Nov 2, 2009, 07:50 PM
#61
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
Here is the BBK Full Vs. the BBK XL Beta on the same 2.3L, with OEM bov, 3rd gear for both
And boost for above:
Offline
Nov 2, 2009, 07:54 PM
#62
Silver Sponsor
Personal Sales Rating: ( 17)
Drives: 06 Rally Red MR
Brian, nice gains, no loss of spool and 18whp peak? Thats the way to do it, especially since at redline/chop it looks like it picked up well more than 18.
CBRD & GST
Offline
Nov 2, 2009, 07:55 PM
#63
Silver Sponsor
Drives: EVO, STI
Quote:
CBRD & GST
Indeed, and now with the BOV that can hold the boost the XL can make up top it's even more gains.
....and it's not even the final version.
Offline
Nov 2, 2009, 07:58 PM
#64
Silver Sponsor
Personal Sales Rating: ( 46)
Drives: LOT's'O'EVO's
man, you guys are creating some great expectations
ok, well, I admit, that's what makes us work harder
cb
__________________
www.cbrdspeedfactory.com
Immaculately prepared facility... State of the Art equipment..
Proven Motorsports Background.. ALMS, Grand-Am, Open wheel...
www.ChadBlock.com
CBRD Radiators, BBK Turbos, Intercoolers, EVO X parts, and CBRD Time Attack EVO backed by Advan
The standard just became standard. Meeting expectations is now not acceptable... we must always exceed them.
Offline
Nov 2, 2009, 08:08 PM
#65
Personal Sales Rating: ( 0)
Drives: GG 9 MR, hennarot e30 M3, both sold. WW IX RS.
(raises hand to volunteer to be your 2.0 test bed on 93 and e85)
__________________
new - bbk, fp4r, etc.
beatrush undertray + vishnu rear diffuser.
suggested reading:
http://www.m3post.com/goodiesforyou/evo.pdf
the moral of the story: the sum of slower + older + harsher + less perfect = more fun. and more fun is why i'm back in an evo.
tuning c/o bear
Offline
Nov 2, 2009, 09:43 PM
#66
Drives: evo
Ok let me see if I can catch up on some of these questions.
Sorry for the slow reply it was a long day at work. :yawn:
Quote:
Originally Posted by GST Motorsports
He was getting a bit of bov surge with the crushed OEM Bov, which was to be expected. He says with the new synapse the drivability is great once he adjusted it just right.
I'll have to double check on the port.
Yea I was kind of bummed to give up the OEM bov, but of course, it's not my car. He actually did a pretty good job of hiding the huge bov, it's almost as big as a coke can! You can't really see it when opening the hood, you have to poke around a bit.
Quote:
Originally Posted by scheides
Sorry just went back and read more, but he actually gained 20+whp over an already crushed IX bov? Yea the weather might be a little different but that is just nuts!
Kinda makes me want one, esp if it is actually drivable. I've gone from plastic to forge to greddy rs to the ix and now crushed the ix, and even slightly crushing the ix has made it a bit more like the others, that I got rid of because of the part throttle studder while cruising long uphill stretches of road when you get into about 5psi and wanna drop a few degrees off of throttle to keep boost from continually rising and just maintain speed. Def interested in more feedback on this unit.
The synapse is great IMO, it returned the car to stock like low speed drivability. Super important for me as I daily drive my car and park in a small multi level garage at work. I can tap on the pedal and completely let off without the car bucking and lurching, aside from what's normal from my heavy clutch. The same is true for light boost situations and immediatly releasing the accelerator, no bucking. There uphill "flutter" from backing off the throttle quickly as psi is building is still there but it's more controllable and honestly I haven't tried to even tune that out. I can tell you that if I'd driving normally up hill it doesn't do it if I'm just trying to maintain speed, where the crushed IX would.
But this isn't a Synchronic thread so...
You can find more details about my install here:
http://evoempire.org/index.php/topic...89&#entry96189
Quote:
Originally Posted by jid2
The APS BOV fixed all those issues for me, and it's a direct swap for an OEM part. The Synapse was my next choice. Why no upper IC pipes, just to remain stock looking? Good power for sure - time for another fuel pump.
I was on the APS route myself till I heard a few reviews from some good sources and though I'd take a chance on it.
As for the upper IC pipes. I thought about doing Nisei (I still have them actually) but I wasn't really happy with the fit up to the throttlebody, didn't end up needing them to make the BOV fit ( must have mini battery though, read the link to my write up above) and figured if it ain't broke don't fix it. I'm sure i can get a little better response with them but unless I can make them fit nice then I'm fine without it.
Quote:
Originally Posted by Mautofied.IS300
Awesome, the exact setup I have been trying to plan. 2.3 with BBK-XL (can't wait until the billet is tested) and stock everything. At least stock on the outside with some nice porting on the inside
I would have thought you might have been able to squeak out a couple more psi, but I assume the pump issue is your limit?
How are those BlueMax 1250's? I want to run pretty much the same setup down the road, and want to make sure I have enough headroom. I don't want to get the 1250s and find out down the road I need the 1450s. Or get the 1250s and run almost 100% idc.
Thanks,
-Will
Quote:
Originally Posted by 94AWDcoupe
awesome build. awesome results for stock appearing. do these BM 1250s have any idle/ drivability issues? and was the pressure relief modded on the walbro?
Bryan has worked out all my issues with the BlueMax's to date. As for more head room. If I did it again I'd have 1450's. I chose the 1250's to try to maintain drivability but the 1450's seem to be just as tune-able and drivable and now I'm wishing I had a little more head room myself.
That and the AMS fuel return line are the only differences fuel wise between this and the other evos that run out of pump at less power so most likely.
- Bryan
Slight note. Fuel rail is Perrin. I chose Perrin over AMS because I liked that the end flanges were more subtantial. I believe that the AMS and Perrin rails are the same internal bore so they should have the same effect.
The return line is actually a no-name -04 line from the FPR to the stock hardline. I only added that for looks and cause I thought that the stock "hose-hardline-hose-hardline" stock setup was stupid.
There's no need for that many possible extra places to leak, I think the marketing guys at Mitsubishi designed that to sell fuel line and hose clamps.
*Edit* Oh and mileage on the last tank of E85 was ~18.4 MPG, filled up 11.8 gallons at 217 miles, 144 of which were freeway.
Offline
Nov 2, 2009, 09:48 PM
#67
Personal Sales Rating: ( 33)
Drives: Evo IX MR
Quote:
The Perrin that I briefly owned had a 9/16" ID while the AMS has a 1/2" ID.
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Offline
Nov 2, 2009, 09:51 PM
#68
Personal Sales Rating: ( 7)
Drives: 2005 EB Evo 8 SSL
Thanks for getting back to me! 1450's it is.
-Will
Offline
Nov 2, 2009, 09:55 PM
#69
Drives: evo
Quote:
Ahhh gooood note. I knew they both "looked" about half an inch.
-Will
no problemo.
Also, many thanks to GST and CBRD not only for my support but that which they are providing the Evo community as a whole. {thumbsup}
^^ There's a joke in there somewhere I'm sure.
Offline
Nov 2, 2009, 10:22 PM
#70
Personal Sales Rating: ( 8)
Drives: AS IX
That's it!!! I have made my choice. BBK-B FTW!!!
__________________
JDMChicago.com
Offline
Nov 3, 2009, 12:36 AM
#71
Personal Sales Rating: ( 6)
Drives: 05 Evo8 SSL
Awesome notes on all fronts.
Offline
Nov 3, 2009, 07:06 PM
#72
Personal Sales Rating: ( 2)
Drives: '06 WW IX MR
jizzed in mah pants!
This looks awesome and I cannot wait to see billet versions of this turbo.
-Jalal
__________________
TeamXXXRacing|Northeast Motorsports Club|Online Store
TriStateEvo|http://forums.tristateevo.com/index.php
XBOX Live Gamer Tag: MJ23FE
THE WANT LIST
POWER
Full Re-Tune
BRAKES
SmikeEvo Pad Combo
Performance Friction 2-piece Front Rotors
SUSPENSION/CHASSIS
Whiteline Sway Bar Set - 26mm Fixed Front/24mm Adjustable Rear
Perrin Stout Mounts
Perrin Positive Steering Response System
Offline
Nov 4, 2009, 05:58 PM
#73
Personal Sales Rating: ( 5)
Drives: EB EVO IX, 1967 Ford Galaxie fastback, 97 Eclipse GSX
This turbo sounds amazing. Great work CBRD, and as Scheides said great notes as well.
Online
Nov 4, 2009, 06:17 PM
#74
Drives: AS IX
As soon as it hits the market, I will definitely get it. Taking deposits?
__________________
JDMChicago.com
Offline
Nov 5, 2009, 12:03 PM
#75
Silver Sponsor
Drives: EVO, STI
Quote:
Should be interesting once the final version is out!
Offline
Tags
500whp, bbk, beta, ca, cbrd, chico, dyno, evo, fp, full, red, stock, tranny, tuning, turbo, xl  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
