Built 2L HTA86@33psi TT long block E85 700hp! | @40psi - 790hp!
I just finished this really awesome pieced together HTA86 powered Turbo Trix built 2L engine. This is a perfect example how combination is a major key in producing wicked power out of these cars.. this car might make 800whp once were done with high boost.. i will update later with that graph also.
Fuel: E85
Boost level: 33psi
ECU: Stock ECU + Speed density /w omni4bar & GM IAT & ECUBoost
Mods:
Engine
2.0L Turbotrix long block Wiesco pistons
Turbo trix stage 5 head
9.2 compression ratio,
aluminum rods
ferra valvetrain
Buschur DP w/modded 255's
-6 feed line
Buschur rail
BBK 75mm throttle body
ID 2000's
DI intake manifold
custom air intake
Buschur 272 cams
Buschur Race FMIC
HTA86 turbo (.82 AR)
Full Race header
Tial WG and BOV
FJO wideband integrated into ecu
E85 Zeitronix Ethanol sensor (e80-e90 at all times)
Carbonetics triple clutch
Grimmspeed 3 port
Sparktech non cdi ignition
Hopefully we hit 800 on high boost mode!
Btw this was in 97% humidity! Will update graphs once we get a good night for tuning.
40psi currently. still 3rd gear run also.
Also still only reving out to 8500ish.. car has the capability to rev to 9500rpm safely.
Fuel: E85
Boost level: 33psi
Mods:
Engine
aluminum rods
ferra valvetrain
-6 feed line
Buschur rail
ID 2000's
DI intake manifold
custom air intake
Buschur 272 cams
Buschur Race FMIC
Full Race header
Tial WG and BOV
Grimmspeed 3 port
Yet again Tom does a great job tuning a car...My car is no where near this build but he did the best out of three tuners I have tried.
Good Job Tom keep it up!!
p.s. Hi Pete, sorry I didnt make it to LG when you came up. I had some family things going on unfortunatly.
I look forward to the next time, The RS is my favorite.
When you hit it around 3k it hits full boost around 5k. its pretty decent for a 2L and the power its producing.
i can't wait to take it for a rip when i'm back up hangout with trav
Peter
From my math:
33 psi = 2.245 bar + 1 bar atm pressure = 3.245 bar
715/3.245 bar = 220 awhp on motor only
800awhp target/220 awhp = 3.636 bar - 1 bar atm pressure = 2.636 bar
2.636 bar = 38.8 psi
You'll lose some turbo efficiency at that high of boost level so I added 2-4 psi back in to make up for it
