Oct 25, 2009, 04:53 PM
Personal Sales Rating: ( 11)
Drives: '06 Wicked White Evo IX w/ SSL
DLL: 422whp and 368wtq, not sure on the accuracy of this...
So I was messing around today, loaded Tephra v7 and wanted to make sure that everything was working alright. In the spring I had 365WHP and 359WTQ @ 28PSI running E85 with a my stock IX turbo at DB Performance on their Dyno Dynamics. Anyways I went out and did a couple pulls, then I decided to try out DLL...
The HP seems a bit high, but the TQ is pretty close to what I was making in the spring. here are the results, still running E85 at 28PSI. --
Engine Mods --
AMS Front Mount Intercooler
AMS Manual Boost Controller
AMS Polyurethane Front Motor Mount
ARP Head Studs
Cosworth M2 Cams
Cosworth Head Gasket
DC Sports Downpipe w/ Cat Delete
ETS Intake Pipe w/ Perrin Filter
Greddy Ti-C Catback Exhaust
Megan Racing o2 Housing
Nisei Intercooler Pipes
Nisei Mini Battery Kit
PTE 1000cc Injectors
Walbro 255 Fuel Pump
Offline
Oct 25, 2009, 06:28 PM
Personal Sales Rating: ( 29)
Drives: '03 CT9A / '06 MDX / '07 CBR600RR
It's pretty accurate when you use accurate inputs: make sure you have the true weight of the car, gear ratios, cD, and a level surface w/ minimal wind when you do your logs. Not sure how you edited the run, but I'll usually show the full slope of the graph where the power starts to fall off later in the RPM range. I've noticed if you cut the run off prior to the power dropping it will show a much higher HP number.
__________________
Shearer HTA3582 / Magnus V5 / GSC S2 Cams / PPI 65mm TB / Dejon 4" Intake / AMSoil 4090 Filter
FIC 1450cc Injectors / Perrin Fuel Rail / BR Dual Pumps / TiAL Q BOV / APS Catback
ETS UICP / Nisei FMIC / HKS DLI2 / Hallman MBC / E85
Speed Density via EcuFlash
Next: Wiseco 1400HD Pistons / Howards Rods / MAP Stage 4 Head / A1 L19 Studs / ACT 6-Puck
Offline
Oct 25, 2009, 06:34 PM
Personal Sales Rating: ( 2)
Drives: 2006 Evo IX RS, 2005 SRT-4, 2006 Charger SRT-8
That's an odd looking graph, did you side-step the clutch at 3000RPMs or what? Not used to seeing a run start at 0HP around 3000rpms... what gear did you use?
__________________
2006 Dodge Charger SRT-8 370RWHP
2006 White Mitsubishi Evolution IX RS STOCK
2005 Dodge SRT-4 412FWHP
Offline
Oct 25, 2009, 07:27 PM
Quote:
I just started the logging at about 30mph in 3rd gear.
I did change the gear ratios and the weight was pretty close to what my car weighs with me inside it. I'll mess with it some more this week and start the logs at a lower RPM.
Offline
Oct 25, 2009, 08:57 PM
Personal Sales Rating: ( 15)
Drives: 01 Audi S4 (DD) 04 WW VIII RS (project/fun/track) 06 TB IX GSR (sold) 05 AS VIII GSR (sold)
Also, DLL read more like a dynojet (which read higher), then a Dyno Dynamics.
A Dyno Dynamics dyno is a low-reading dyno, more like a mustang.
A Dynojet dyno is a higher reading dyno.
Offline
Oct 25, 2009, 09:19 PM
Personal Sales Rating: ( 48)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO VIII White
That's a really bizarre torque curve. I've never really scene one that just continues to climb, especially on the stock turbo. Typically it will make peak torque at 4000 RPM or so and then fall off. I'd try some more, start logging when you start the car and make some pulls. Then isolate the pulls for the DLL shots.
Here's a more typical curve....
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Oct 25, 2009, 09:23 PM
Personal Sales Rating: ( 6)
Drives: 05 Evo8 SSL
^ this hasnt been my experience. chukee, what settings did you use in DLL? whp seems way high for your setup, but then again its a little colder out now. I saw similar numbers to my dyno dynamics numbers using the dll default correction. We can compare notes if ya want
Offline
Oct 25, 2009, 09:36 PM
Also, everyone should just be using VDR anyways.
Has more dyno settings
Has "max RPM trim"
Is free
and..
Is made by a fellow EvoM member.
VDR FTW
Offline
Oct 26, 2009, 02:05 AM
Personal Sales Rating: ( 14)
Drives: 03 EVO8, 05 R6
A lot of us like DLL because its faster. Don't get me wrong I like VDR but DLL is easier to pull graphs up on.
Your graph looks messed up, power shouldn't start from 0.
__________________
03 Apex silver EVO VIII 12.25@113 1.83 60' @ 4800 ft
stock 9 turbo, stock ecu, stock block e-85
www.rcm-awd.com Colorado car club
Offline
Oct 26, 2009, 04:16 PM
I dont think DLL is faster at all. To me, DLL takes longer but I guess thats my opinion.
still VDR FTW.
DLL
Offline
Oct 26, 2009, 04:29 PM
No not on opinion, a fact that your slower at working DLL then VDR when it takes less actions to accomplish the same thing.
My DLL and VDR graphs are nearly identical in evom mode.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
