Jun 18, 2009, 01:02 PM
#31
Personal Sales Rating: ( 50)
Drives: '06 RR IX RS / '99 Maroon GSX
HTA Green vs. "New" 80mm Red..Hmmm  .
__________________
◄ ◄ K U N i i i Z Z Z E E E ► ►
"OCD isn't a disease..it's a lifestyle" -revvin9k
-||'06 RR E9 RS||-
ROBISPEC/// "...live a little!"
...powered by: żMagic?
Offline
Jun 18, 2009, 01:15 PM
#32
Personal Sales Rating: ( 2)
Drives: 03 EVO TB
Nice numbers, but from the looks of where it spools why not just go Red? FP already had the White, Green, and Red, they should be focusing their energy on stuffing the HTA35R wheel into the new 80mm housing.
Offline
Jun 18, 2009, 01:26 PM
#33
Personal Sales Rating: ( 1)
Looks good  I think I'm going to have to get this.....
__________________
I have a pet ▀□ Compound turbocharged Nitrous Goldfish □▀
Why do people refer to their car parts as bad boys or goodies??? Something is wrong here.....
"Tore up from tha floor up!"
KUNiiiZZZEEE Dial-IN!
'06 RS
Offline
Jun 18, 2009, 03:32 PM
#34
Drives: evo 8 MR
nice numbers
Offline
Jun 18, 2009, 05:31 PM
#35
Personal Sales Rating: ( 86)
Quote:
there is 700rpm diff in spool between the original green and the red. there was a big need for a turbo in between. Plus there is the BBK and Tomie turbos that are beating the old green. This is right were I want to be.
__________________
early evo nut rockin
evo1 and evo 4
Offline
Jun 18, 2009, 05:40 PM
#36
Personal Sales Rating: ( 0)
Drives: Evo 8
Quote:
Originally Posted by Liqquid
Well I think it depends on who's driving the car  I've spoken with a couple tuners and manufactures, from what I've been told about 500/500 is a gamble on the stock bottom end, specifically the stock connecting rods. Mine let go in 4th just after peak torque, the rod snapped right in the middle, but the pistons tops and plugs are clean... so I kinda had a bit of warning before hand, from asking around and from Switzer's but I did it anyways.   live and learn!
can you say beyond MBT?
good numbers but it sounds fairly aggressive, I guess you pay to play...
__________________
{GSC}{enkei}{swift}{ferodo}{20psiMR}{ROBIspec///}{KW}
Eddie says:
it is fun to passenge with you
Brandon says:
well trust me I just turned the log ride into the tower of terror....
Eddie says:
lmfao
Offline
Jun 18, 2009, 05:48 PM
#37
Personal Sales Rating: ( 7)
2003 Mitsubishi Lancer Evolution
Drives: 03 Evo 8, 05 Kawasaki 636RR, 08 Kawasaki KFX450R
Ive definitely wanted the red but now with this I think my mind might be made up. With some meth seeing I dont have e85 around it should put out some nice numbers.
Wondering what its rated at.
__________________
CBRD Slim Rad~Ported Evo 9 16g~Labonte's ISG-S3~BR S.S. o2~HKS Ann. Ed. Ex~3" TP~HKS 272's~PPI PEM~PTE 780's~TTP Spec BBL~SuperTech Duals~4" TurboXS FM~BR LICP~TTR UICP~Sychronic BPV~GM BCS~ACT HDSS~ACT Pro-Lite Flywheel~S.S. -6AN Lines~AMS Full S.S. Clutch Line~Walbro 255~BLOX FMM~Carbon Trunk Lid~JDM Map~Self-Tuned-30psi
::My car on car domain here:: along with Evo/DSM Shoot Out and Some pics many more to come.
Offline
#38
what gear was this dynoed in? and what boost was it holding at redline?
__________________
evo1 and evo 4
Offline
Jun 18, 2009, 09:22 PM
#39
Drives: 05 Evo8
Quote:
3rd gear, it holds about 28-28.5 at redline, but not until the very end of the pull does it go under 30...
__________________
FP HTA Green-ProEfi ECU-Switzer Performance
517awhp/491tq E85
Offline
Jun 19, 2009, 12:41 AM
#40
Drives: 2004 RS
Quote:
Originally Posted by Mike01gsr
So this is a new designed HTA green, not the previous one that was scrapped?
Yes, the short-lived HTA Green that you are refering to did not quite live up to expectations. However, all was not lost as the same HTA compressor wheel from that earlier, failed HTA Green endeavor is being used to great success in the FP White.
It seems that for some reason that particular HTA compressor wheel did not work well in cojunction with the Green's turbine wheel. It does work well in conjunction with the smaller, stock 16G turbine wheel however. Thus, the FP White.
__________________
Vishnu XEDE & camgears-Greddy 720's-ported Green-HKS 280/272-Forge WGA-AMS LICP-DC DP-Magnaflow Ti-Ralliart TS-Tomei Thermokiller - SSAC O2 - BR8ES-Nissei IC--SS clutch line-Endless(f) /Hawk(r) - WALBRO 255-ITG filter-Motul-KOYO radiator-SAMCO intake hose-UEGO-Autometer-Kartboys-Authority SS-MR DV.
DLL: 389WHP/25PSI on 93( non-corrected@3300' altitude). (No dynos in the jungle! Fortunately, there are carnivorous toads that feed on bats).
Offline
Jun 19, 2009, 02:03 AM
#41
Personal Sales Rating: ( 21)
Drives: Evo IX Gsr
damn I hope they have a HTA conversion/trade in for people with regular greens
__________________
Mil.Spec/Ai Racing/Massimo Power
380whp/353wtq @ 28psi stock IX turbo Gst Mustang Dyno
431whp/408wtq @ 28psi RRE's Dynapack
Tooned by Bryan @ Gst
Offline
Jun 19, 2009, 06:17 AM
#42
Drives: 2003 Blue EVO
Quote:
agree to that
__________________
394 awhp on Dynodynamics dyno - Junior tuned
20G9lt and lots more
Offline
Jun 20, 2009, 04:26 AM
#43
Personal Sales Rating: ( 4)
Quote:
Originally Posted by Import Junky
wow you made more on your pump gas tune than i did with my red.
+1
Offline
Jun 20, 2009, 06:57 AM
#44
Personal Sales Rating: ( 13)
Drives: Evo VIII, AE86, R1
That´s an insane power curve.
How´s the idle with the Comp 280´s?
Offline
Jun 20, 2009, 07:18 AM
#45
Personal Sales Rating: ( 3)
Drives: 06 MR
It probably wasn't the 500hp that broke the motor, but rather the 500 lbs of torque. Usually big boost, but low timing are a safe combination on stock motors.
Awsome power on that turbo.... 11.2 @ 129 ....man that sounds fun on the street.
__________________
Authorized Amsoil dealer
Offline
Tags
bolt on, dyno, e85, evo, evolution, evolutionm, forced performance, fp, green, hta, hta green, kfx450r, switzer, turbo, turbocharged  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
