Mar 30, 2009, 05:10 AM
Personal Sales Rating: ( 9)
Drives: Evolution
e85, green, stock block, safe?
i am running fp green on stock block with supporting mods, only engine mod is headstuds. im thinking about opening up the turbo and raising boost with e85. i was just wondering if the stock motor can handle 25-28psi?
__________________
aem intake, hks ti catback, invidia test pipe, downpipe, ported mani, hks 272s, fidenza camgears, 1200cc injectors, motor mounts, torque dampener, fp green turbo, ams intercooler and piping, hks ss bov, aem ems, cosworth head studs, walbro 255 fuel pump, hks DLI ignition amplifier, apexi n1 coil, act 2700, ams mini battery, slotted rotors, defi boost, egt, oil temp, aem wideband, apexi tt,e85. 426whp @ 27psi
Offline
Mar 30, 2009, 05:13 AM
Personal Sales Rating: ( 13)
Drives: 05 VIII Tarmac Black
__________________
05 TB EVO8
|Kelford 272's|Supertech Dual Springs|Supertech Valves|Ported IM and Head|Helix Cam Gears|Greddy Ti Exhaust|PPI Intake Tube|PPI UICP|PPI Modified LICP|Amsoil Air Filter|APEXi AVC-R|Megan V2 DP and Testpipe|APS BOV|Works Short Shifter|Zaklee Bushings|Walbro FP|EPM O2 Dump|PPI Ported/Swain Coated Exhaust Manifold|PPI ported Hotside|PPI 4" IC|FP Ported and Polished Green|FIC 1050s|LC-1 Wideband|Sparktech Non-CDI|CA670 Remote Start|Exedy Twin HD|Megan Track Coilovers|AMS Tuned
Offline
Mar 30, 2009, 07:46 AM
Personal Sales Rating: ( 29)
Drives: 05 Silver Evo 8.5, 03 TB Evo 8 Project, 08 R6, and Sievers' 2.3L 37R Evo 8 @ 40+ psi
Yea, you have headstuds. Should be fine.
Offline
Mar 30, 2009, 08:10 AM
Personal Sales Rating: ( 6)
Drives: 05 EB evo
Are headstuds even needed for that power requirement?
I would assume you would be fine as long as you have the supporting fuel mods and tuning.
__________________
AKA: PM-Performance
APAT Tuned
05 EB VIII
345WHP/322TQ on 23PSi on the "HeartBreaker" Mustang Dyno (old numbers)
Offline
Mar 30, 2009, 10:12 AM
Needed? Maybe not. Safety precaution though. The way you learn that you needed them is when your headgasket goes or worse...
Offline
Mar 30, 2009, 10:19 AM
Personal Sales Rating: ( 5)
Drives: 2006 EVO RS, 1992 Laser RS AWD 6/4
It is better to be on the safe side rather than the other way around.
-Shane
Offline
Mar 30, 2009, 10:57 AM
Personal Sales Rating: ( 0)
Diiirk had a Green with supporting mods on e85 for a while and ran 10.72 @ 127. I don't think he has head studs. Well at least his mod list doesn't say so. From my experience as a technician for 5 years and based on what I've read, for the power you'll be making with a green and e85 I really don't think head studs are a necessity. On top of that, not having them is like a fail safe. If you have head studs and for whatever reason you start to have pre detonation, whats going to happen when a piston starts to compress air and fuel thats burning and expanding in the combustion chamber? You'll be producing some serious heat and you're going to bend a rod or bust a hole in the side of your block. On the other hand with the factory head bolts in the same scenario, they'll stretch, you'll lift the head and all you'll have to do is replace a head gasket and clean up a small mess. I honestly can't justify doing head studs unless you plan on producing upwards of 28psi on a turbo at least the size of a red or unless you have the head off already and its just plain convienient to do them. If it ain't broke, why mess with it?
__________________
Quote:
Originally Posted by davidbuschur
I think some of FP's turbos should be named, "Blue vein throbber".
Offline
Mar 30, 2009, 11:31 AM
Drives: 05 EB evo
Quote:
-Shane
to my knowledge 4G's arent really in need of headstuds for the little HP a Green is gonna make. You can push it hard and make more HP, but again, I just dont think its needed on this motor. If I had a reason to take the head off, then id prob do a set to have em though.
__________________
AKA: PM-Performance
APAT Tuned
05 EB VIII
Offline
Apr 2, 2009, 08:46 PM
Personal Sales Rating: ( 34)
Drives: '03 CT9A / '06 MDX / '07 CBR600RR
__________________
APM Built 2.0 / APM CNC Head / Shearer HTA3582 / Magnus V5 IM / GSC S2 Cams / APS Catback / SpoolinUp COP
BR Dual Pumps / FIC 1450cc Injectors / Fuel Lab FPR / Perrin Fuel Rail / TiAL Q BOV / APM UICP
APM Driveshaft / Nisei FMIC / PPI 65mm TB / Dejon 4" Intake / Hallman MBC
Tephra v7 Speed Density
625whp / 507wtq - Komet Motorsports Mustang Dyno
Offline
Apr 2, 2009, 10:07 PM
Personal Sales Rating: ( 1)
Drives: BBK EVO
it's all in the tune. i can't emphasize this enough.
Offline
Apr 2, 2009, 11:17 PM
Quote:
x2. Find a reputable tuner that knows what he's doing and you'll be straight with what you have.
Offline
Apr 2, 2009, 11:42 PM
Silver Sponsor
Personal Sales Rating: ( 22)
Drives: 06 Rally Red MR
I had no issues with my Green on E85 and a stock bottom end at 31psi.
Offline
Apr 4, 2009, 10:08 AM
Personal Sales Rating: ( 8)
Drives: 2006 Mitsubishi Evolution IX
Quote:
like other have said and imo, head studs are cheap and reliable, get'em and you won't be sorry!
Offline
Apr 4, 2009, 10:25 AM
Personal Sales Rating: ( 23)
Drives: lancer evo Ix mr
IMO, you should get headstuds they are only 200 or so not sure, it's a way to stay on the safe side , arp headstuds is one of the first mods i ever didi to my car , and they will aslo prevent lifting your head.
Offline
Apr 4, 2009, 02:23 PM
Quote:
i have the headstuds & rod bolts, is there anything else (main studs)
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
