Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Dyno Tuning and Results
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 6, 2009, 04:49 AM   #16
Personal Sales Rating: (0)
JC evo1's Avatar
Drives: EVO1
T3 or T4 hotside?
__________________
built 2L - GSCS2 - Hypertune intake - GT3582.....
490whp pump gas 27psi dynamics 1.0CF
Offline
Old Aug 6, 2009, 07:19 AM   #17
Personal Sales Rating: (2)
bambooi's Avatar
Drives: Evo IX
t4. It's twin scroll.
__________________
11.554 @ 122.73 (full weight minus spare tire)
Offline
Old Aug 6, 2009, 09:05 AM   #18
Personal Sales Rating: (14)
Viciouslord's Avatar
Drives: Zip Zip through the city!
Send a message via AIM to Viciouslord
Awesome build! good to see something different. looking forward to your final numbers
__________________
"When the power of love overcomes the love of power, the world will know peace." - Jimi Hendrix
Ryan-Tech built, Jestr Tuned
Offline
Old Aug 6, 2009, 11:22 PM   #19
dsevo's Avatar
Drives: 2003 RR Evo
Here's the boost plots for those who are interested.
Offline
Old Aug 7, 2009, 06:30 AM   #20
Personal Sales Rating: (86)
Very nice. very fast spool for that setup. will be a joy when tweaked out.
__________________
early evo nut rockin
evo1 and evo 4
Offline
Old Aug 7, 2009, 08:21 AM   #21
dsevo's Avatar
Drives: 2003 RR Evo
I think there is way too much boost taper on the E85 graph, and the car would have an even better looking power/torque curve if I could take care of that. I originally planed on Ecu boost control, but my tuner talked me out of it in favor of dual MBC's, and I'm not sure it was the right choice. 3psi of taper in the higher rpm's would probably make the graph quite a bit flatter.
__________________
Dsevo Spec Long Rod 2.2L, TS T4 HTA35, Revolver Cams, ETS 4" IC, Ported TB, Ported IM, Buschur UICP, Buschur Double Pumper, FIC 1450cc Injectors
565/493 on E85 (28psi), 425/370 on 91 (22psi)
More to come on E85
Offline
Old Aug 7, 2009, 08:27 AM   #22
crcain's Avatar
Drives: vi rs
How much spring pressure do you have in your gate(s)?
__________________
10.7 granny shifting - http://www.youtube.com/watch?v=sOEL7uGJIuc
Autronic, 2.4l, MAD spec piper cams, AMS kit, FP HTA 35R, RC 3" exhaust, AIM Dash, Kansai inlet, q45 TB, Buschur COP
Tuned by Mark Shead
Offline
Old Aug 7, 2009, 08:31 AM   #23
dsevo's Avatar
Drives: 2003 RR Evo
Quote:
1 bar. The MBC's aren't even close to fully turned in, so I don't think that is an issue. I am running a metal OEM diverter valve though, I wonder if that could be leaking.
__________________
More to come on E85
Offline
Old Aug 7, 2009, 10:22 AM   #24
Personal Sales Rating: (29)
Creamo3's Avatar
Drives: '03 CT9A / '06 MDX / '07 CBR600RR
That boost profile is pretty good; 2.2l and twinscroll make for a responsive setup. I'm not seeing 20psi until ~4500 rpm and 30psi until ~5000rpm on a 2L single scroll. Might be time to upgrade the valve to avoid the boost taper up top. Good luck , look forward to seeing more results
__________________
Shearer HTA3582 / Magnus V5 / GSC S2 Cams / PPI 65mm TB / Dejon 4" Intake / AMSoil 4090 Filter
FIC 1450cc Injectors / Perrin Fuel Rail / BR Dual Pumps / TiAL Q BOV / APS Catback
ETS UICP / Nisei FMIC / HKS DLI2 / Hallman MBC / E85
Speed Density via EcuFlash
Next: Wiseco 1400HD Pistons / Howards Rods / MAP Stage 4 Head / A1 L19 Studs / ACT 6-Puck
Offline
Old Aug 7, 2009, 10:25 AM   #25
Personal Sales Rating: (1)
BLKCarbonEVO's Avatar
Drives: 2006 EVO IXMR
Send a message via MSN to BLKCarbonEVO
Will an 86 hold the top end better than the 82?
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Old Aug 7, 2009, 10:42 AM   #26
dsevo's Avatar
Drives: 2003 RR Evo
Quote:
By valve do you mean the diverter valve? If so, I will crush it first and do before and after logs to see if that is the issue.
Quote:
Yes it will, but it gives up spool. Unless you're running 40psi, I don't think the gains warrant the loss of spool. If the 82 keeps gaining 25 hp/psi that means another 6 psi will put me around 700whp. Thats a lot of power for a street car.
__________________
More to come on E85
Offline
Old Aug 7, 2009, 11:08 AM   #27
crcain's Avatar
Drives: vi rs
Quote:
Yeah I run a little over 1.5 bar spring pressure in a single gate and that allows me to run about 3 bar without issue. You run two gates though correct? So you have a 1 bar spring in each gate?
__________________
Tuned by Mark Shead
Offline
Old Aug 7, 2009, 11:11 AM   #28
dsevo's Avatar
Drives: 2003 RR Evo
Correct, 1 bar in each gate.
__________________
More to come on E85
Offline
Old Aug 7, 2009, 11:47 AM   #29
crcain's Avatar
Drives: vi rs
Sounds like plenty then. Thanks for clarification and good luck finding the cause of the bleeding boost.
__________________
Tuned by Mark Shead
Offline
Old Aug 7, 2009, 12:19 PM   #30
why not get an aftermarket valve?
__________________
Offline
Tags
22l, dyno, evo, evolutionmlong, freeze, gt3076, hta82, hta86, install, jb, meth, plugs, rod22, scroll, twin, weld
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
