Aug 5, 2009, 12:18 PM
Personal Sales Rating: ( 14)
Drives: 2003 RR Evo
Long Rod 2.2L HTA3582R Twin Scroll
Well, it was a rough night at the dyno, but I thought you guys would want to see the numbers for comparison sake.
-4G64 long Rod 2.2L
-HTA3882R Turbo
-Revolver Cams
-All the usual other stuff
It pretty obvious this motor will shine on E85, but 22psi on pump gas just isn't into the sweet spot of the turbo. The car only made one pull on E85 before blowing a freeze plug out of the block. Going from 22 psi on pump gas to 28 psi on the first E85 pull netted 140HP and 120 Ft/lb increase. Thats 23 hp/psi, which seems pretty good to me. My tuner also said that pull was very rich and the car would make around 600whp at the same boost when properly tuned. That leads me to believe it should be well in the 650+ range with mid 30's boost.
He also thinks its very likely that that HG is fine because 1.) I used crappy freeze plugs (I didn't know any better), and 2.) There was no water in the oil and the overflow reservoir didn't overflow. I'm hopeful that I can just replace the freeze plugs with OEM ones (I used Doorman from Autozone) and my problem is solved.
I also think its possible that there was an air pocket in the cooling system because I just put the turbo on and the car had only been run a couple times since doing so.
Anyways, here's the graphs. I'll keep you guys updated.
Offline
Aug 5, 2009, 12:52 PM
Personal Sales Rating: ( 32)
Drives: 2005 EVO RS, 2004 RC51
Sweet!
Online
Aug 5, 2009, 01:19 PM
Personal Sales Rating: ( 15)
Drives: 03 Evo VIII
Nice combo! what rpm did you hit 28 psi in third gear?
__________________
804 whp/650 wtrq (dyno dynamics 1.2 correction)
FP HTA86, Driven Innovative Intake, Turbo Trix long Block, APS Exhaust, BF FMIC, AEM w/1600cc inj
Old setup 487 hp/ 510 trq FP Evo Green
TheShopCT.com Built
Offline
Aug 5, 2009, 01:24 PM
Personal Sales Rating: ( 86)
when you install freeze plugs dont install them with a socket that fits inside. this is common mistake. your stretching the plug and loosing the tension that holds them in place. they need to be installed by pressing them in by the rim.
__________________
early evo nut rockin
evo1 and evo 4
Offline
Aug 5, 2009, 01:31 PM
Drives: 2003 RR Evo
Quote:
Yeah, I learned that last night, lol. This time it was definitely a green mistake. Are there tools specifically for that or do I just use a bigger socket?
Do you think it's possible that the HG is fine?
Offline
Drives: 2003 RR Evo
Quote:
Originally Posted by freddy302
nice combo! What rpm did you hit 28 psi in third gear?
4200 rpm
Offline
Aug 5, 2009, 01:36 PM
Personal Sales Rating: ( 48)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO VIII White
Always a saga. But it looks like you will be making serious power when it's sorted. Over 600 whp should be stupid fast as they say.
Do some 3rd gear street pulls once it's tuned and going well, so we can see boost profile. Dynapacks load the car to start the run, so that will create a different boost profile.
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Aug 5, 2009, 02:38 PM
Personal Sales Rating: ( 4)
Drives: 05' Evo, 00' BMW 323 Wagon, 94' Nissan Truck
That's gonna be an awesome street car with that kind of response. Great job on selecting the parts... minus the freeze plugs
Offline
Aug 5, 2009, 02:52 PM
Personal Sales Rating: ( 2)
Drives: Evo IX
Your torque is falling off pretty fast with that big turbo. I wouldn't think it would drop that fast. Any thoughts?
__________________
11.554 @ 122.73 (full weight minus spare tire)
Offline
Aug 5, 2009, 04:19 PM
Drives: 2003 RR Evo
Quote:
I'm guessing the 1.00 divided hot side. A bigger one would probably be better, but this is the one that FP sells, and I didn't think it was worth buying a different one. Regardless, 560/500 on a preliminary tune is pretty decent for the boost level and the size of the turbo. I think it is gonna make for a really fun street car.
Offline
Aug 5, 2009, 04:21 PM
Drives: 2003 RR Evo
Quote:
Thanks Walker. Yeah, it never even crossed my mind that freeze plugs even matter. In hindsight, I should have never touched the ones that were in the block originally (they were a ***** to get out).
Offline
Aug 5, 2009, 04:34 PM
Drives: 03 Evo VIII
Quote:
I dont think it is the 1.00 divided housing.. These are my results.. it is a 2.0 and the HTA86.. Your spool up is killing this set up, LOL.
HTA86 Twinscroll Dyno and Track Results
On as side note when I had the HTA82 at that exact power level. 540hp/500 trq w/ 28 psi and meth I ran 11.0 @ 132 w/ 1.9 60ft. And my power curve looked very similar to yours minus 400 rpm on the spool up. So It is gonna be a REALLY FUN street car, Kudos!
__________________
TheShopCT.com Built
Offline
Aug 5, 2009, 05:08 PM
Drives: 2003 RR Evo
Good info, thanks  .
I forgot to mention that this is on the stock ECU and MAF too.
Offline
Aug 5, 2009, 05:11 PM
water pressure is 15psi
combustion pressure is 2000psi
it doesnt take much of a leak to over pressurize water jacket and pop out a freeze plug. my guess is you had block and head resurfaced. and one or both was not machined smooth enough to use a metal gasket. most machine shops are not capable of machining the surface smooth enough. matel gakets require a mirror smooth like surface finish.
my guess is freeze plugs are installed at factory using a special tool with the block heated and the plugs cooled. its a very bad idea to remove them for block cleaning. I would recommend using JB weld when installing the new ones.
__________________
evo1 and evo 4
Offline
Aug 5, 2009, 05:17 PM
Drives: 2003 RR Evo
I was told red loctite works well. I thought about JB weld, but I am worried it won't be enough because of its thick consistency. Is there a problem with tack welding the freeze plugs, lol?
BTW, I was able to put the freeze plug back in almost all the way by hand, so it obviously wasn't very tight. The rest of them were very easy to get out too.
Offline
Tags
22l, dyno, evo, evolutionmlong, freeze, gt3076, hta82, hta86, install, jb, meth, plugs, rod22, scroll, twin, weld  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
