Oct 4, 2009, 02:04 PM
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
Evo 9 + FPred + BlaqOps + E85
2009 Evo 9 MR
Mods:
TBE
MilSpec HiFlow cat
Tubular 02 housing
FPred (BlaqOps porting)
OEM BlaqOps ported intake manifold
OEM BlaqOps ported exhaust manifold
FIC BlueMax 1450cc injectors
BlaqOps progressive double pumper (Maf Based)
Injen Upper/Lower ic pipes
Perrin foam open filter
Cosworth M2 Mivec cams
ARP head studs
Aftermarket FMIC
GM 3 port boost solenoid using ECU boost control
Tephra stock ECU map switching (91oct to E85)
This car is a test bed for BlaqOps products, mainly the new progressive double pumper they are bringing to the market. On this car it is run based off the MAF and is tunable based on the Hz curve. Worked out very well once we got the flow vs Hz dialed in. Think progressive Meth injection but with your fuel system.
This day was just to make sure everything was working correctly. The double pumper performed great. We are looking to push the fuel system a little bit more on this car once we iron out some other things unrelated to the actual fuel. Also expect to see this double pumper system on a bit more max effort build here soon (PT6262, built motor, E85 biggie boost).
Gains with E85 on this car over 91 oct: (24psi vs 28psi)
+90whp / +100wtq
91 oct curves (dotted) vs E85 curves (solid):
For the people on the fence, E85 vs Meth: (E85 @ 28psi, Meth @ 30psi)
Offline
Oct 4, 2009, 02:15 PM
Personal Sales Rating: ( 9)
Drives: RX7 GSL-SE turbo, 05 MR Graphite Gray,02 GSXR-750, 88 supra turbo
Quote:
Originally Posted by GST Motorsports
2009 Evo 9
Mods:
TBE
MilSpec HiFlow cat
Tubular 02 housing
ARP head studs
Aftermarket FMIC
+90whp / +100wtq
Intresting double pumper concept. I am surprised to see the e-85 make so much more power then meth though.. Was timing around the same? What was the meth mixture and how much? Either way thanks for posting, car looks very strong
Offline
Personal Sales Rating: ( 6)
Drives: GG IX SE
good job man...keep up the good work...driving my car to you guys is actually starting to enter my mind, as i want to do ecu controlled boost and e85
__________________
AEM / ACT / Defi / GReddy / MIL.SPEC / Perrin / Speed Element / Swain Tech Coatings / Walbro
eD NINe.2X powering 2 X 13 Ov.2 ~ 600w
www.myspace.com/mclarenf12003
4wstuned! 320/313 DLL
Offline
Oct 4, 2009, 02:18 PM
Personal Sales Rating: ( 12)
Drives: 2006 EVO IX
is the meth the dotted line!!
__________________
Subaru(STi) is a boys car, Mitsubishi(evo) is a man's car - Jeremy (Top Gear)
Blue EVO IX:
I have done enough that I'm worried of breaking stuff now!
On a nine turbo I made 366/369 on 91/Meth
New #'s on 11/07/2009 hoping for 450whp
Tuned by Me, Mayhem Tuning
Online
Oct 4, 2009, 02:25 PM
Silver Sponsor
Drives: EVO, STI
Quote:
Timing was less with meth inj if I recall correctly. From 5500 rpm the boost was exactly the same on both. I brought the boost on more gradual this time to give the 6spd a little more time before self destructing.  I believe meth mix was 50/50 but I could be mistaken, it was last year.
Quote:
Yup dotted line is meth inj
Offline
Oct 4, 2009, 07:16 PM
I have to ask, are you using roll speed for rpm cal. or a pickup? Your comparisons are always dead on with graphs from who knows how long ago  I use 2 byte rpm but I can never seem to get it as consistant as you lol
Offline
Oct 4, 2009, 07:19 PM
Silver Sponsor
Drives: EVO, STI
Roll speed.
- Bryan
Offline
Oct 4, 2009, 07:38 PM
Personal Sales Rating: ( 11)
Drives: 04 evo 8
gotta ****ing love E85 man!
__________________
NEW SETUP FP Black Ported - BR 2.3 - BR stage3 head - BR double pumper - kelford 272 - map rev3 im - Exedy twin hd
OLD IVEYTUNE - 461/451 - 33psi - E85
NEW IVEYTUNE - ???????
Offline
Oct 4, 2009, 08:11 PM
Drives: 05 Evo8 SSL
A year later and no parts changes other than the E85 conversion? An extra 40whp seems way excessive over alky, unless the gas was really really really crappy.
Ultimately, decent power and looks like a great fuel pump product
Offline
Oct 4, 2009, 08:17 PM
Silver Sponsor
Drives: EVO, STI
No power changes other than fuel. The car cleaned up a bit with the new fuel system. Before it was a bit touchy knock wise. Perhaps one of his injectors where off flow before or something else.
I don't think 30 whp or so gains over meth is excessive from what I have seen. So far E85 has gained over pretty much every fuel it's been up against on our dyno. 91 / 93 / 100 / MS109 / 110 / C16 / Alky injection
Offline
Oct 6, 2009, 11:56 AM
Personal Sales Rating: ( 7)
Drives: 03 evo
thats killer bro!
Offline
Oct 6, 2009, 12:46 PM
Personal Sales Rating: ( 1)
Drives: 2006 EVO IXMR
That may be correct but I'm not sure that E85 could compare to Q16w/100% meth. I may be wrong but I also have not seen a comparison between the two.
Nice nunbers
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Oct 6, 2009, 12:50 PM
Silver Sponsor
Drives: EVO, STI
Quote:
Nice nunbers
Well that is why I didn't list Q16 .
Offline
Oct 6, 2009, 02:45 PM
Personal Sales Rating: ( 14)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO8, 05 R6
q16 also costs $18 a gallon last i checked.
__________________
03 Apex silver EVO VIII 12.25@113 1.83 60' @ 4800 ft
stock 9 turbo, stock ecu, stock block e-85
www.rcm-awd.com Colorado car club
Online
Oct 6, 2009, 02:54 PM
you pay for quality!
__________________
Offline
Tags
85, blaqops, conversion, double, e85, evo, fuel, ix, list, meth, parts, progressive, pump, pumper, twin  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
