Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Dyno Tuning and Results
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 30, 2009, 02:59 PM   #1
Personal Sales Rating: (44)
RS back on the dyno......again, ignition and muffler testing.
I am working on some more changes that I am preparing to make on my RS. In order to do this I wanted to get a baseline on the car again and I had a few things I wanted to try and test.
The last time the car was on the dyno it made 683/551 without any smoothing of the graph, dyno sheet printed was 677 whp if I remember correctly.
I changed a few things. I changed the spark plugs I am running to a very high end NGK racing plug. The plug is a #5442, it's iridium, 8 heat range.
The first few pulls on the car I did with a new muffler in the exhaust. I'm getting old and I am tired of the noise to be honest. My car has the JDM EVO9 rear bumper cover on it. We make an exhaust specifically for that rear cover. The exhaust puts our bullet muffler in the center of the car so there isn't a big ugly can hanging out of the rear. This leaves your options pretty limited to make the car quieter if you have that rear bumper cover.
The new muffler is very small in diameter and is straight through 3", therefore I am going to refer to it as the SD (small diameter) muffler. I didn't expect much in noise reduction from it. I did some decibel testing at idle only and was pleasantly suprised. My car at idle dropped nearly 4 decibels. That is substantial as 3 decibels to the human ear is twice as loud. It took nearly, if not all, of the raspiness out of the exhaust.
Now for the power testing. I made a few pulls with the additional SD muffler and was shocked to see the power, the car made 694 whp and 550 ft lbs ot torque. That is the best power my car has ever made, that was in 3rd gear.
We then took the SD muffler out and put the straight pipe back in. The changes were so insignificant that it's hard to say if there was actually any change or not, 694 whp and 554 ft lbs of torque. The boost did change slightly, less than .5 psi in a few spots, which could account for the slight increases around 6,000 rpm.
Here is the dyno graph of the SD muffler/bullet muffler combo vs. the bullet muffler by itself:
I think for the small changes in power I will be keeping the SD muffler on my car, it is so much quieter and enjoyable with it. Here is a picture of the new SD muffler installed in the rear section of our JDM EVO9 exhaust:
Now that I completed that testing I had another mission. My personal car has a slight studder in it at part throttle cruise that is only noticable on the dyno. I cannot feel it on the street what-so-ever. I have blamed it on just about every part you can imagine on the car and swapped just about everything you can imagine. It is just barely there and annoys me. I have heard about this same thing from other customers too in the past.
One of the things I kept going back to time and time again is the COP ignition. I was quite certain that this feeling was from the ignition.
We have, as I have said before, wired our COP's per M&W's instructions. We have also run M&W's harness that they sent us directly. NONE of these changes have had ANY effect on the cars drivability or performance.
Well today we have a car in our shop for a very large build and in the trunk of the car was..............a complete Spark Tech ignition. I've read here and in other places about our competitor Spark Tech and heard how this and that are different etc. Him and I have spent more than enough time argueing on EVOm about our products.
Given the car was on the dyno for testing and I had the opportunity to very easily put our competitors ignition on my car I went ahead and installed it. Needless to say we also looked it over very good. The unit is wired just as M&W's instructions suggest.
I'd like to say something nice at this point in time but given the fact it will show up in someone's signature or their advertisement I will not The only problem found is the main connector doesn't have the insert in it to lock the pins in place. I'm sure after this comment, like others I have made though, it will now be corrected.
With the Spark Tech ignition installed on my RS I did some testing and of course a dyno pull. Honestly, no difference. No change in this "jerkiness" I was feeling, no change in power, nothing. If I had not changed the ignition myself I'd have never known anything was different.
So, with that behind me I was still fixated on what this feeling was in the car. For the first time I got the bright idea to pull the COP off the car and simply run a set of stock coils and stock plug wires. I didn't do any WOT pulls, this was only to find out what was causing the car to studder. No change again.................SOB!!!!
I guess this rambling about the ignition wasn't really needed but I know there are other guys who have this studder in their EVO's too. I also know that with a lot of talk I have seen and heard there is some thoughts that it is related to the COP's. This does NOT seem to be the case, whether is it ours or ST's.
I will have to get on a mission to find out what this annoyance is, atleast now I am 100% certain that it is nothing to do with the ignition.
Anyone shopping for a COP can be confident in buying either unit.
Next week will hopefully bring some further testing.
Just for a quick description of the car for those that are going to ask:
BR EVERYTHING
Stage 3, 2 liter, standard bore
Stage 3 head
BF272's
PTE 1200's
BR double pumper
BR BFIC
BR 3" turbo back
BR COP
AEM EMS
BR forward facing turbo kit
HTA86
Wilson V2 intake
BR 65 mm throttle body
Peak boost, 41 psi
Offline
Old Jan 30, 2009, 03:36 PM   #2
Personal Sales Rating: (4)
RAbishi's Avatar
Drives: EVO IX MR
I might just have to get that SD muffler when I order my exhaust from you. Quieter and no power loss, it doesn't get much better than that!
__________________
Ryan
E85 Powered
2006 Evo IX MR
1991 Toyota MR2 Turbo
Youtube Channel
Offline
Old Jan 30, 2009, 03:39 PM   #3
Personal Sales Rating: (0)
Meeh Lucky IX's Avatar
Drives: 2006 Evolution IX MR
Nice write up Dav I remember having that studder as well on partcial throttle when I had a VTA Bov it got so annoying I ended up selling it and going back with the Evo9 Bov. Almost at 700whp thats amazing can't wait until your Street RS go's into the 8's : )
__________________
Eip Racing
Piloted By: Chris N.
Quarter Mile ET: TBA
Mustang Dyno
513.6awhp @ 6750rpm
433.9awtq @ 5750rpm
@ 30psi of boost
Offline
Old Jan 30, 2009, 03:46 PM   #4
Personal Sales Rating: (2)
Guerillah's Avatar
Drives: EVO IX MR
Send a message via AIM to Guerillah
Awesome results. How much is that rear section going to cost?
__________________
Offline
Old Jan 30, 2009, 04:15 PM   #5
I don't have the pricing finished for the SD muffler. It's going to depend on how it's ordered. Cheapest way to get it is with a full exhaust system. Building it as a replacement for any part is going to be the most expensive because it has to be built with seperate raw material rather than cutting a section out of a complete exhaust system and put in place of a piece of pipe that is already there. The muffler itself is only about $90 I believe.
Sorry, I should be more prepared for the pricing question.
Offline
Old Jan 30, 2009, 04:20 PM   #6
crcain's Avatar
Drives: vi rs
Nice post... so how come she got more powerful though? Also I'm forgetting the heat range of NGK's... 7 is standard and 8 is one step colder yes? How come you didn't try a WOT pull with the stock coils?
__________________
10.7 granny shifting - http://www.youtube.com/watch?v=sOEL7uGJIuc
Autronic, 2.4l, MAD spec piper cams, AMS kit, FP HTA 35R, RC 3" exhaust, AIM Dash, Kansai inlet, q45 TB, Buschur COP
Tuned by Mark Shead
Offline
Old Jan 30, 2009, 04:24 PM   #7
Personal Sales Rating: (9)
ExViTermini's Avatar
Drives: 03 evo
The stutter you speak of I've experienced in my own cars, though it was very noticeable on the street
I'm sure you have, but in my efforts to maybe offer some semi-form of help or solution, have you tried pulling out timing in that area or changed the dwell?
This helped my car tremendously, almost to the point of it not being there...
__________________
03 Rally Red
600whp sold and gone :(
03 Apex Silver
370ish whp sold and gone :(
Offline
Old Jan 30, 2009, 05:30 PM   #8
crcain, the extra power.......I'm guessing most of it is from simply the difference in the air. While the intake air temps were very close to equal from the last testing I did it was colder today than any other time I have dyno'd the car. Yes, the 8 heat range is one step colder. I know for sure the car would misfire on the stock coils/wires, I saw no point in letting the car misfire for no reason. It's hard on everything when it happens.
exvtermini, yes, I have moved the timing and the dwell settings around in the past, it is a very good suggestion though. There are a number of things in the ignition set up in the AEM that I don't agree with 100%. I need to take an extensive amount of time to look into it further and mess with nothing but these settings that do not seem to be right to me. I think some of these settings are the reason people foul plugs and have more misfire problems than on the stock ECU.
Offline
Old Jan 30, 2009, 05:54 PM   #9
EvoM Administrator
Personal Sales Rating: (1)
SASD209's Avatar
Here we go again. This time I have even less patience. Posts deleted. If the posts re-appear, poster will be banned. If this gets off-topic and out of hand, same thing: a ban. Don't test me people, I stand by my word. Now, let's keep this on-topic and factual. Carry on.
__________________
Our FAQ's can be found here:
http://forums.evolutionm.net/faq.php
Our rules can be found here:
http://forums.evolutionm.net/evom-an...uncements.html
NRA Life Member
USNI Life Member
Offline
Old Jan 30, 2009, 07:42 PM   #10
Personal Sales Rating: (13)
vwjeff's Avatar
Drives: WW Evo IX Buschur Race car. 97 GTi VR6T, self built and tuned. 98 Jetta VR6 DD.
Send a message via AIM to vwjeff
Its BS your car makes that kind of power in 3rd gear
Thanks for the testing buddy, that new muffler looks very nice! I wounder if it is better than my "old" school race muffler?
__________________
I USE AND ONLY SUPPORT THE BEST. IF BUSCHUR MAKES IT, I HAVE IT
Buschur Built and Tuned... 9sec full weight street car.
New build in progress at Buschurs now. Will be Nevada's Fastest Evo.
Winning, HP and the FASTEST Evo's start here
http://www.buschurracing.com/
http://www.awdmotorsports.com/
http://www.shearerfabrications.com
http://www.cbrdspeedfactory.com/
www.myspace.com/vwjeff
Come see me at... http://highboostforum.com/forum/forum.php
Offline
Old Jan 30, 2009, 07:57 PM   #11
I'd say it's better and I'd say it's quieter too! You're going to like how my car sounds.
Offline
Old Jan 30, 2009, 08:51 PM   #12
LoKiEvo's Avatar
Drives: 2003 EVO 8
Hey Dave, any chance we can get a picture of how it fits w/ your rear undertray? What about a video comparing the 2 sounds, give us a sample of how much quieter it is.
Also, I know your theory behind the 3rd gear dyno pull, but I think everyone would love to see what the car makes on a 4th gear pull.
__________________
The day you become satisfied with how fast you are, check your pulse you may be dead!!
If you dont support our Military then get the f*ck out of our Country!!!
Offline
Old Jan 30, 2009, 10:56 PM   #13
Personal Sales Rating: (91)
DynoFlash's Avatar
Drives: 9.50 @ 148 (no nos)
I agree on the aem ignition settings
Interestingly with the HYDRA ems I have been running up to 700 whp at 28 psi with the stock coils and wires no HKS twin fire
With an AEM a twin fire is required to make that kind of power
I suspect the issue is in the drivers themselves and not in the software settings
I am anxious to see the new AEM boxes comming out and see if they have improved upon some of these issues
BTW - great testing David - keep doing what you do !
Offline
Old Jan 31, 2009, 02:33 AM   #14
Personal Sales Rating: (6)
Johnboy1065's Avatar
Drives: Lancer Evolution VIII
Send a message via ICQ to Johnboy1065 Send a message via AIM to Johnboy1065
will you be offering this SD muffler in a slip fit???
__________________
Buschur Tuned 500+ WHP on 93 Octane!
2.3 Liter Stroker, Buschur Front facing turbo kit w/HTA 3586R, Buschur Stage 3 Head w/BF 272 Cams, Driven Innovations Intake manifold, Buschur Race Core Intercooler
For Sale Air conditioning parts!! http://forums.evolutionm.net/sale-pa...ning-pump.html
For sale MAF sensor!!! http://forums.evolutionm.net/sale-en...af-sensor.html
Offline
Old Jan 31, 2009, 08:34 AM   #15
I will post pictures of it on the car next week and I can try to video the car with and without it. I have a feeling it is going to be hard to tell from a video but we can give it a try. Please shoot me a reminder in my PM's next week if I seem to have forgotten.
Personally Al, I don't think it's the drivers, I'm pretty sure it's in the software settings. You and I will have to talk about it further off the forums but there are definetely some things in there that can not be right.
johnboy, yes, for sure it is offered in a slip fit. We built a few of those already and shipped them out.
Offline
Tags
1988, accord, buschur, coil, decibel, diameter, drivability, dyno, honda, idle, ignition, mr2, muffler, problems, sd, small, straight, test, testing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
