Oct 18, 2009, 09:57 PM
Personal Sales Rating: ( 5)
Drives: Evo VIII
Alpine iDA-X300
hi.. i donīt know if this forums is for this... but i have a question... i have this head unit (Alpine iDA-X300), and i have a problem with the USB.... already searched in google with no results...
when i add new folders to the USB the stereo wonīt recognise the new folders unless i disconnect the battery to reset the stereo... and then the stereo search for new folders again...
i read the manual and i cant find how to reset the BANK again...
maybe this is not the correct place for this, but i hope you can help me...
__________________
Quote:
Originally Posted by EvoJoeIX
i love peoples excuses and reasoning for spending money on their evo....
makes me laugh
Quote:
Originally Posted by scumrat
what do you mean? Anyways my little sister just got an A+ on here math test so i think im gonna do a full 2.3L build with a 6262 and stage 3 shep trans. You know, just to show her how proud i am.
Offline
Oct 19, 2009, 10:55 PM
Personal Sales Rating: ( 1)
So you disconnect the usb, add folders/songs, reconnect the usb and it won't recognize it until you reset the headunit?
Offline
Oct 20, 2009, 01:13 AM
Drives: Evo VIII
Quote:
yes... wont recognize the new folders... still showing the last folders...
if i reset the headunit then yes...
__________________
makes me laugh
Offline
Oct 20, 2009, 09:48 AM
Personal Sales Rating: ( 3)
Drives: 05 MR
Call Alpine and see what they suggest it might be a bad headunit.I have the X305 I think it is but might be the 300 as well and I dont have issues with it.
Offline
Oct 20, 2009, 10:39 AM
Hmmm.... that's strange. When you reconnect the usb does it say that it's searching for a few seconds before listing all folders/songs?
It should just pop up... try Alpine support... I haven't seen that issue before and I've installed a lot of these headunits.
Offline
Oct 21, 2009, 01:45 AM
Drives: Evo VIII
nop.. that is the problem.. never start to search for new files... when i reconnect the usb inmediately start to play the last song played after disconnect the usb...
__________________
makes me laugh
Offline
Oct 21, 2009, 07:04 PM
Try changing the source to anything other than usb before you disconnect it... the problem may be that if you are unplugging the usb while it is still reading/playing it may be doing something to the headunit.
If you switch source to tuner and then disconnect the usb and then plug the usb back in... does it make a difference?
Offline
Nov 1, 2009, 04:58 PM
Personal Sales Rating: ( 0)
Drives: Evo IX, Mercedes-benz G500
What USB device do you use?
i have iDA-X001 and using USB hdd with it without any problems.
As i've read on the audio forums, there can be some issues with X-series while USB drives, and it depends on HDD manufacturer and model, some of them simply doesn't work with headunit, some of them working with errors and problems.
As tip: i'm using WD 160gb 2,5" external drive, it's going for something like 50$ in stores. No problems with adding folders, files, playback e.t.c.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
