Nov 2, 2009, 11:52 AM
#31
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
Quote:
Originally Posted by BLKCarbonEVO
Was the crush IX Gmodded also?
I'm not sure what you are asking here.
- Bryan
Offline
Nov 2, 2009, 12:24 PM
#32
Personal Sales Rating: ( 6)
Drives: GG IX SE
hmmm, i bought that filter from SE and i didnt know it fit in the stock airbox, i might hack up my stock airbox to keep air temps down in our 115+ degree summer
or i might have you guys do it...i should be down there before summer for a tune on e85
__________________
AEM / ACT / Defi / GReddy / MIL.SPEC / Perrin / Speed Element / Swain Tech Coatings / Walbro
eD NINe.2X powering 2 X 13 Ov.2 ~ 600w
www.myspace.com/mclarenf12003
4wstuned! 320/313 DLL
Offline
Nov 2, 2009, 12:26 PM
#33
Drives: GG IX SE
also, do you think this XL variant will max out a single fuel pump on e85 on a 2.0L?
__________________
Offline
Nov 2, 2009, 12:30 PM
#34
Personal Sales Rating: ( 1)
Drives: 2006 EVO IXMR
Quote:
- Bryan
You said it was running a crushed IX bov at first and was leaking. Did you also have the IX bov gus modded?
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Nov 2, 2009, 12:32 PM
#35
Quote:
Yep, E85 requires a great deal more fuel over pump 93. If you break 500 on E85 with single pump I would be shocked
__________________
Offline
Nov 2, 2009, 12:33 PM
#36
Drives: GG IX SE
^^^true, but it touched 500hp on a 2.3, if this same setup was on a 2.0, it wouldnt be that high, right?
__________________
Offline
Nov 2, 2009, 12:36 PM
#37
Silver Sponsor
Drives: EVO, STI
ahhh. No, just crushed.
Offline
Nov 2, 2009, 12:41 PM
#38
Well on a 2.0 vs. 2.3 on same setup your hp would be lower to start with (in most cases) but I think you would be able to push the single pump a bit further due to less volume  I would not chance anything and just go double pump. If you continue to upgrade your car you will have to eventually and the XL i believe will be 500+ capable and the Red or Black will top 600+. End result... Just double pump. It is a ****ty feeling when you go to the dyno and your car is not "done, hp wise" but you just ran out of fuel so you had to call it a day
Thank you
__________________
Offline
Nov 2, 2009, 12:45 PM
#39
Silver Sponsor
Drives: EVO, STI
Here is the same car, with BBK Full (non-XL)
2.0L vs 2.3L
Offline
Nov 2, 2009, 12:51 PM
#40
Drives: GG IX SE
^^^good graph
my goal is to NOT do dual pumps, so i just need to decide if i want to bbk full or the XL version whenever its released...so for now, it still looks like the normal bbk full for me
__________________
Offline
Nov 2, 2009, 01:49 PM
#41
Drives: 05 Evo8 SSL
He was getting a bit of bov surge with the crushed OEM Bov, which was to be expected. He says with the new synapse the drivability is great once he adjusted it just right.
What setup did he use on the synapse? Port A? B? Kinda deters from the factory look, but I'd def like to know how driveability is improved over a crushed stock unit (i.e. the current best setup imho).
Offline
Nov 2, 2009, 01:51 PM
#42
Silver Sponsor
Drives: EVO, STI
Quote:
I'll have to double check on the port.
Yea I was kind of bummed to give up the OEM bov, but of course, it's not my car. He actually did a pretty good job of hiding the huge bov, it's almost as big as a coke can! You can't really see it when opening the hood, you have to poke around a bit.
Offline
Nov 2, 2009, 02:07 PM
#43
Drives: 05 Evo8 SSL
Sorry just went back and read more, but he actually gained 20+whp over an already crushed IX bov? Yea the weather might be a little different but that is just nuts!
Kinda makes me want one, esp if it is actually drivable. I've gone from plastic to forge to greddy rs to the ix and now crushed the ix, and even slightly crushing the ix has made it a bit more like the others, that I got rid of because of the part throttle studder while cruising long uphill stretches of road when you get into about 5psi and wanna drop a few degrees off of throttle to keep boost from continually rising and just maintain speed. Def interested in more feedback on this unit.
Offline
Nov 2, 2009, 02:12 PM
#44
Silver Sponsor
Drives: EVO, STI
Indeed. It held more boost and didn't leak like the crushed BOV was so I was able to add some more ignition timing as well.
I have a uber crushed OEM bov in my personal Evo and it gets annoying on slight grades. When I go to Tahoe over donner pass it's actually makes for a "lively" experience on icy/slick roads when you have to give the car some opposite lock when the surge makes the back end kick out.
Offline
Nov 2, 2009, 02:38 PM
#45
Personal Sales Rating: ( 48)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO VIII White
The APS BOV fixed all those issues for me, and it's a direct swap for an OEM part. The Synapse was my next choice. Why no upper IC pipes, just to remain stock looking? Good power for sure - time for another fuel pump.
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Tags
500whp, bbk, beta, ca, cbrd, chico, dyno, evo, fp, full, red, stock, tranny, tuning, turbo, xl  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
