Oct 25, 2009, 09:59 PM
Personal Sales Rating: ( 1)
Drives: evo ix
Hids ruining radio signal
I put in a hid kit and now every time I turn my lights on the radio gets really fuzzy. It's an aftermarket stereo but, jeez I don't know what I could do.
Offline
Oct 26, 2009, 12:18 AM
Drives: 06 IX GG,
check the ground on the amp...or try changing it up move it around..its a grounding problem...
__________________
06 Graphite Gray IX WingLess
OUTSIDEBlacked out Headlamps*APR Carbon Lip*Tein springs*Window visors*Oem Hids*Custom Hood Dampners*Window tint*Vortex Generator*short antenna*$10 JDM Tails*Amber sidemarkers*Diy Plate Bracket
ENGINE20psi*Injen Intercooler pipe Kit*Xs Engineering DP*Bushur CB*Forge MBC*Walbro 255lph*Miata Battery*Act street disk*Pro-lite flywheel*clutch pill removed
INTERIORRadio relocate kit*SWboost guage*IPOD hookup
Next:TUNE 330 here i come
Offline
Oct 26, 2009, 06:06 AM
Personal Sales Rating: ( 0)
Drives: Evo IX WW
Quote:
+1
Or check your Grounds upfront by the actual lights. Did you install both at the same time or one after the other. Moreover, when did the problem occur? I am assuming you had the aftermarket stereo, everything was fine, installed the headlights; fuzz. If thats the case then I would say check your headlight(s) ground. It may seem odd, but in the end a bad ground can do funny things to your car. Friend of mine built a B16 in a civic, car wouldn't turn over b\c of a bad/ incorrect ground.
Lastly, and this would be the last thing I would think about, but just curious where did you get the HIDs? Used? did they come out of someone elses car? are you 100% they are in 100% working order?
Reason: reread OP
Offline
Oct 26, 2009, 10:33 AM
Personal Sales Rating: ( 11)
Drives: EB IX
Its a bad Balast(s) .
All ready been down that road !
__________________
HKS intake/EBAY IC/3'' turboback/ECUflash(BigRic touch up)26psi GM 3 port
355HP/327TQ Dynojet
Offline
Oct 26, 2009, 10:39 AM
Drives: 2003 Galant
Lol that's kind of a broad statement. That's like him asking why his car won't run (threw a rod and doesn't kno it yet). And u popping in and saying "your out of gas! Already been down that road!" lol
Offline
Oct 27, 2009, 08:30 AM
Drives: Evo VIII
Quote:
And what was the point of posting that? At least he gave some feedback.... What did you give nothing.. Fail
+1 to the ground though. Make sure your speaker wires are seperated from other wires. This might cause it to.. Just a thought though. Good Luck!
Offline
Oct 27, 2009, 02:42 PM
Drives: EB IX
Like I said Ive all ready been down that road
$75 hid kit
I left out the the hrs of phone calls to the seller / tracking / isolating /switching out ballast / bulbs / removing front end and trying a "fix" noise suppressors from the seller ...
I learned alot since my 13th post
__________________
355HP/327TQ Dynojet
Offline
Oct 28, 2009, 12:27 PM
Drives: Evo IX WW
$75 hid kit
Lol oddly enough I thought to actually recommend/ say it could be a ballast in my post a few back, just thought it would be jumping to conclusions too fast...
Offline
Oct 28, 2009, 03:03 PM
Drives: EB IX
Quote:
LOL
Wife tells me Iam not as smart as I think Iam , and I might be(Iam) wrong .
But he said he just put them in , from what Ive seen most new HID kits dont use the solenoid/wiring set but instead use a plug-n- play set up .
So it shouldnt be a ground seeing how it uses the stock wiring .
Soooooo I say the its the Ballest(s) and I did stay in a Holiday Inn last night
__________________
355HP/327TQ Dynojet
Offline
Oct 28, 2009, 04:04 PM
Drives: Evo IX WW
LOL
Yea tough to tell, OP left a few details out, and we haven't heard back from him since. My money is on something with the lights, like I said just a few details left out to really dive into it. Funny you had the same thing happen, in an ironic way.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
