I think his threads speak for themselves.
Thanks Tom!
Hallman MBC
PTE 1000cc
Walboro pump
Full Tbe
Greddy RS Bov
ETS LICP
T bolt clamps
NGK brp8 1 step
E85
93OCT
Thanks Tom!
that is pretty unbelievable for stock cams. evo 8 turbo with the small hot side and FMIC, stock intake, o2 housing, goes to show each car is different, enjoy your car!
ok thanks for clarifying even then your major power adders are still not there which is unreal, saw you were doing the cams maybe (if you can afford) do a fmic at the same time but i think its cool you are wringing out every bit of the stock turbo small hotside 8 turbo
well im tuning it on 93oct in about an hr so i will post that result. i would imagine it makes 350 on 93 if it made this on e85. we will find out in a bit. hopefully he extracted the broken bolt in his radiator bracket and its not being held by zipties anymore
also Zack, i highly doubt its a smaller housing on the turbo.. it has to be the bigger 10.5 id imagine that came on some 8 turbos. the cars a 2005.. i dont know what year they started doing the bigger housings on the 8 turbo though. do you?
he must have upgraded to a 10.5 or if he bought it used then the previous owner did the upgrade because 03's definately came with 9.8 hotside. (someone correct me if i am wrong though). good luck with the tune it is cool to see all these stock turbos making big power for sure
speaking of cool.. its getting cooler outside also.. and with cool air comes higher hp
is there a way to tell if its 9.8 or 10.5 with it still installed on the car? i would guess not ?
Im waiting for him to msg me so i can finish his tune on 93 octane.. he went to olive garden............ maybe he got stuck in the salad bowl
