Nov 2, 2009, 10:02 PM
#31
Personal Sales Rating: ( 4)
Drives: 04 mitsubishi lancer evolution VIII
All I can say is....WOW! great job! This looks like an awesome setup and I cant wait to see you guys go into the 9's! Best of luck to you all!
__________________
HKS/ACT/INJEN/APEXI
Offline
Nov 3, 2009, 02:22 AM
#32
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Quote:
Thanks for the support!
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Nov 3, 2009, 04:04 AM
#33
Personal Sales Rating: ( 5)
Drives: 2006 Evo IX GSR
Damn Scott. Way to go. Very impressive.
Offline
Nov 3, 2009, 07:51 AM
#34
Personal Sales Rating: ( 19)
Drives: AWD Machines
Quote:
Originally Posted by TTP Engineering
Its a COP unit we had on the car before dynotesting while installing the FMIC. Once we moved to stock coils the spark improved. 50psi+ was able to be achieved without a miss on stock coils.
Doesnt look like a Sparktech. Is that a one off you were testing? Maybe you just havent perfected it yet.
Congrats on the power. Is that the new QM clutch design?
__________________
2004 Evo RS Street Car
FP Red/Stock Motor/Stock ECU
11.03 @ 123
11.34 @ 121 (93 Oct.)
WARP9 Tuned
Online
Nov 3, 2009, 10:01 AM
#35
He is running the stock coils due to problems with the coil on plug that was on the car. In the pictures above there is a COP system probably a spoolinup as I believe they were trying it out. Scott correct me if im wrong
__________________
HKS/ACT/INJEN/APEXI
Offline
Nov 3, 2009, 10:19 AM
#36
Silver Sponsor
Personal Sales Rating: ( 9)
Drives: 04 SSL
Correct. The unit was the one I was using on my car before I started testing out the new and improved coils. He needed a set ASAP so I got it out to him as quick as I could. Talking with Scott to see what went amiss. I'm sure I made a mistake somewhere as I have several customers running the relatively low PSI that it started missing at.
__________________
-Matt
http://www.SpoolinUp.com
Check out the New DIY section.
Affordable COP Kits - Used Coils in stock!
"Performance without the Price Tag"
Offline
Nov 3, 2009, 12:52 PM
#37
Personal Sales Rating: ( 0)
Drives: Evo 5
^^Hope it can be sorted cos im confident its a damn good COP.... otherwise congrates Scott.... its an ANIMAL!!
__________________
1998 Evolution 5
Offline
Nov 3, 2009, 12:54 PM
#38
Silver Sponsor +1
Definitely the fastest street car I have ever driven. It's disgusting. After punching it in first and second, you have enough adrenalin in your system to not even need 3rd or 4th to make you smile ear to ear.
We installed the GM AIT sensor and switched from MAT reading the fuel temp to reading the IAT sensor so now with the colder months ahead we will have temperature compensation. Bumped the idle some more last night as the Quartermaster twin is so frickin lightweight that its not heavy enough to carry over the dips idle that 32lbs rotating masses do. Its a small price to pay for a clutch so light that rips through the gears like it does. With the BOOMBA 75mm throttle body idle set screw cranked a little higher, we are in good shape now.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Nov 3, 2009, 12:56 PM
#39
Personal Sales Rating: ( 44)
With 763 whp on a Mustang Dyno that car will have to MPH at least 163 mph. Good luck with that.
Offline
Nov 3, 2009, 01:06 PM
#40
Silver Sponsor +1
Quote:
No David, no Mustang Dyno in existence reads like yours and if that is the point you are trying to interject into our thread, then this statement should cover that.
I don't know what MD has done your dyno or if it is something in your settings, or why your rpms roll speed calibration was off for so long but we hope you have most of the issues resolved with your dyno. It is frustrating when all of your testing over the years becomes null and void when your roll speed calibration is off. After you have it corrected, none of the data becomes useful from prior tests as the overlays from present to then are on different scales.
We have stated our MPH goals for the car. If we exceed them, great.
We are working with JOT on comparing our dyno's calibration to others in the USA. Part of our testing issue with that VDR program is that our 2byte rpm numbers in evoscan are not reading correct. We have changed our MUT table to reflect what should allow us to datalog 2byte rpm to exceed 7900rpms which we could not before so the VDR program meant nothing with peak whp in the 8000rpms range.
From our initial observations it appears that uncorrected, our dyno reads on par with most MD's and with weather correction, depending on how extreme the temperature in the dyno room and what humidity level it is in this tropical climate, during the summer WCF can add some power over uncorrected MD numbers and when colder than 77*F, the WCF can subtract whp from the WCF numbers.
Lastly, this car weighs 3490 with driver.
We don't have any "tin cans" over here. Only street cars with PS, A/C, Condenser, manual water pump, and ABS, complete with all airbags, heater core, full size radiator, lower members, sway bars, etc etc.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Nov 3, 2009, 01:25 PM
#41
Personal Sales Rating: ( 22)
Drives: eboIX
That is some good info right there.....
__________________
06 Evolution IX
- Its a $15k dollar car with a $15k dollar powertrain
Offline
Nov 3, 2009, 01:34 PM
#42
Personal Sales Rating: ( 15)
2003 Mitsubishi Lancer Evolution
Drives: 2003 evolution, 2009 335i
Wow, those are some awesome #'s.
I never realized you guys had a mustang dyno. I was always thinking it was a dynojet or something.
Either way, awesome #'s and good luck with it.
I'm running the same turbo and love it.
__________________
Built and Tuned by Buschur Racing
Offline
Nov 3, 2009, 01:39 PM
#43
Silver Sponsor +1
Yes it is a Mustang Dyno AWD-500, the same as most other MD's.
We USE a weather station most of the time which takes into account temperature in the dyno room and humidity / barometric pressure. Some dyno shops do NOT. Most of the ones that do not use the weather station choose not to because they have facilities with low humidity or low temperatures and dry air which without weather correction would read higher than with weather correction anyhow.
It is a lot easier to make power with cooler dry air as it is denser and more can fit into the cylinders. The WCF makes up some of the handicap of high humidity (water in the air= less dense, less oxygen) and hotter air (less dense, less oxygen) and compensates as if the humidity was low and the temps were 77*F.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Nov 3, 2009, 01:47 PM
#44
Silver Sponsor
Drives: 04 SSL
Quote:
I should have thought twice before sending him a unit that has had more experiments on it than an alien abductee and made him wait for new coils. Really a stupid judgment call, but as Oscar Wilde said "Experience is the name everyone gives to their mistakes." When I do something stupid, I own up to it.
I'm 100% confident the new kit coming out will rock this easily and Scott will surely be testing it. If anyone has any more comments/concerns feel free to PM me because this thread is about Scott's craziness! CONGRATS!
__________________
-Matt
Offline
Nov 3, 2009, 01:56 PM
#45
Personal Sales Rating: ( 26)
Drives: 03 TB VIII
In the end they are all just tools for tuning. As you said you have a ET your hoping the car runs. If it makes it great if not then you'll know what 7XXhp on your dyno traps. Pretty much end of story
As Im sure Buschur knows what 7XX on his dyno traps.
Heck all you guys here TTP, Buschur, English, GST, AWD, etc... All you guys can give the customer a good idea based on the power the car made on your dyno what it should trap in the 1/4.
Obviously there are some variables such as tin cans cars vs. full weight cars and such
__________________
4WS TUNED VIII
Quote:
Originally Posted by Evoryder
Its' the turbo punching out for the day
Offline
Tags
2007, aluminum, e85, ecu, evo, gsr, head, houston, injectors, ported, rods, stock, ttp, world record  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
