Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Dyno Tuning and Results
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 1, 2009, 12:27 PM   #16
Personal Sales Rating: (13)
Nomad4g63's Avatar
Drives: 06 Evo IX
Send a message via AIM to Nomad4g63
Quote:
Originally Posted by ForcedPerformance View Post
BenJ, sorry for the annoying reposting whomever is responsible for multiple postings of this vid should be shot at once! hee hee!
I was unaware of other posts of this video, this is actually the right section to post this video in b/c it is the dyno/results section and no one else posted it
Offline
Old Nov 1, 2009, 01:21 PM   #17
Personal Sales Rating: (1)
9sec9's Avatar
Drives: my wife nuts and my son to the track.
Here's a link to the 40 psi video:
http://s43.photobucket.com/albums/e3...P1020012-1.flv
__________________
FP-BLACK 9.53@148.43 & 149.58 MPH
Worlds FASTEST FP-RED Turbo 9.57 & 145.16
Worlds FASTEST OLD FP-GREEN Turbo 133.70 mph
Thanks to our Sponsors
FORCED PERFORMANCE
WILSON MANIFOLDS
SWIFT SPRINGS, USA
IMPACT RACE PRODUCTS
SPARKTECH IGNITIONS
MAPerformance
Offline
Old Nov 1, 2009, 01:53 PM   #18
Silver Sponsor
Personal Sales Rating: (6)
"What boost is the dyno run"
It starts at 42psi and slopes down to 35psi, it is basically the 138-140krpm speed line on the compressor map. We bring it up to it's max RPM and just let it sit there, and whatever air runs thru the motor is what we get. So if you are looking at a compressor map, the operating line would basically look like that high speed line on the map when you run it this way. Actual mass flow gets up to about 68-69lb/min during this pull. My motor gets to 69lb/min at a much lower RPM than most others since it is a larger engine and has very huge camshafts.
__________________
BOOST ON!
Robert Young
www.forcedperformance.net
Offline
Old Nov 1, 2009, 11:07 PM   #19
BLKCarbonEVO's Avatar
Drives: 2006 EVO IXMR
Send a message via MSN to BLKCarbonEVO
Robert, I have a HKS 272/280 combo and I was wondering how these cams would perform in my car, 5Rs? Would I have valve clearance issues? I also got your email and I'll holla at you tomorrow at work. I need to order a few things from you!
Mikey
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Old Nov 2, 2009, 03:33 AM   #20
Personal Sales Rating: (11)
tscompusa's Avatar
Drives: 04 evo 8
damn thats a LOT of airflow considering this is a direct bolt on turbo for our cars.
__________________
NEW SETUP FP Black Ported - BR 2.3 - BR stage3 head - BR double pumper - kelford 272 - map rev3 im - Exedy twin hd
OLD IVEYTUNE - 461/451 - 33psi - E85
NEW IVEYTUNE - ???????
Offline
Old Nov 2, 2009, 06:35 AM   #21
Personal Sales Rating: (0)
crcain's Avatar
Drives: vi rs
One of the most surprising things to come out of our recent testing was the observation that at g force of .6 or greater during acceleration you loose oil pressure due to all the oil moving to the backside of the motor rather than being in the pan. This does cause a spike in the temperature of the thrust bearing itself (yes, we have thermocouples inside the turbo, I know we are total dorks!).
How many forward G's have you pulled in this particular car?
Where were you measuring oil pressure?
What was the duration and size of the pressure drop?
__________________
10.7 granny shifting - http://www.youtube.com/watch?v=sOEL7uGJIuc
Autronic, 2.4l, MAD spec piper cams, AMS kit, FP HTA 35R, RC 3" exhaust, AIM Dash, Kansai inlet, q45 TB, Buschur COP
Tuned by Mark Shead
Offline
Old Nov 2, 2009, 09:30 AM   #22
Silver Sponsor
Quote:
Mikey
Those cams will run fine. My 4R ran fine too - I just like the 5R better. The only way to know about clearance issues is to check the clearance, I know that is a cop out answer from a DIY perspective, but it's really the only way to know the clearance.
BOOSTON!
Robert
__________________
BOOST ON!
Robert Young
Offline
Old Nov 2, 2009, 09:41 AM   #23
Drives: RR evo9 RS
BOOSTON!
Robert
i was meaning to ask this also, i was thinking about doing the 5R's but wasn't sure about the piston to valve clearance, some say yes some say no. ( i'm a stock head/stock bottom end car)
__________________
Bone Stock IX RS... 13.1 @103.
mods coming s00n
Offline
Old Nov 2, 2009, 10:54 AM   #24
Silver Sponsor
We see over .7g forward acceleration from just a third gear pull, no launch. Just starting at 2500RPM and rolling on full throttle, when the turbo hits it pegs .7g and then some, depends on the traction.
We are measuring the oil pressure in 2 locations. The first is the oil filter housing right after the pump. The second is inside the oil fitting at the turbo oil inlet. We also measure the temperature of the oil at this location and also the temperature of the oil coming out of the thrust bearing. And the temp of the oil coming out of the thrust bearing definitely spikes when the air bubbles just pushed thru the turbo. Not good at all. So be aware that high acceleration can cause oil cavitation and some problems. This might be a new issue for a lot of you guys that are not used to pulling this hard yet. Ignoring these warnings and blowing stuff up does not necessarily get rewarded with a new free turbo for your efforts
The green oil pressure is directly from the oil filter housing, the red one is the oil pressure inside the oil inlet of the turbocharger using our oil supply line kit.
There are some other interesting data traces on that jpg that I can answer questions about so long as the discussion stays civil and friendly.
BOOSTON!
Robert
__________________
BOOST ON!
Robert Young
Offline
Old Nov 2, 2009, 11:16 AM   #25
Personal Sales Rating: (35)
RockmanX's Avatar
Drives: Nissan 350z eclipse spyder eclipse hardtop 08 lancer 03 lancer evolution
email sent fp
__________________
Installed
Aps intercooler,INvidiaExhaust,MishimotoRadaitor, Eclipse Dvd/Nav/Tv AIT Racing Kit, JDM Rear ,Vis CarbonFiber Trunk ,Riser APR GTC 200, APS Bov, T-Rex BBY CarbonFiber Hood
Waiting
ebay ported 02, Exedy Twin Carbon, Met.Black Buschur Throttle Body, Splitter Garage HRS Carbon Kevlar, Met.Black PPI Intake Manifold, "undercut" head studs, Perrin FuelRail, Mike@AwdMotorsports built evo8head, AMS Fuel Line, PTE 1000cc
Ordered
Motor-RX 2.3 Shortblock, FP BLACK TURBOCHARGER
Offline
Old Nov 2, 2009, 11:57 AM   #26
Silver Sponsor
Quote:
The 5R were not designed to clear a stock piston, so the answer is no. The 4R will, and the 4R also lets the stock retainer clear the stock guide. And I also hit 600whp with the black turbo with the 4R in the motor.
BOOSTON!
Robert
__________________
BOOST ON!
Robert Young
Offline
Old Nov 2, 2009, 12:18 PM   #27
9sec9's Avatar
Robert, looking at your current dyno sheet, I can see why you're measuring accelleratin in 'GEEE' forces. I'm impressed to say the least. GroceriusMaximus said he had a lot of testing to do before you could have it back. The 5R's definitely woke the car up.
__________________
FORCED PERFORMANCE
WILSON MANIFOLDS
SWIFT SPRINGS, USA
SPARKTECH IGNITIONS
MAPerformance
Offline
Old Nov 2, 2009, 12:50 PM   #28
tscompusa's Avatar
Drives: 04 evo 8
what kind of solution can we do for the oil pressure loss?
__________________
Offline
Old Nov 2, 2009, 01:02 PM   #29
Silver Sponsor
I added the dyno graph to the first post I made in this thread, but I'll put it here so more people can see it.
__________________
BOOST ON!
Robert Young
Offline
Old Nov 2, 2009, 01:25 PM   #30
Personal Sales Rating: (14)
2003 Mitsubishi Lancer Evolution
project_skyline's Avatar
Drives: 03 EVO8, 05 R6
Send a message via MSN to project_skyline
Wow thats a pretty big dip in oil pressure. Def looks like some pick up solutions need to be made or something.
I guess that tq tapper is pretty normal for a stock appearing turbo right?
The lateral acceleration force is amazing, this turbo is nutz!
__________________
03 Apex silver EVO VIII 12.25@113 1.83 60' @ 4800 ft
stock 9 turbo, stock ecu, stock block e-85
www.rcm-awd.com Colorado car club
Offline
Tags
5r, black, cam, dsm, dyno, ebay, evo, evolutionm, forged, fp, fp5r, modification, oil, pan, turbo, wg
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
