MAP EF4 e85 built 2L tuned by tscompusa/vr-speed
I know a lot of people have been waiting on some EF4 results. Well Tom did not disappoint with the tune he put on my car . Mod list is as follows
10;1 built engine (eagle rods,etc)
map ef4 turbo
Port polish head
kelford 272
1680 FIC Blue Max high z injectors
double pumper
ETS 3.5" fmic
hallman pro mbc
3 inch exhaust
ported intake
ported exhaust mani
milspec tb
act xtss
Tephra v7 speed density w/ fuel temp as IAT
I cant even tell you how long Tom spent on my car. The driveabilty really is what makes the car stand out to me. I have owned a few built turbo cars. This is the most enjoyable yet! Thanks Tom you did a hell of a job.
I want to say Thanks to MAP for allowing me to beta test this new turbo. We had a few bumps in the road with everything but MAP was always there to lend a hand.
Also want to give thanks to Jen at FIC. We had a strange problem with injectors and he was very helpful in getting everything sorted out.
ok enough BS here is the graph. Tom wanted to up the boost some but im happy where we are at , At least for a few days . Plus he suggested to pre load the gate a little more to help it hold more boost up top instead of just spiking down low.
some car pictures
also i have owned a few built cars. the last one being a 640whp 3800 car and this thing feels every bit as fast if not faster. Cant wait to get it down the 1320 and see what she does.
map ef4 turbo
Port polish head
kelford 272
double pumper
ETS 3.5" fmic
hallman pro mbc
3 inch exhaust
ported intake
ported exhaust mani
milspec tb
act xtss
some car pictures
you get the idea of the power curves of this turbo.. peak tq occurs about 5k and full boost around 4800.
make the WGA hold alittle better out the top and he will be well over 600 more then he is now barely touching it.
will update more as we do more testing etc.. the car ran very bad on the fic 1450cc with the double pumper, so we had them tested and he even bought a new set and still the same ordeal so he called fic and they sent him a set of 1680 to test and problem solved.
but you'll notice not much changed in the overall powerband from 35 to 37 and that is specifically due to the boost curve / wga preload. based on what ive seen from this ef4 it will shine around 34-35psi at higher rpm's like the black does.
Thanks for the kind words Jeff. hopefully it will get some 10's at the track now.
Did the car misfire no matter what as soon as the second pump kicked on with the 1450's?
it is more lol. he failed to mention it has subs, amps, etc in trunk. its ok though no big deal.
It's an experience I will never forget lol... Long day on the dyno There are only a handfull of FIC injectors I like, and 1450's are definitely not on that list lol
The injector problem set me back about 3 weeks. Day after
Day for those weeks me and Tom were testing new roms anything we could think of. Eventually I pulled the fuse to the second pump and it worked fine. Jen was kind enough to send out these 1680s and they work perfect.
Tom has it dialed in about perfect. Car drives like stock.
thanks BJ - i think the car needs hoosier to do good. seems once all cars get hoosiers they perform good
now once you fix your hack job stuff in your engine bay i will make yours perform the same. cars do not like being grounded by a strand of wire to the battery
Results are decent for 2.0 looks like though, but I'd expect closer to 650 with those good supporting mods.
