Highest HP 4g63 engine (from 2007)
Old Dec 15, 2011, 02:45 PM
  #1021
CBRD's Avatar
Originally Posted by Debug
I think it speak volumes for the community when shops collaborate with each other. This collaboration is the catalyst that drive new innovations and as a consumer, I appreciate all the efforts. Once someone becomes complacent, unteachable or untrainable in this business (or any for that matter) marketshare will starts to diminish. Again, thanks to you shops are "all in" for the betterment of the community.
There is noone on here who is afraid to learn from others is there?
we look forward to working with Xtreme-
Love the technology they bring to the table- and their inspirations- similar to ours-
cb
CBRD is offline
Old Dec 15, 2011, 03:25 PM
  #1022
EvoJoeIX's Avatar
Funny thing is that one shop seems to come to mind
Im looking forward to whats in the future
EvoJoeIX is offline
Old Dec 15, 2011, 05:01 PM
  #1023
Danielle1485's Avatar
changed my rear diff oil.
Danielle1485 is offline
Old Dec 15, 2011, 07:49 PM
  #1024
detroit pistins's Avatar
Originally Posted by JohnBradley
Soon.
cb
That would save alot of people the long distance calls to Greece
detroit pistins is offline
Old Dec 15, 2011, 10:47 PM
  #1025
hubz91talontsi's Avatar
The more of these parts floating around the more track and dyno results we will see. I'm really looking forward to seeing how some of these can benefit your average joe.
hubz91talontsi is offline
Old Dec 16, 2011, 01:11 AM
  #1026
Beetspeed's Avatar
Spyros,
If I may, I have a question on your intake ports, specifically the shaving of the valve guide down to the port bottom: I often also see that there is a 'trailing ridge' left just before the valve guide and shaft.
Why did you shave the guide all the way down to the port bottom?
Thanks,
Walter
Beetspeed is offline
Old Dec 16, 2011, 03:45 AM
  #1027
tim radley's Avatar
Originally Posted by Extreme Tuners
Intake vs stock intake
Exhaust vs stock
Spyros
Finally someone engineering these heads rather than polishing them.
What epoxy do you use in the exhaust ports? Looks like jb weld form the colour. How long does that last in the exhaust? I always weld the exhaust port and epoxy the inlet because i cannot get epoxy to stay in exhaust port. I've tried jb weld, belzona 1111 and 1511, loctite metal set, devcon and splashzone 788. 2 of those will stay in the intake port forever, 1 comes loose after a year the others after a week! But in exhaust port is fail. But if i could avoid tig welding inside the exhaust ports i would.
Did you also weld the combustion chamber? I recently did an evo head with a lof of chamber welding before putting new seat inserts in. I wanted to fix the bad angles without having a step off the new inserts plus i changed shape between the valves.
Did you consider to move the injector to the port floor side when lifting the port? I think that would be better for you with a proper injector at 5 bar.
Tim
tim radley is offline
Old Dec 16, 2011, 06:26 AM
  #1028
pirsq's Avatar
head ports
You are the first shop other than my own that Ive seen raise the ports that much.If i was state side i would send you pictures of the last generation raised port head i did back in 2003 if you are willing to do more welding and do away with a conventional bolt on intake port the intake can be raised almost 1/4 inch more if you are going to do a new head casting i can do a drawing scan it and send you to explain the changes i developed .the exhaust port you have pictured can be raised even further if you are willing to do welding a lot more!
pirsq is offline
Old Dec 16, 2011, 06:45 AM
  #1029
pirsq's Avatar
injectors
Since you are also doing more methanol based projects i would also suggest you take a look at mike moran big cc custom injectors http://www.moranmotorsports.com/ he has video's showing the spray pattern differance compared to the style you are using and i think you will find so major improvements to be had there!
pirsq is offline
Old Dec 16, 2011, 07:52 AM
  #1030
FILIN's Avatar
I had some failures with them, but if they work it has good spray.
FILIN is offline
Old Dec 19, 2011, 09:27 AM
  #1031
Extreme Tuners's Avatar
Soon.
Extreme Tuners is offline
Old Dec 19, 2011, 09:49 AM
  #1032
Originally Posted by khmerpimpin
CBRD already stated that they were working with Spyros, ER too??
We search to find the best and the most serious shops that can support our products with success.
Englishracing and CBRD some of them.
Old Dec 19, 2011, 04:27 PM
  #1033
Spec-Ops1's Avatar
Looking forward to results Spyros! You couldn't have picked 2 better shops to do testing/results!
Spec-Ops1 is offline
Old Dec 19, 2011, 04:57 PM
  #1034
MrLith's Avatar
When are results likely to start showing up?
MrLith is offline
Old Dec 20, 2011, 10:38 AM
  #1035
Some more pics of the head.
Spyros
Quick Reply: Highest HP 4g63 engine (from 2007)
