Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Dyno Tuning and Results
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 7, 2009, 01:04 AM   #1
Personal Sales Rating: (3)
greatgonzer's Avatar
Drives: 2006 EVOix and 300zxTT
Question FP HTA35R86 on 2.3L stroker. Question
Here are my mods:
I currently have the following installed on my EVO 9: 2.3 stroker kit, FP HTA35r, AEM EMS, AMS Tubular Manifold, JIC Turbo Back With Test Pipe Exhaust, custom Upper Intercooler Pipe With Tial open dump wastegate, custom Lower Intercooler Pipe, Hallman Boost Controller, Walboro 255 Fuel Pump, HKS 272 Cams, ARP Head Studs, Exedy twin disk clutch, Custom 4inch Hard Pipe with k&n filter, 1000cc injectors.
Ok here is my situation, in Albuquerque, NM I was conservatively tuned to 510 on pump 91 octane at 23psi on a Dynojet. Not too shabby. I then had to drive all the way to Portland Oregon for business. While up here I was getting some surging and driveability issues and had to take it to a premier local Tuning shop.
They tuned my car but said that they could only get 425hp at 22psi 92octane and that is about as much as they could get out of it. They said that they highest that they've seen with my setup is about 460hp.
And post their tune my car makes a huge backfiring sound and feels like I hit a brick wall at about 6500rmp. I took it back to them and they said that they think I have a "trigger disk" issue where the AEM computer does not know what the RPM value is passed 6500K?! They showed me the log files where the RPM is at 6500K then suddenly spikes up to about 7400K? They do not know quite what to think of that and when my car hits that value it falls on its face and backfires. It did not do this before I took it to them.
So What hp numbers should I be expecting off of this setup approximately, and what PSI is the safest to run this on pump gas? Also can anyone explain to me how the AEM reads RPM off the motor?
The reason is that my tuner says that I should only expect about 460hp numbers and I'm thinking that is a bit low as my tuner in ALb said that I should easilly hit around 540hp on 91 octane with a decent tune. What do you guys think? Looking for input
__________________
http://www.cardomain.com/id/greatgonzer
506 HP on pump!
HTA-GT35R86 bb 2.3L
Pipes Fabricated by DMC performance and fabrication
Tuning props to English Racing & MagnumPSI
Offline
Old Oct 7, 2009, 01:13 AM   #2
Personal Sales Rating: (24)
nikkadanny's Avatar
Drives: evo 9
go to a different tuner?
__________________
EVOLUTION DYNAMICS TUNED!
Newbie D40
some guy "Man i heard your mitec kick in"
me "no, you heard my o2 dump open"
HAHAHA
Be creative and have your own style, NOW STOP JOCKING ME!
R.I.P DJ Keewie.
Buschur Racing 35r..=) and meth
Offline
Old Oct 7, 2009, 01:21 AM   #3
Quote:
Yeah but when I already spent money in ALB on one tune, then some more money for the tune up in Portland, it makes more sense to stick with that tuner than to switch a third time. The cost alone is killing me. I'm just looking for info to take back to this tuner.
1: Does my situation sound like a "trigger disk" or whatever issue?
2: What HP values should I be expecting from my setup at sea level on a dynojet?
Thanks guys
__________________
506 HP on pump!
HTA-GT35R86 bb 2.3L
Offline
Old Oct 7, 2009, 01:33 AM   #4
nikkadanny's Avatar
Drives: evo 9
im no expert on tuning but there are plenty of evos on here making more than that and running more boost. but 460 on 23psi is good
__________________
Newbie D40
HAHAHA
R.I.P DJ Keewie.
Offline
Old Oct 7, 2009, 02:04 AM   #5
Personal Sales Rating: (0)
Drives: AE86, R33GTR, EVO IX GT
If your rpm is spiking in the logs it could be a crank sensor issue, becareful because if the ECU doesnt know what rpm the engine is actually at you can end up in the wrong load cell and tus end up with the ecu putting incorrect fuel and ignition in, subsequently this can kill the engine.
I'd get the crank sensor / cam sensor checked out and I have read that there are issues with the AEM ecu when one of these goes awol.
Good luck.
Offline
Old Oct 7, 2009, 02:13 AM   #6
Personal Sales Rating: (14)
2003 Mitsubishi Lancer Evolution
project_skyline's Avatar
Drives: 03 EVO8, 05 R6
Send a message via MSN to project_skyline
Im not sure what would be causing your car to lose RPM signal but it sounds like it could possibly be a cam angle sensor, try replacing it.
Also why are you running that crap ass turboxs bov???
__________________
03 Apex silver EVO VIII 12.25@113 1.83 60' @ 4800 ft
stock 9 turbo, stock ecu, stock block e-85
www.rcm-awd.com Colorado car club
Offline
Old Oct 7, 2009, 03:23 AM   #7
Personal Sales Rating: (15)
Evo_Kid's Avatar
Drives: 01 Audi S4 (DD) 04 WW VIII RS (project/fun/track) 06 TB IX GSR (sold) 05 AS VIII GSR (sold)
Good luck.
I quoted "conrad" but this is to the OP:
Read david buschur's recent thread about this happening to him on his 900+HP car and blowing the head.
AEM cars have been experiencing this problem. Do a search on here.
David's thread is called "more broken parts for bad bish" or something similar.
Offline
Old Oct 7, 2009, 06:35 AM   #8
Personal Sales Rating: (6)
scheides's Avatar
Drives: 05 Evo8 SSL
+1 on the cam sensor. If it was the crank angle sensor it'd basically be getting chewed up and jsut stop working; make sure the bolt on the end of your crank is tight (the one you can put a 1/2" drive into and turn the motor over with).
That said, 460whp dynojet with 'issues' seems dandy, and 500whp on pump @22psi seems dandy. Don't forget that not all pump gas is created equal, and you can lose some significant power by running cheapo and supposedly 'top tier' premium gasoline. Put some known good fuel in it, figure out your rpm issue and go back.
Offline
Old Oct 7, 2009, 10:48 AM   #9
Personal Sales Rating: (2)
Magnumpsi's Avatar
Hola,
D you have to understand the differences here. The dyno in ABQ uses a really high correction factor. It is in the range of 1.18-1.25 depending on the day. Because of this all the numbers that come off of that dyno are high.
460hp is about what I would expect on a normal dyno jet reading with just a 1.0 CF.
As for RPM's I am not sure what to tell you. I would say if they think it is a cam sensor problem datalog "stat sync" and see if you loose it when the car backfires.
Let me know if you need anything Darrell I would be more than happy to get this sorted out for you.
Thanks,
Mitch M
__________________
Mitch Mckee
Tuner
Offline
Old Oct 7, 2009, 11:15 AM   #10
R/TErnie's Avatar
Drives: TB Evo IX
Send a message via AIM to R/TErnie
Did you take it to John Reed in Portland?
__________________
11.1@129mph - 521whp via Dynojet
Online
Old Oct 7, 2009, 12:19 PM   #11
Personal Sales Rating: (1)
BLKCarbonEVO's Avatar
Drives: 2006 EVO IXMR
Send a message via MSN to BLKCarbonEVO
I'll be the first to say ER love is where it should have went...
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Old Oct 7, 2009, 12:36 PM   #12
blk4doorawd's Avatar
Drives: 06 evo se
im having a similar problem. i have a 2.0 850r setup and made 625 on pump. then i noticed the car has been feeling slow took it to the track and my best mph was only 120 when i had previous mph's of 133 when i only had 520whp.
__________________
Precision Psi---Streetsweeper---
Offline
Old Oct 7, 2009, 01:58 PM   #13
Drives: evo ix MR, evo ix gsr
check for a boost leak somewhere same thing happend to me, 6500 car would break up and backfire, ended up being a boost leak.
Offline
Old Oct 7, 2009, 03:57 PM   #14
Evo_Kid's Avatar
Quote:
+1
If your in the northwest, the only shop ya need to call is English Racing.....
Offline
Old Oct 7, 2009, 09:37 PM   #15
Thanks guys for all the advice. Mitch (MagnumPSI), I really appreciated your tuning in Alb. But when I got up here in Portland my car was surging badly and was dying whenever I'd put the clutch in. We definately were not able to give the tune adequate time prior to making a 1200mile journey in the EVO. Not your fault under the circumstances.
So I had to find some tuners up here to help me get the surging and idle under control. The people I found here did a great job at that. Now If I can just figure out the 6500k + RPM issue. I will start with the CAM/Crank sensors and boost leaks. I may also just drive up to ER tomorrow and talk with Lucas.
And to answer
Quote:
Kind of. John Reed is going over my map now with the current tuning shop. He also believes that it is a sensor. He thinks that the CAM sensor pickup may be flipped. I'll let you know what I find out.
__________________
506 HP on pump!
HTA-GT35R86 bb 2.3L
Offline
Tags
23, 60, evo, motor, stock, stroked, stroker
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
