Nov 1, 2009, 08:46 AM
Personal Sales Rating: ( 13)
Drives: 06 Evo IX
FP Black Q16 635hp/640tq
I have no idea any of the specs on this car, but i found it on youtube and thought i'd share it with other members on here who i know are curious on FP BLack results
http://www.youtube.com/watch?v=Yibnlx3anJY
By the way 640 tq must be a total monster and a definet BIG TURBO killer with the quick spool
Offline
Nov 1, 2009, 08:54 AM
Personal Sales Rating: ( 4)
Drives: 2005 Mitsubishi Evo 8
I think this vid was already posted bud. But good looking out.
__________________
Frankie's 2005 EVO 8 (stock turbo),B/R STAGE 1, 2, & 3 KIT: (I do have half of 4 and half of 5)
BR TBE
BR MBC
BR AIR FILTER
BR FUEL PUMP
BR UPPER & LOWER INERCOOLER PIPE
BR RACE BATTERY
BR RACE FRONT MOUNT I/C
BR PORTED EXHUST MANIFOLD
EPM O2
HKS 272 CAMS
EXDEY TWIN DISC CLUTCH
FORGE BOV
COOLING MIST KIT
ARP HEAD STUDS
BUSHWAKER TRANNY
SHEP STAGE 2 T-CASE
93 OCT - 20/80METH
Jester Dyno Tune
1.8-60FT.- 12.1@113MPH
Offline
Nov 1, 2009, 10:16 AM
Personal Sales Rating: ( 9)
Drives: 06 IX
lol, yeah this is the third repost that I've seen this week.
Offline
Nov 1, 2009, 10:18 AM
Silver Sponsor
Personal Sales Rating: ( 6)
That's our shop car, I used to drive it a lot, but now it is just stupid. We ran it on C16 for this trip. It is above 400ftlb by 3600rpm and above 500ftlb by 3900rpm and above 600ftlb by 4200rpm and crests 640 by 4600rpm.
First off, since this is my own car, I built it to suit me, and I like them stout in the lower RPM, I like tq, I dont like down shifting, I like to drive them "Tow Truck" style. But still the power stays above 600whp for over 2500rpm stretch from 5k to 7500 where I shut it down most of the time. Reving out farther than that starts to find the limitations of the stroker with stock manifolds and 3" exh system etc. This car also doenst have a external dump for the WG gas, so all the gas has to fit down the DP, not just the turbine gas, but the turbine gas and the WG gas must fit and this does generate some high pressures in the DP itself which is actually kind of a problem with my setup as it sits right now.
Some car specs:
2.3 bottom end 9:1 compression
stock head with stock valves and 5R cams and kiggly springs
Modified and ported stock intake manifold
stock exh manifold
Works O2 housing and DP with 44mm TiAl gate attached to help reduce DP pressure buildup at these higher boost pressures.
Buschur FMIC
Course lots of other non stock parts like windshield wiper fluid etc, but none that are really relevant I think. We do use a Motec M800 box since we have such a large need for data acquisition during our tuning and testing and need so many additional temp and pressure sensors that are non standard, the only way to collect it all is with e M800 box and a E888 expansion logging box piggy backed on.
One of the most surprising things to come out of our recent testing was the observation that at g force of .6 or greater during acceleration you loose oil pressure due to all the oil moving to the backside of the motor rather than being in the pan. This does cause a spike in the temperature of the thrust bearing itself (yes, we have thermocouples inside the turbo, I know we are total dorks!). Not a good thing, not sure what to recommend as a fix for end users at this point, but this turbo will exceed .6g forward acceleration with ease, so it will be something that needs to be addressed just like the road course guys have to deal with it for hard right handers due to the same reason. Anyone launching this hard has trouble like this with oil pressure when the g force gets this high and stays there, even if he doesnt know it yet
But anyway, not going to get it to the track until we work on the oil pickup (dont have a cage anyway). But we might run it over to a dynojet this week without changing anything and see how different the mustang reads from the dynojet just for grins.
If you want to run this turbo at low boost, you are welcome to do it, but you wont make this kind of power. We already have good turbos for lower boost pressures, the 73HTA Green and the 76HTA Red do a great job delivering less airflow and less power than this 82HTA Black. Obviously the point of the Black is to "push harder".
BOOSTON!
Robert
Reason: add dyno graph
Offline
Nov 1, 2009, 10:24 AM
Personal Sales Rating: ( 2)
Drives: Evo IX GSR & 06 ZX10 R Nassert Beet'd
Some car specs:
stock exh manifold
Buschur FMIC
BOOSTON!
Robert
ive been hearing about this turbo, whats the 411 on it? its been the talk for a lil bit, but when i check your site, i dont find anything?
__________________
Evo IX GSR - Int, homemade TBE, Borla Tub Mani(test mule), home tune, JL audio's
06 ZX10RR Kawi Green 163.8 whp stock w/ gutted cat, now rockin Nassert Beet and Barnes clutch/springs
Offline
Nov 1, 2009, 10:33 AM
Personal Sales Rating: ( 1)
Drives: my wife nuts and my son to the track.
Nice post Robert. A couple of weeks ago, I talked to CWILL about the oil pick up. I think he may have a solution so CWILL, if you're on here, post up. This turbo is going to be a nightmare for big turbo's on the street. Just about perfect to be a street sweeper. We were going to take ours to the track, but Tony decided to get engaged Friday night. By the way Robert, nice job on the 5R's. It's about time you tried your own 'big boys' out.
__________________
FP-BLACK 9.53@148.43 & 149.58 MPH
Worlds FASTEST FP-RED Turbo 9.57 & 145.16
Worlds FASTEST OLD FP-GREEN Turbo 133.70 mph
Thanks to our Sponsors
FORCED PERFORMANCE
WILSON MANIFOLDS
SWIFT SPRINGS, USA
IMPACT RACE PRODUCTS
SPARKTECH IGNITIONS
MAPerformance
Offline
Nov 1, 2009, 10:45 AM
Silver Sponsor
Engaged!?!? Another one bites the dust  J/K Congratulations Tony!
Yes, I really love these 5R grinds, freaking move some air! I was surprised that our spool actually got BETTER with them in the car, go figure.
CWILL, talk abou the oil pickup ideas, all ears my friend
BenJ, sorry for the annoying reposting  whomever is responsible for multiple postings of this vid should be shot at once! hee hee!
jmcmill3 : not on the site yet, but almost. Still working out boxing and mundane stuff like that, they'll be shipping soon for those of you that have called in and ordered them already! I should have a product page up on monday or tuesday with some basic info and pics etc.
I really look forward to seeing Tony run the car with this setup on it. Tom if you want to post up any of your testing results with the turbo, be my guest!
(cant bring myself to say Cheers)
Robert
Offline
Nov 1, 2009, 10:47 AM
Robert
thanks for the quick response, i like to do my research before i buy, so that i buy once. ill be looking out for the specs. i think my car is asking me for that turbo, lol.
__________________
Offline
Nov 1, 2009, 10:49 AM
Personal Sales Rating: ( 0)
The oil pickup solution is something the DSM big hp guys been doing for years. Making a cradle around the oil-pickup so no oil-sloshes around/moves away from the pickup has been around for years. I wonder if there would be a market for something like this. Im sure Dave and some others whos been in the game for a long time already has this done to their own and possibly others.
__________________
1993 Plymouth Laser - 649whp/444wtq E85 Dsmlink tuned by MYSELF.
Offline
Nov 1, 2009, 10:55 AM
Drives: 06 gsxr 600
Man talk about tq. Lol
Offline
Nov 1, 2009, 11:17 AM
Silver Sponsor
Personal Sales Rating: ( 17)
Drives: 06 Rally Red MR
We ran into the oil pickup problem on our drag cars. The cause is of course the oil pickup being uncovered so you have to have a deeper sump and longer pickup to keep it buried all the time. The Moroso pan for the 1G and the Evo seem to be the ticket, though our first pan on the Evo was a modded stocker.
Offline
Nov 1, 2009, 11:20 AM
Personal Sales Rating: ( 10)
Drives: TMS 330i
Unless i miss, how much boost youre running?
Offline
Nov 1, 2009, 11:22 AM
Here's a few pics, links and log shots of various pulls when we did the initial tuning.
This is a pic of the 38 psi pull.
40 psi:
__________________
FORCED PERFORMANCE
WILSON MANIFOLDS
SWIFT SPRINGS, USA
SPARKTECH IGNITIONS
MAPerformance
Offline
Nov 1, 2009, 11:44 AM
Log shot showing the previously mentioned wheelspin at peak torque.(5650-6500)
__________________
FORCED PERFORMANCE
WILSON MANIFOLDS
SWIFT SPRINGS, USA
SPARKTECH IGNITIONS
MAPerformance
Offline
Nov 1, 2009, 12:24 PM
Drives: 06 Evo IX
Some car specs:
stock exh manifold
Buschur FMIC
BOOSTON!
Robert
What kind of boost were u guys running on that dyno run? And holy crap by the way 635/640 and on a MUSTANG dyno here i am thinking Dynojet
BTW AWD motosports also had similar issues with oil pressure and launching gforces when they ran their 6765 @ Buschur Shootout. Ask Mike about the issue i know he found a solution for his problem
Offline
Tags
5r, black, cam, dsm, dyno, ebay, evo, evolutionm, forged, fp, fp5r, modification, oil, pan, turbo, wg  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
