Borgwarner Twin Scroll 7670 With Dyno Graph
Old Sep 7, 2011, 02:50 PM
leetEVO's Avatar
I figured I'd post this here in so people don't have to go through 800 posts to find the graph.
A Huge thanks to my sponser Robi@robispec!
Thanks To RRE for the tune and dyno use!
30LBS on e85.
Motor Setup:
Buschur Racing 2.3RPM
Bushur Racing BuiltHead
Buschur Racing Intercooler
Buschur Racing Intake
Buschur Racing Double Pumper
Buschur Racing MB
Fullrace twinscroll Minfold
Fullrace twinscroll downpipe
Fullrace twinscroll midpipe
1600CC injectors
280 HKS Cams
Jdm intake
AEM 5bar
Aem 1313-U EMS
Spark Tech Non-cdi coil pack
Borgwarner TwinScroll 7670
Dual tial MVR Wastegates (dump tubes)
Tial Q BOV
Enjoy!
hokiruu (Jan 22, 2020)
Old Sep 7, 2011, 02:52 PM
Guerillah's Avatar
Crazy amount of torque at 4000RPM. How does the RRE dynopak compare to say a dynojet?
Old Sep 7, 2011, 03:05 PM
JARVEVO8's Avatar
where should we be looking at? the yellow or green numbers?
Thanks!
Old Sep 7, 2011, 03:07 PM
leetEVO's Avatar
Edited
Old Sep 7, 2011, 03:12 PM
tscompusa2's Avatar
i wish it was done on a dynojet. the curves look awesome as is tho.
leetevo can you throw it on a dynojet for us to see also? your mod list is badass also.. great setup you got there.
Old Sep 7, 2011, 03:21 PM
leetEVO's Avatar
Originally Posted by tscompusa
reads higher. i wish it was done on a dynojet. the curves look awesome as is tho.
Thanks!
I will put it on a mustang and dynojet if people want to start donating to the cause. hahahaha If anyone is interested they can PM me and I'll send out my paypal lol.
Old Sep 7, 2011, 03:24 PM
YogSaahoth's Avatar
Before I say anything I should ask if this is a 3rd or 4th gear pull....
Either way that spool is very impressive. What turbine housing are u using? T4 0.92 or 1.05?
And this is only 30psi...nasty turbo for sure. Pairs very well with the 2.3L. Inspiring to say the least...
Old Sep 7, 2011, 03:28 PM
leetEVO's Avatar
This is a T4 1.05.
I wasn't there, I'll have to ask what gear.
Old Sep 7, 2011, 03:54 PM
YogSaahoth's Avatar
If the mph at the bottom of the graph are correct, it looks like 3rd gear...which makes the curve even more impressive
Old Sep 7, 2011, 04:36 PM
Aby@MIL.SPEC's Avatar
iirc, the rre dyno reads slightly lower than a local dj (tuning tech).
on the socal evo boards a while back, someone went from 1 place to another with identical mods & similar ambient conditions.
WOW, thats a bad-*** curve for 30psi.
Old Sep 7, 2011, 05:28 PM
SmurfZilla's Avatar
Its about damn time. Very impressive.
Old Sep 7, 2011, 05:37 PM
tscompusa2's Avatar
if its true it reads lower i really wanna see it on a dynojet now!
i just remember reading in the evo X section all the time that it reads higher.
Old Sep 7, 2011, 05:44 PM
Strm Trpr's Avatar
That torque curve is ridiculous!
Are you the same Leet from Tooners?
I am waiting for this exact turbo as well.
I'm going to run it in a weekend/track day Eclipse GSX 2.0L.
Should be getting the turbo sometime this month, but I'm not going to hold my breath!
Old Sep 7, 2011, 05:50 PM
murlo26's Avatar
Wow, that is a beautiful graph, almost 600/600 yum.
Old Sep 7, 2011, 05:51 PM
RSMike's Avatar
the number in the "ratio" box indicates that it's done in 3rd gear.
The Dynapak dyno is different to all other dyno's.
It takes a set amount of time to complete a run.
A run in 3rd gear and 4th gear will yield the same results if the ratio is setup correctly for the gear and if the length of the run is the same (6seconds etc).
As i said in the BW EFR Thread, i would like to know the temperature of the run and what the peak power would be if correction is turned off. Also how long was the run.
Cheers, Mike
Quick Reply: Borgwarner Twin Scroll 7670 With Dyno Graph
