May 24, 2009, 03:14 PM
#61
Personal Sales Rating: ( 2)
Drives: TB Evo IX
Quote:
Originally Posted by Chemwarrior
You are correct. He uses the DLL program to get his numbers.
haha.
__________________
11.1@129mph - 521whp via Dynojet
Offline
May 25, 2009, 10:05 AM
#62
Personal Sales Rating: ( 14)
Drives: 2003 RR Evo
Mellon, can you comment on the spool differences between the two turbos? Thanks.
Offline
May 26, 2009, 06:55 AM
#63
Silver Sponsor
Personal Sales Rating: ( 28)
Drives: 05 EVO & 91 Stealth TT
Quote:
Originally Posted by TheBoz
How much timing are you running at 40psi? Also what AFR are you targeting on the q16?
sorry but that's information I only share with paying customers that have a similar setup
Offline
May 26, 2009, 06:59 AM
#64
Silver Sponsor
Quote:
Originally Posted by dsevo
From the looks of the graph in post #1, the 86 doesn't give up any power anywhere to the 82. Does that turbo really spool the same as an 82? I just ordered my 82 yesterday, but after looking at your graph I'm wondering if I should change my order to the bigger one. I could have sworn that I read the the bigger HTA does give up quite a bit of spool though.
The HTA 3586 .82 definitely feels lazy compared to the HTA 3582 .63 in daily driving but on the track the respool is instant if you shift fast and you can't tell the difference. My advice, if you're going to stick with pump gas and 30psi...go with the HTA 36582 .63 it'll feel more responsive and make nearly identical power. If you're going to run 40psi + on race gas and are mainly into drag racing, then the HTA 3586 .82 might make more sense.
Quote:
Originally Posted by whoflungpoo
so when are you going to bring this beast down to Bham and roll some of these dang dang'r guys up?
there's plenty of fools here that need educating
Offline
May 26, 2009, 08:59 AM
#65
Personal Sales Rating: ( 0)
Drives: vi rs
Quote:
Originally Posted by EvoChrisLee
I have the Hta86 with .82 on a 2.0 and on the street i start to see boost around 4500 this turbo sounds like a jet when it starts to move
So that means you make 30 psi around where? High 5000's?
__________________
10.7 granny shifting - http://www.youtube.com/watch?v=sOEL7uGJIuc
Autronic, 2.4l, MAD spec piper cams, AMS kit, FP HTA 35R, RC 3" exhaust, AIM Dash, Kansai inlet, q45 TB, Buschur COP
Tuned by Mark Shead
Offline
May 26, 2009, 09:07 AM
#66
Drives: 2003 RR Evo
Thanks for the response, I'll stick with the 3582.
Offline
May 26, 2009, 11:14 AM
#67
Personal Sales Rating: ( 29)
Drives: '03 CT9A / '06 MDX / '07 CBR600RR
Just to give you another example: I'm making 20psi in 3rd gear @ ~4550rpm on a HTA3582 w/ .82 with stock 2.0L and 26psi @ ~4800rpm
__________________
Shearer HTA3582 / Magnus V5 / GSC S2 Cams / PPI 65mm TB / Dejon 4" Intake / AMSoil 4090 Filter
FIC 1450cc Injectors / Perrin Fuel Rail / BR Dual Pumps / TiAL Q BOV / APS Catback
ETS UICP / Nisei FMIC / HKS DLI2 / Hallman MBC / E85
Speed Density via EcuFlash
Next: Wiseco 1400HD Pistons / Howards Rods / MAP Stage 4 Head / A1 L19 Studs / ACT 6-Puck
Offline
May 26, 2009, 01:04 PM
#68
Silver Sponsor
Quote:
Originally Posted by R/TErnie
Well you're going to be limp today chief.
Do yourself a favor and be open to help. You might be surprised to find out that there are other people out there that are much smarter than you. When you make comments like this ^^^^ they shake there heads and won't waste their time teaching you what took them 30 years to learn.
sorry I came off dismissive, but I don't like throwing parts at a car just because somebody says "this will help". I don't have unlimited funds nor time to try everything that's out there. I'm doing pretty good with the 3" intake piping and I'm not finished pushing it to see what's left. I'll definitely keep the 4" pipe in mind once I max what I have out if I still want more power. Especially if somebody can provide some proof that it's worth the price.
It's nothing against you, I don't know who you are and your background...but this forum is full of bench racers whom make all kinds of claims based on what their buddy told them. I'm skeptical when I don't see any unbiased data (shops like to sell those parts!) to go along with the claims.
certainly when/if I do a 4" intake I'll be happy to share the results good or bad and give credit where it's due, sorry I offended you, that wasn't my intention.
Offline
May 26, 2009, 01:07 PM
#69
Drives: TB IX SE
damn, very nice. hta's seem to be doing very well!
Offline
May 26, 2009, 03:17 PM
#70
sick number I hope mine makes that
Offline
May 26, 2009, 05:09 PM
#71
Drives: 2003 RR Evo
Quote:
That's exactly the info I was looking for. Thanks
Offline
May 26, 2009, 05:29 PM
#72
Personal Sales Rating: ( 44)
Very nice. I hope you get it all back together soon. I hate when my cars are down.
The turbo inlet discussion. The MAF coupling is 3.25" I believe, not 4". I'd measure it if I was at the shop. The turbo has a 4" inlet with the ported shroud. I don't know for sure but I would guess that the MAF right now is by far the largest restriction in the system. A 4" pipe may very well gain some power but the gains from losing the MAF are going to be MUCH higher. Have you considered running the stock ECU with speed density yet? I want to make the switch soon but want to finish off what I think I can get out of the stock MAF first. In your case it makes sense though.
If you want to try a 4" pipe just say the word and I can fab something up for you and send it over. On the AEM with speed density we had a car on the dyno in the 550 whp range and switched from his 3" BR double bend MAF pipe and open filter to a 4" single bend MAF pipe and filter (no maf being used) and the car gained about 12 whp.
Offline
May 26, 2009, 05:44 PM
#73
Drives: 2008 RR Evo X
These results are super impressive.
__________________
If you build it, they will come.
I'm so JDM I sleep on the right side of the bed.
Quote:
Originally Posted by hotrod2448
I say do it into the earpiece for her phone. Then call her and when she answers ask "Can you hear me coming?" and laugh maniacally.
Offline
May 26, 2009, 06:24 PM
#74
Drives: TB Evo IX
I agree with dave... removing the maf altogether would help much more than making a custom pipe to the maf. I have yet to switch to speed density using the stock ecu... so we'll have to see when the time comes
Congrats on the power  must be fun!
__________________
Offline
May 26, 2009, 07:41 PM
#75
Silver Sponsor
Like you David, I'd like to finish up the tune on the stock mas before I consider trying something else like speed density or even the 4" pipe but thanks for the data and offer to give it a whirl. I may take you up on that later.
12whp is worth doing, did you run into any snags with idling related to the 4" pipe. There was another shop sending me PM's that couldn't get it right until he went back to the 3". I'm not familiar with that shop or their tuning abilities so it didn't scare me off. Also that was on a stock ecu, not an AEM FWIW. I think we can agree that with the stock mas in the way, the size of the pipe leading to the turbo isn't going to matter as much as it would on a speed density setup with no other obstructions.
Offline
Tags
3582, 3586, bend, dyno, fab, hta, hta3586, maf, pipe, shearer, single  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
