Aug 7, 2009, 03:54 PM
#31
Personal Sales Rating: ( 14)
Drives: 2003 RR Evo
I just got her back together, and all I can say is damn she is fun to drive. I have it set at somewhere around 22 psi right now, so I can't imagine how 28 psi feels. First gear is useless. I would like to log boost, and I have an OMNI 4 bar map sensor, but I don't think it is setup yet. Is there a how-to on setting it up so that I can show you guys some boost logs?
__________________
Dsevo Spec Long Rod 2.2L, TS T4 HTA35, Revolver Cams, ETS 4" IC, Ported TB, Ported IM, Buschur UICP, Buschur Double Pumper, FIC 1450cc Injectors
565/493 on E85 (28psi), 425/370 on 91 (22psi)
More to come on E85
Offline
Aug 7, 2009, 06:58 PM
#32
Drives: 2003 RR Evo
I tried figuring out the settings in Ecuflash for the omni 4 bar map sensor, but I can't get it to work. When I try to log boost it just read 37.xx psi all the time and it never changes. I followed the instruction in the thread in the Ecuflash forum, but obviously I screwed something up.
__________________
More to come on E85
Offline
Aug 7, 2009, 08:44 PM
#33
Personal Sales Rating: ( 1)
Drives: 2006 EVO IXMR
Quote:
Originally Posted by dsevo
By valve do you mean the diverter valve? If so, I will crush it first and do before and after logs to see if that is the issue.
Yes it will, but it gives up spool. Unless you're running 40psi, I don't think the gains warrant the loss of spool. If the 82 keeps gaining 25 hp/psi that means another 6 psi will put me around 700whp. Thats a lot of power for a street car.
+1 and great build
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Aug 7, 2009, 09:59 PM
#34
Personal Sales Rating: ( 2)
Drives: Evo IX
Search for jon bradley's post. english racing sells them and he posted all the info you need.
__________________
11.554 @ 122.73 (full weight minus spare tire)
Offline
Aug 8, 2009, 07:44 AM
#35
Personal Sales Rating: ( 29)
Drives: '03 CT9A / '06 MDX / '07 CBR600RR
You may have one of the sensors where you have to flip flop the MAP sensor wires; I had the same issue w/ my 4-Bar. You can read up about it here: OmniPower 4 bar settings
__________________
Shearer HTA3582 / Magnus V5 / GSC S2 Cams / PPI 65mm TB / Dejon 4" Intake / AMSoil 4090 Filter
FIC 1450cc Injectors / Perrin Fuel Rail / BR Dual Pumps / TiAL Q BOV / APS Catback
ETS UICP / Nisei FMIC / HKS DLI2 / Hallman MBC / E85
Speed Density via EcuFlash
Next: Wiseco 1400HD Pistons / Howards Rods / MAP Stage 4 Head / A1 L19 Studs / ACT 6-Puck
Offline
Aug 8, 2009, 08:22 AM
#36
Personal Sales Rating: ( 16)
Drives: '04 EVO VIII, '06 EVO IX RS, '90 1JZ-TT Supra
1 bar. The MBC's aren't even close to fully turned in, so I don't think that is an issue. I am running a metal OEM diverter valve though, I wonder if that could be leaking.
In the dyno testing I've done - the metal stock BOV started leaking around 23psi. You get the turbo to blow more psi that that - but part of your air charge is getting recirculated rather than going straight into the motor. . .
We picked up 40ft# at the torque spike by switching from the stock BOV to a Forge unit that did not leak at all. . . NO other changes at all. Boost went up from 28psi spike to 32psi spike without touching the boost controller or tune. . .
__________________
Many thanks to:
Andy @ Showcase Mitsubishi
Keith @ Pure Tuning
David @ DHP Composites
Jon @ TRE
Wayne @ Paradigm Performance
Evan @Exedy Clutch
for your contributions to the EVOlutionary EVO9 Project:
2008 - one car - 20+ wins
2008 - Solo2 XPL National Champ
2008 - Solo2 SM National Champ
2009 - the sky's the limit!
Offline
Aug 8, 2009, 09:38 AM
#37
Drives: 2003 RR Evo
Quote:
Nice! I bet that's it. I've had the sensor sitting around for a couple months, so I probably got one of the bad ones. I searched, but I only typed in "Omni" and that thread didn't show up. Thanks again.
__________________
More to come on E85
Offline
Aug 8, 2009, 02:45 PM
#38
Drives: 2003 RR Evo
Thanks Creamo3, that was the issue. I haven't gone out and driven yet, but it seems right at idle.
__________________
More to come on E85
Offline
Aug 9, 2009, 12:39 PM
#39
Personal Sales Rating: ( 65)
Drives: TURBO cars only !!!!!
Very nice set-up. Sounds great too
__________________
Oz
2003 Tarmac Black Evo 8 (A.K.A Mr. Clean)
My Evo
Powered by Buschur Racing!
Reese Tuning - Corn Juice coming! - MD 500
ROBISPEC ///
"The boost-induced adrenaline rush that is an aggressively tuned TURBO
car pulling at the reigns in anger is profoundly tempting. Evan Griffey TM"
Offline
Aug 9, 2009, 01:31 PM
#40
Drives: 2003 RR Evo
Quote:
Thanks Oz, it was nice to meet you. I spend a lot of time in my garage, feel free to drop by any time.
__________________
More to come on E85
Offline
Aug 9, 2009, 02:06 PM
#41
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO8, 05 R6
Get the APS twin vent bov, hands down the best for stock ecu and holds 40 psi solid!
Did you get the omni 4 bar MAP sensor setup? Bet the car is a blast!
__________________
03 Apex silver EVO VIII 12.25@113 1.83 60' @ 4800 ft
stock 9 turbo, stock ecu, stock block e-85
www.rcm-awd.com Colorado car club
Offline
Aug 9, 2009, 02:17 PM
#42
Drives: 2003 RR Evo
I will buy a new BOV, just not sure when. Yes I did get the MAP sensor working. I am running low boost right now, so it only shows 20psi at 4k rpm, but when I crank up the boost again I will be sure to log.
__________________
More to come on E85
Offline
Oct 28, 2009, 09:47 AM
#43
Personal Sales Rating: ( 0)
Drives: 2006 EVO IX GSR
Synapse synchronic BOV the the best currently.. No doubt about it!
__________________
Quote:
Originally Posted by Steve93Talon
I heard FP is coming out with the FP Clear™. The compressor wheel is made out of transparent aluminum. It reaches full boost before you even start the engine, and it's so fast you'll actually create a rift in the space-time continuum and cross the finish line before you even leave the starting line. Discuss.
Online
Nov 8, 2009, 09:31 PM
#44
Anything new lately?
How is your Motor doing and what are the latest changes you have made to it?
Bob -
Offline
Nov 9, 2009, 10:26 PM
#45
Drives: TB Evo IX
Quote:
I just made the switch to the synchronic... amazing.
I had the stock 9 dv
Crushed 9 dv
gus M modded and crushed 9 dv
TiAL 50mm valve VTA
and now the syncronic... best decision every.
Your stock bov is leaking undoubtedly... mine leaked TERRIBLY when I got the Red! I had to rescale my injectors during the retune it was leaking so bad.
__________________
11.1@129mph - 521whp via Dynojet
Offline
Tags
22l, dyno, evo, evolutionmlong, freeze, gt3076, hta82, hta86, install, jb, meth, plugs, rod22, scroll, twin, weld  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
