Oct 14, 2009, 12:47 PM
Personal Sales Rating: ( 36)
Drives: like I've got a pair.
522 whp on E85 --- Mellon tuned!
Let me start by saying that I’m a repeat offender (return customer of Chris Turman’s, aka: Mellon Tuning), and have gone to him for a re-tune at every significant step in the “evolution” of my current Evo 9 MR. This time around, we were going to transition the Evo into a leaner, meaner, GREENER machine by switching to E85 (which we currently have an excellent supply of in northwest Arkansas). To do so, I purchased a double-pumper from Buschur Racing (props to Nick – great guy), PTE 1200’s from Nolimitmotorsports (Chris is the man there), and the Sparktech non-cdi COP setup, as well as fresh iridiums, and an AMS fuel rail (a gift from my buddy Quy). These parts were to be installed when I arrived in Memphis, and would all work well with my existing engine mods:
Buschur Racing built 2.0 block
Buschur Racing stage 3 race head
Cosworth M2 mivec cams
Forced Performance Red turbo (63mm with oil line upgrade)
Ported and Coated stock Ex. Manifold
Ported stock intake manifold
WORKS Aperture II throttle body
WORKS Cast O2 housing
WORKS 76mm downpipe
WORKS resonated test pipe
Tanabe Touring Medallion Catback
ETS upper and lower intercooler pipes
Perrin FMIC (bug-covered)
APS twin-vent (recirc) --- I actually was tuned on the Synapse, but switched back
Apexi cone intake on Cusco intake pipe (stock MAF)
Hallman Pro RX manual boost controller (heavy spring)
and finally, the Stock ECU
Armed with these components, a few of my own tools, and almost 25 gallons of local E85, I set off for the Memphis area to complete the build with Chris’s help. Upon arrival, we started installing the parts almost immediately (after the car cooled down). Chris was already set up and ready to drain my remaining fuel from the tank and refill with E85 when we completed the fuel pump swap, so after a couple of hours of installs, wiring, injector fitment and fresh plugs, we had a car idling on E85 for the first time. We went for a run to scale the injectors and work on the idle (solid motor mounts + race engine + large injectors make it tough to get a clean idle, but at 1100 rpms, everything felt good).
Chris invited me out for dinner with the guys from the local race scene that night, and we had some great food and laughs at the local Memphis Benihana’s (you MUST try the Las Vegas roll --- sooo good). After that, we went for a bit of late-night tuning --- the weather, btw, was in the high 80’s during the day, and high 70’s at night. It had been raining all weekend off and on, so the humidity was extremely high as well. As we went through the normal cycle of third gear pulls that evening, Chris leaned the fuel in spots, added timing across the board, and added even more fuel in some places --- all to take advantage of the excellent anti-knock properties of the E85. AFR’s were solid and we had maxed the turbo out at 38.9 psi (according to Chris’s Greddy Profec B).
Sometime after midnight, we blew a bolt out of the 02 housing at 7500 rpm. HORRIBLE sounding exhaust leak! I was about to despair, but Chris knew exactly what happened the instant we heard it --- and he was right. We drove back to his house, jacked up the front end, and waited for the engine to cool. Thinking back on this, it was a comical experience, but at the time I was freaking out. You see, we found a vacant bolt hole on the top of the O2 housing and replaced it --- fired it up, and the exhaust leak remained. So we found ANOTHER bolt on the side of the O2 housing that needed to be tightened. Tightened THAT bolt. STILL had the exhaust leak. Finally --- right when I get extremely spiritual --- I’m praying in earnest now --- Chris says, “Hey man, there’s another bolt hole back here!” So, we find a bolt that works, and we use all of our socket extensions to attack the bolt on the ass-end of the O2 housing from underneath the car --- and FINALLY --- no exhaust leak. It was 4:30 in the morning.
Does anyone else have a tuner that will go to such lengths for a single customer? I’ve never heard of such sacrifice before, especially on an individual basis, but I know that Chris’s customers will all attest that he consistently goes the extra mile for them. Truly exemplary behavior, that’s all I can say. Ok, fast-forward to the next day --- we’ve got some sleep, and after some breakfast, we headed out to finish up the tune. Another hot, humid day, but the Evo is loving the E85, and we extract 528 whp out of the beast, but back it down to 522 for safety and consistency. The car idles great. You can’t even tell it has large injectors. A truly amazing difference from a simple change of fuel. Chris, once again, never fails to impress. Even though he worked an extra 4 hours of labor IN THE DEAD OF NIGHT --- he never asked for more compensation, and even offered to tweak the tune free of charge as they make the change to winter E85 in my area.
THAT’S what I call an excellent tuner.
THAT’S why he gets my return business.
End of Story.  Enjoy the graph!
__________________
Current Mods:
BR 2.0, Stage 3 head, FPred @ 39psi, Ptd/ctd Exh. mani, Ported Intake mani, WORKS 76mm DP w/ RTP, Tanabe Touring Medallion, Apexi filter, APS twin-vent, Aperture II TB, Cossie M2's, JAM lifters, BR Double Pumper, PTE 1200's, AMS fuel rail, Sparktech non-CDI, ETS LICP, Perrin FMIC, ETS UICP, Irragi HO Alt, Hallman Pro RX, Beatrush + CROX II, Whiteline kit, Tanabe Pro 5's, WORKS rear strut bar, LC-1, Defi's, JDM rear, UK badge, SE lip, Volk's, 522/473 on E85.
Tuned by Mellon
Offline
Oct 14, 2009, 12:55 PM
Personal Sales Rating: ( 1)
2005 Mitsubishi Lancer Evolution
Drives: 05 EVO GSR
Congrats man..  But I have a TUNER that will match and beat that....
__________________
FP Red Turbo " I'm on it".
"510WHP- 453TQ ON PUMP+METH AT 30PSI" DYNOFLASH TUNED
Offline
Oct 14, 2009, 01:20 PM
Personal Sales Rating: ( 0)
Drives: 03 evo
"Congrats man.. But I have a TUNER that will match and beat that.."
"So you have a Tuner that doesnt charge Anything if he has to fix your car before he tunes it? He works for a couple of HOURS for free?
Offline
Oct 14, 2009, 01:29 PM
Personal Sales Rating: ( 32)
Drives: Evo IX
Congrats. Chris goes above and beyond for his customers, that is for sure!
__________________
Fp RED + Buschur + Bushwacker + Shep + CBRD + Exedy 30psi*93 oct*
Tuned by MELLON,430AWHP/380AWTQ DLL
Offline
Oct 14, 2009, 01:58 PM
Quote:
You must be your own tuner!
__________________
Current Mods:
Tuned by Mellon
Offline
Oct 14, 2009, 02:04 PM
Silver Sponsor
Drives: 2006 Evo IX TB
Congrats Brandon. I hope you're enjoying the car. Looking forward to you coming back with a 35r this time haha
__________________
-Kevin
2006 Mitsubishi Evo IX
www.MellonTuning.com - Stock ECU custom tuning Flash ROMs for your EVO done via e-mail or local
Tuning Evo 7, 8, 9, & 10's!
E-mail me at kevin@mellontuning.com if you're interested in getting your Evo tuned!
Offline
Oct 14, 2009, 02:51 PM
Drives: 03 z06, 06 Evo, 03 Cobra
how do you run e85?
Offline
Oct 14, 2009, 03:09 PM
Personal Sales Rating: ( 29)
Drives: evo VII evo VII
lots of power man , mellon ftw
Offline
Drives: that one car.
cool story, and awesome #'s.
thnks for sharing man.
__________________
DRASTIC.
6262. :)
500+ pump.
600+ race.
Offline
Oct 14, 2009, 03:11 PM
Personal Sales Rating: ( 2)
Drives: Evo IX
Nice write up. I enjoyed reading it. Did you sleep at mellon's house? Congrats on the numbers. It must spin first gear when you go WOT...
__________________
11.554 @ 122.73 (full weight minus spare tire)
Offline
Oct 14, 2009, 03:27 PM
Silver Sponsor
Personal Sales Rating: ( 107)
Drives: 03 evo 8
Nice results...Glad to see the non-cdi working well for you.
Congrats on your new found power
__________________
www.SparkTechIgnitions.net
IGNITION TO THE FASTEST.
Breaking news !! 9sec9/OKIX 9.53 @ 148.43 FP Black | Paul N/English Racing. 8.99@149(best mph 166) 1117whp | Jeff B./English racing 8.9 @ 155 mph | 06MR/Turbotrix 8.79@160mph | CFT/PROCCO 9.06@166 | Cwill/ASAP 9.43@150mph | DogBox 8.7@170mph
Dog Box Racing WINS Bounty on the 8's
::::It's Your time for REAL Spark!:::::
Offline
Oct 14, 2009, 03:31 PM
Personal Sales Rating: ( 52)
2003 Mitsubishi Lancer Evolution
Drives: 2003 Evo 8
how much boost are you running? 38.9psi?
Offline
Oct 14, 2009, 04:32 PM
Personal Sales Rating: ( 11)
Drives: mitsubishi evo 8
wow that car must be a beast!! nice
__________________
05 GSR
Mellon DLL 400whp 382wtq 93 pump only ~29PSI
VDR 5.71 (Dynojet Mode)=417WHP 405wtq 93 pump only ~29psi
Tuned by Mellon
|Built 2.0 liter short block (stock compression), stock head|
|FP Green turbo|Ebay 3" TBE with resonator|Buschur SS ported o2 housing|
|Buschur Jet Coated Stock NON ported Exhaust Manifold|
|Buschur Cone Filter|HKS 272 cams| PTE 680's|
|Walbro 255lph |ETS 3" FMIC| ETS LICP Stock UICP|Samco I/C Hoses|
|ACT clutch|ACT flywheel|APS DV|Joe P MBC|
Offline
Oct 14, 2009, 07:03 PM
Silver Sponsor
Personal Sales Rating: ( 28)
Drives: 05 EVO & 91 Stealth TT
thanks for the kind words Brandon, always a pleasure to have you here and thanks for the gift, that was unexpected and very cool of ya
send me some fresh logs when you get a chance and we'll dial it back in for the e85 change you guys are noticing in the area.
Offline
Oct 15, 2009, 09:08 AM
Job well done, in my opinion!
Now that the weather is turning colder, they'll be weaning us off of the "good" E85, and onto the E70 stuff, so we might need a tweak here or there, but nothing as of yet. One thing I have noticed though --- and I'm sure a ton of you guys have experienced this --- is, now that the car is capable of neck-snapping acceleration, the interior components complain alot more in the form of rattles and squeaks, and the like. Especially with the colder weather, and there's more cold on the way! Looks like I'll be turning up the stereo.
__________________
Current Mods:
Tuned by Mellon
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
