590whp 576wtq@40.2psi FPred/Stock Block (TTP TUNED)
Old Aug 16, 2009, 07:09 PM
RyuEvoIX's Avatar
It's taken 4 months to make the preperations to get the car back on the dyno at TTP but I would say the wait was well worth it. This weekend the car went in for a new clutch (Spec Supertwin) and Speed Density conversion along with a retune. The peak boost was 40.2psi, the fuel used was 110oct+100%methanol injection. Below the graph shows the previous best numbers from last time on the dotted lines and the new numbers on the solid lines. I must say the drive home was very impressive in both power and quality. A huge thanks to the crew at TTP for giving me A+ service!!!
Video courtesy of SHhhhh http://www.youtube.com/watch?v=BBV9MeRFUYg
The good: The car idles, and cruises so smooth on speed density in comparison to how the car comes from the factory with the mas it is unreal.
The bad: At the moment I am having lockout issues with this new Spec Supertwin clutch. I am going to attempt to spend an excessive amount of time bleeding the heck out of the hydrolic throw out bearing in hopes it alleviates the issue.
Old Aug 16, 2009, 07:11 PM
danameisoj's Avatar
weaksauce!!!!! lol.
Old Aug 16, 2009, 07:12 PM
localtoys73's Avatar
great numbers you going to take it to the track soon? were you having lockout issues with the act or was it just slipping?
Old Aug 16, 2009, 07:13 PM
RyuEvoIX's Avatar
The previous clutch that was in the car was an Exedy Twin. I did not have lockout issues but I did have a SEVERE slipping issue at the track in the upper gears.
Old Aug 16, 2009, 07:17 PM
at what rpm are you having the lockout? still sounds like a great day on the dyno
Old Aug 16, 2009, 07:29 PM
fqjdmct9a's Avatar
WOW!!! Speechlees....Great Numbers i bet it felt awesome driving home!
Old Aug 16, 2009, 07:46 PM
RyuEvoIX's Avatar
7800rpms. Once the lockout issue is resolved I am confident this car will be in the 9.9-10.1 range at the drag strip.
Old Aug 16, 2009, 07:48 PM
well update the thread when u plan on going id def like to go and watch
Old Aug 16, 2009, 07:51 PM
SOEuro's Avatar
damn dude,you might break the stock block record if you keep it up
RyuEvoIX's Avatar
That's the idea.
Old Aug 16, 2009, 07:59 PM
Evo_TK's Avatar
Wow those are some siiick numbers
Old Aug 16, 2009, 08:24 PM
DenverEvo's Avatar
Wow. +1 for sea level!
Old Aug 16, 2009, 08:26 PM
EvoM Moderator
scheides's Avatar
Holy crap, nice numbers. What WGA are you using to get that much boost out of that thing? Mind sharing the rest of your mod list (or at least the basics)?
Old Aug 16, 2009, 08:28 PM
TTP Engineering's Avatar
I believe he has the FP actuator 18psi, but I believe the stock unit would be able to hit 40 or so psi.
The turbo is capable of 43-45psi ful full tilt, however at the track at high rpm use it will peak in the 36psi range.
Old Aug 16, 2009, 08:31 PM
94AWDcoupe's Avatar
sweet gains Chris. very exciting.
Quick Reply: 590whp 576wtq@40.2psi FPred/Stock Block (TTP TUNED)
