Nov 2, 2009, 12:08 PM
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
763whp/595tq STOCK ECU, SpeedDensity, E85 by TTP!
So in the last few weeks we finally got the clutch situation worked out with the gray '05 MR, my personal daily driver.
With some time we got the speed density system up and running on the car on the kavlico 5bar (Zeitronix) sensor which has a capability of reading up to 60.3psi boost above atmospheric pressure.
There is a little more left in the car. Our tuning session was cut a little short for Halloween so with base fuel pressure bumped a little on the FPR we will be able to extend the legs a little further.
We found that there was no 5bar calibration that was remotely close to correct for our car on the forum so we spent much of the time carefully scaling the 5bar sensor to match the load cells in the ECU for a consistant, calculated and calibrated measurement so when we really got into tuning the cells we could easily know where we stand without having to check loadcalc in the datalogs on every pull.
Power Mods off the top of my head so I could miss some small stuff.
-TTP G.A. 9.0:1 compression aluminum rod race motor
-TTP hand ported head, Supertech black nitrided 1mm over intake valves, Supertech Inconel +1mm exhaust valves, Supertech NEW Beehive Springs, Supertech bronze valve guides, Supertech viton valve seals
-Magnus V5 intake manifold
-Boomba Racing 75mm Throttle Body
-ETS 5in IC with 3 in black powdercoated piping
-TTP 4" intake with AEM dry cone 4" filter
-Tial Q bov vta
-ETS Equal length manifold HTA86 35R turbo, 44mm WG
-STOCK IGNITION COILS AND WIRES
-STOCK ECU, with speed density conversion (thanks to Dr. John Banks)
-TTP Ethamax 1600cc injectors with TTP Fuelab regulator kit on stock rail
-Dual modded walbro fuel pumps in FullBlown Twin pump housing stock fuel lines
-Running on E82% fuel
-Quartermaster Twin Ceram clutch
This car just rips on the street. It will go to the track with AC, PS, 3490lbs with driver. It will do what it will do. The clutch will hold now and not pop the wedge collar like the EXEDY twin every other pass. The BOV will stay put as the flange is welded to the UICP and clamshell clamped. The car has run 10.9@134 with about 641whp with full lift shifts and the wedge collar breaking on the pass with a 1/2 " brake booster hose popping off the intake causing a big boost leak.
Wanted to thank ETS for a great turbo kit. Boomba Racing for an awesome 75mm throttle body, Supertech Performance for amazing valvetrain components, Magnus Motorsports for a superbly crafted cast intake manifold, Quartermaster for the lightest and strongest clutch for the money in the marketplace, Dr. John Banks, Dave AKA Tephra, Jamie AKA JOT for their contributions in advancements to the stock ECU development.
Our short term goals are 9.9@143mph+ STOCK ECU
World Record STOCK ECU E.T. and MPH
World Record WHP record on STOCK ECU
After these have been achieved, we will work on weight reduction and/or a possible new chassis for the powertrain to be transferred to like so many others have done.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Nov 2, 2009, 12:23 PM
Personal Sales Rating: ( 40)
Drives: Operation Damaged Goods - 03 Yellow Evo
TTP FTW! Great job on pushing the stock ECU to the limits! That's a ton of power for a street car
__________________
Michael
Site: Extreme Turbo Systems
Pho: 360-263-3748
AIM: ETS MichaelR
Evo X Stock Block/Stock Head - World Record - 681whp (ETS 3586 Turbo Kit)
Evo X ETS Built Motor - 2.0L World Record - 718whp (ETS 3586 Turbo Kit)
1117whp Evolution 8 (ETS 42R Turbo Kit)
ETS 6.0" Intercooler - ETS 45R Turbo Kit - ETS Exhaust - English Racing Motor - English Racing Tune
ETS Holiday Specials On Our Website!! 20% Off ETS Products!!
Offline
Nov 2, 2009, 12:26 PM
Personal Sales Rating: ( 1)
Drives: 2006 IX Apex Silver
what ignition is that on the first picture?
__________________
E85
TUNED BY Diiirk
SPONSORED BY:AWD MOTORSPORTS
(954) 753-6006
Offline
Personal Sales Rating: ( 7)
Drives: 03 evo
Nice work!
Offline
Nov 2, 2009, 12:30 PM
Silver Sponsor +1
Quote:
Its a COP unit we had on the car before dynotesting while installing the FMIC. Once we moved to stock coils the spark improved. 50psi+ was able to be achieved without a miss on stock coils.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Nov 2, 2009, 12:34 PM
Personal Sales Rating: ( 10)
Drives: 06 TB IX
Looks good guys! Hope you can achieve those records!
Offline
Nov 2, 2009, 12:37 PM
Drives: 06 Evo IX
Congrats again scott! Let me know when you plan on taking it to the track so I can snatch the key when your not looking.
__________________
2006 Mitsubishi Lancer Evolution IX
Stock Turbo/Stock Cams 11.388@119.92 Best MPH 120.38
10.805@125.97mph 1.574 60ft Stock turbo
Quickest Stock Turbo/Stock Block/Stock ECU
Worlds Quickest Stock Block Evo IX
FP Red/Stock Block 10.301@132 1.56 60ft
Stock Turbo 442WHP 482WTQ tuned by TTP
FP Red 590WHP 576WTQ tuned by TTP
Sponsored by
TTP Engineering
Judge Racing
Offline
Nov 2, 2009, 01:11 PM
Personal Sales Rating: ( 11)
Drives: 04 evo 8
very nice man
__________________
NEW SETUP FP Black Ported - BR 2.3 - BR stage3 head - BR double pumper - kelford 272 - map rev3 im - Exedy twin hd
OLD IVEYTUNE - 461/451 - 33psi - E85
NEW IVEYTUNE - ???????
Offline
Nov 2, 2009, 01:16 PM
Gold Sponsor
Personal Sales Rating: ( 9)
Drives: 570whp stock block IX, 66Chevelle, EK hatch DD.
Nice going Scott, seems as though we are fighting for the same records  should be fun.
How do you like the Boomba TB? Bet that thing revs like a motorcycle
Did you have problems with that COP?
__________________
Force-Fed Performance/ A Division of EPIC MOTORSPORTS
http://www.myspace.com/forcefedperformance
834 Stanley Street Fayetteville NC 28306 910-920-1140 Force-Fed (919)300-9673 Kelford Cams ACT Clutches Mishimoto Radiators/Thermostats Aeromotive Products Full-Race ETS Amsoil Authorized Dealer
Offline
Nov 2, 2009, 01:29 PM
Personal Sales Rating: ( 8)
Drives: GG IX MR, '09 Toyota Yaris ONYX Edition
Quote:
Originally Posted by gst motorsports
+1
__________________
XBL GT: Zero Mils
Offline
Drives: 06 Evo IX
Quote:
Originally Posted by GST Motorsports
Wow the "stock motor" personal car magically has a built motor now.
- Bryan
I'm not sure how you guys at GST operate but at TTP I'm certain magic had little to do with it. More like hard work and money well spent to get it in there to push the HTA86 setup much further as you can plainly see.
__________________
Sponsored by
TTP Engineering
Judge Racing
Offline
Nov 2, 2009, 01:34 PM
Silver Sponsor
Personal Sales Rating: ( 17)
Drives: 06 Rally Red MR
Cool. Nice to see what the 86 is doing on E85. I am curious how much boost and what cams?
Ryu, I prefer magic. Makes it so much less time consuming  lol
Offline
Nov 2, 2009, 01:40 PM
Drives: 06 Evo IX
Quote:
Feel free to wave your magic wand over my engine bay  2.2L w/ 9:5:1 please.
__________________
Sponsored by
TTP Engineering
Judge Racing
Offline
Nov 2, 2009, 01:51 PM
Silver Sponsor +1
Sure does. Stock motor is on the floor beside me. I will sell it to you for $2500
http://forums.evolutionm.net/7546541-post14.html
After speaking with Marco Passante from Magnus Motorsports and telling him of our ambitions for stock motor world records, he responded "for what? do you enjoy pain? In the end, what do you gain? What do you have to lose? $5000+ in an engine?"
So we took his advice since our HG was lifting over 40psi we decided to push it for another two months before changing the setup. If we had to change the HG and moved to L19's as we did, we decided to move to a no BShaft TTP Race engine with aluminum rods with CP pistons and rings setup for 40psi+ clearances so that the engine could be used as it was designed for, high boost.
The stock motor looks beautiful from E85 use. Perfect in every way. It is available for sale complete with frontcase, bshafts, and oil pan. If it does not sell, it will go back into the Gray MR if we transfer this powertrain into our race chassis.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Tags
2007, aluminum, e85, ecu, evo, gsr, head, houston, injectors, ported, rods, stock, ttp, world record  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
