Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Dyno Tuning and Results
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 2, 2009, 02:45 PM   #1
Silver Sponsor
Personal Sales Rating: (4)
GST Motorsports's Avatar
Drives: EVO, STI
400 wtq - Stock Evo 9 turbo
Had a repeat customer come in for a retune on 91 and E85 after adding a few supporting mods.
Ended up tieing the 91 oct stock turbo record on our dyno, which is 339whp and has been held for about two years now. Which should give you an idea how hard it is to make that kind of power on our low reading Musting dyno, and on 91 oct, with the stock turbo.
The car actually made 340whp on a couple earlier pulls but the final tune had more torque and 1 less whp. It did claim the stock turbo 91 oct torque record on our dyno which is now 348wtq
Then we moved to E85, which measured at E78 (via GM FlexFuel sensor) since there was still some 91 in the tank, even after draining, which is normal. We have E85 tunes come back for a quick "touch-up" tune after a couple tanks, and they usually pick up a little more power.
On the "E85" tune it made: 395 whp / 400 wtq @ 28psi peak.
+56 whp / +52 wtq on E85
2006 Evo GSR
Modifications:
3" TBE
Stock Evo 9 turbo (ported)
Titek V2 02 housing
MAP V2 ported OEM exhaust manifold
MAP V3 ported/coated OEM intake manifold
MilSpec OEM ported throttle body
APS cold air intake extension with Perrin open filter
Nisei IC pipes
Nisei 3.75 Competition FMIC
Synapse recirc BOV
Exhaust cam gear
Cosworth M3 Mivec Cams (280/272)
ARP headstuds
Forge WGA
RC1200cc injectors
Walbro FP
GM 3 port boost solenoid
Mitsu OEM 3 bar map sensor
Stock MAF
Stock motor
Stock ECU
For reference:
Highest power on a Evo 9 stock turbo so far on our dyno is 403 whp / 402wtq (E85). This had the car doing a 11.4@120 mph, full weight, street tires, 300lb driver.
320-330whp will do 11.9-12.0 @ 115ish with a really good driver, full weight Evo.
Stock 03/04 evo = 190-210whp
Stock 05 evo = 210-215whp
Stock 06 evo = 220-230whp
Stock 08 evo = 215-230whp
Stock 09 Ralliart = 190-199whp
__________________
GST Motorsports
2439 Industrial Pkwy. West Suite A
Hayward, CA 94545
510-264-9049
The original E85 Army
http://www.gstmotorsports.com
Offline
Old Nov 2, 2009, 03:08 PM   #2
Personal Sales Rating: (6)
ChuckP's Avatar
Drives: 2006 GG IX MR
Send a message via AIM to ChuckP
Very nice. What's the owners plan turbo wise?
__________________
GG IX MR - 353whp/347wtq Bryan@GST Tuned
Offline
Old Nov 2, 2009, 03:11 PM   #3
Personal Sales Rating: (33)
mrfred's Avatar
Drives: Evo IX MR
Nice job on the tune. E85 is amazing stuff.
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Offline
Old Nov 2, 2009, 06:03 PM   #4
Silver Sponsor
Drives: EVO, STI
Forgot to add this was dynoed on Hoosier drag radials that where sticky as flytraps on the dyno, which probably brought the power down a bit.
But they should work well at the strip. ;P
__________________
GST Motorsports
Hayward, CA 94545
510-264-9049
Offline
Old Nov 2, 2009, 10:11 PM   #5
Silver Sponsor
Personal Sales Rating: (99)
Aby@MIL.SPEC's Avatar
Drives: Dirty EVO VIII
Very Nice! can you post a boost plot for the e85 run?
__________________
OEM Throttle shaft seals = BOOST LEAK!
FIX your boost leak NOW with MIL.SPEC HIGH PRESSURE TB Shaft Seals!
http://forums.evolutionm.net/evo-sale-external-engine-power/364108-mil-spec-high-pressure-throttle-shaft-seals-available.html
MIL.SPEC 65mm TB's
http://forums.evolutionm.net/evo-sale-external-engine-power/331371-mil-spec-65mm-throttle-body-hotness.html
AMS PERFORMANCE CHICAGO, IL
CBRD YORK, PA
ENGLISH RACING CAMAS, WA
GST MOTORSPORTS HAYWARD, CA
MAPERFORMANCE PLYMOUTH, MN
REESE TUNING SANTEE, CA
TUNING TECHNOLOGIES COLTON, CA
Offline
Old Nov 3, 2009, 11:25 AM   #6
Silver Sponsor
Drives: EVO, STI
Quote:
Here you go:
__________________
GST Motorsports
Hayward, CA 94545
510-264-9049
Offline
Old Nov 3, 2009, 11:32 AM   #7
EvoM Moderator
Personal Sales Rating: (12)
MR Turco's Avatar
Drives: WW Evo IX w/ SSL/SE, 2000 Sentra SE w/ SR20
Very nice numbers! Makes me really wish we had E85 out here.
__________________
-Mike
The Rules - love them
TephraMOD V7 - now serving 25x30 fuel and timing maps and Gear Dependent Boost Control
Quote:
Originally Posted by beavis820 View Post
turco is a damn fine mechanic without me
Offline
Old Nov 3, 2009, 12:02 PM   #8
Personal Sales Rating: (26)
gsrboi80's Avatar
Drives: 03 TB VIII
Quote:
LOL it sux there are two stations in all of NJ I think neither near me
__________________
4WS TUNED VIII
Quote:
Originally Posted by Evoryder View Post
Its' the turbo punching out for the day
Offline
Old Nov 3, 2009, 06:50 PM   #9
Personal Sales Rating: (2)
MJ23FE's Avatar
Drives: '06 WW IX MR
Send a message via AIM to MJ23FE
+1 on that!!!
-Jalal
__________________
TeamXXXRacing|Northeast Motorsports Club|Online Store
TriStateEvo|http://forums.tristateevo.com/index.php
XBOX Live Gamer Tag: MJ23FE
THE WANT LIST
POWER
Full Re-Tune
BRAKES
SmikeEvo Pad Combo
Performance Friction 2-piece Front Rotors
SUSPENSION/CHASSIS
Whiteline Sway Bar Set - 26mm Fixed Front/24mm Adjustable Rear
Perrin Stout Mounts
Perrin Positive Steering Response System
Offline
Old Nov 3, 2009, 10:05 PM   #10
Personal Sales Rating: (15)
Evo_Kid's Avatar
Drives: 01 Audi S4 (DD) 04 WW VIII RS (project/fun/track) 06 TB IX GSR (sold) 05 AS VIII GSR (sold)
Me too.
They have E-85 in the bay, bout 2.5 hours away from me and they have a bunhc of stations in Sacramento, which is only 1.5 hours away from me. But not ONE near me.
Online
Old Nov 4, 2009, 09:35 AM   #11
Personal Sales Rating: (0)
Drives: 2006 WW Evo IX RS
great numbers bryan
__________________
evo 9 rs: gst motorsports tuned
Offline
Old Nov 4, 2009, 04:35 PM   #12
2.0Ldoom's Avatar
Drives: EVO IX SE
Awesome numbers man..I wish I could get E85
__________________
DG Motors-Kreonic tuned 379AWHP/375AWTQ
Offline
Old Nov 4, 2009, 05:45 PM   #13
Personal Sales Rating: (24)
nikkadanny's Avatar
Drives: evo 9
nice tq, my 9 turbo made 408tq on meth.
__________________
EVOLUTION DYNAMICS TUNED!
Newbie D40
some guy "Man i heard your mitec kick in"
me "no, you heard my o2 dump open"
HAHAHA
Be creative and have your own style, NOW STOP JOCKING ME!
R.I.P DJ Keewie.
Buschur Racing 35r..=) and meth
Offline
Old Nov 5, 2009, 12:02 PM   #14
Silver Sponsor
Drives: EVO, STI
Quote:
Originally Posted by Evo_Kid View Post
Me too.
Give it some time.
__________________
GST Motorsports
Hayward, CA 94545
510-264-9049
Offline
Old Nov 5, 2009, 12:27 PM   #15
TO BE CONTINUED's Avatar
Drives: EVO 9
Quote:
On GST's dyno there is no way your coming close to these number's with just Meth
__________________
EIP Racing Built/Tuned By: Paul
& Mr. T.B.C. Chris N. At The Helm!
13.2 / 12.2 / 11.7 / 11.5 / 11.2 The Countdown Continues...
Offline
Tags
2006, 400, build, evo, exhaust, ix, ixmr, manifold, milspec, oem, power, sale, sti, stock, turbo, whp, wtq
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
